Follow this guide to remove and replace the screen on the iPad Pro 9.7".
The home button assembly is paired to the iPad's logic board. In order to maintain Touch ID functionality, you must transfer your original home button to the new display assembly. This guide includes these steps.
Do not use metal prying tools, or you risk shorting and damaging the iPad.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Handling it by the tabs on either end, place a heated iOpener over the top edge of the iPad.
Let the iOpener sit on the iPad for two minutes to soften the adhesive securing the front panel to the rest of the iPad.
As you follow the directions, take special care to avoid prying in the following areas:
Home Button
Front Facing Camera
Main Camera
crwdns2935267:0crwdne2935267:0Clampy - Anti-Clamp$24.95
Elevate the iPad enough for the Anti-Clamp's arms to rest above and below the screen.
Pull the blue handle towards the hinge to disengage opening mode.
Position the suction cups near the top edge of the iPad—one on the front, and one on the back.
Push down on the cups to apply suction to the desired area.
Push the blue handle away from the hinge to engage opening mode.
Turn the handle clockwise until you see the cups start to stretch.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next two steps.
Place a suction cup over the iPad's front-facing camera and press down to create a seal.
Firmly pull up on the suction cup to create a small gap between the front panel and the rear case.
Once you've opened a sufficient gap, insert an opening pick into the gap to prevent the adhesive from resealing.
Slide the pick along the edge of the display, towards the headphone jack.
If there is still a considerable amount of resistance when sliding the opening pick, repeat the iOpener heating procedure and apply additional heat.
Insert a second opening pick by the front-facing camera.
Slide the second pick along the top edge of the iPad, towards the Sleep/Wake Button.
Insert a third pick by the front-facing camera.
Bring the right opening pick down and around the top right corner of the iPad.
Bring the left opening pick around the top left corner of the tablet.
Reheat the iOpener and lay it over the right edge of the display to loosen the adhesive underneath.
Slide the right opening pick roughly halfway down the display.
Reheat the iOpener and apply heat to the left side of the iPad.
Slide the left-hand opening pick about halfway down the edge of the display.
Slide the opposite opening pick down to the bottom right corner of the iPad.
Slide the left-hand opening pick down the edge of the display until you reach the corner.
Use the iOpener to apply heat to the bottom edge of the iPad.
Bring the right-hand opening pick around the bottom corner of the iPad.
Remove the right-hand opening pick at the bottom of the iPad.
Slide the left-hand opening pick along the bottom edge of the display, then remove it from the bottom right corner of the iPad.
Use picks to ensure most of the adhesive has been cut through on the top, left, and bottom sides.
Twist the top and bottom picks to separate the display assembly from the rear case.
Swing the display assembly towards the right of the case, using the right edge as a hinge.
As you move the display assembly, make sure that the display ribbon cable is not being stressed.
Continue swinging the display assembly until it lays flat next to the rear case.
Use a Phillips screwdriver to remove the eleven 1.3 mm screws securing the EMI shield.
Apply a heated iOpener to the EMI shield on the logic board for one minute.
Lift the logic board EMI shield, starting at the edge nearest the top of the iPad.
Slowly peel the EMI shield up from the logic board.
Remove the logic board EMI shield.
Use a Phillips driver to remove the 1.7 mm-long screw securing the battery connector.
Squeeze the sharp protrusion with a pair of pliers to flatten it.
Repeat the process for all sharp protrusions along the edges of the EMI shield.
Slide the battery blocker underneath the left side of the logic board's battery connector at a 35 degree angle.
Leave the battery blocker in place as you work.
Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the logic board to the left and right of the battery connection.
Wait one minute for the isopropyl alcohol to weaken the adhesive under the logic board.
Try to insert the battery blocker. If the logic board doesn't easily lift up, apply a few more drops of isopropyl alcohol.
Use a Phillips screwdriver to remove the three 1.3 mm Phillips screws securing the display cable bracket.
Remove the display cable bracket.
Use the flat end of the spudger to disconnect the display assembly connector from the motherboard socket.
Repeat the previous step for the two remaining connectors.
Remove the display assembly from the frame.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to remove the tape covering the ZIF connector above the home button.
Use the point of a spudger to lift the flap on the ZIF connector that secures the cable.
Use tweezers to slide the cable out of the ZIF connector.
Use an iOpener, heat gun, or hair dryer to soften the adhesive under the cable before you pry it up.
Alternatively, apply a few drops of isopropyl alcohol to the cable and wait for a minute to let the adhesive soften.
Starting from the ZIF connector, use an opening pick to separate the home button cable from the adhesive holding it in place. Stop when you reach the home button.
Apply a few drops of isopropyl alcohol to the base of the home button bracket.
Alternatively, you can use a heated iOpener to loosen the adhesive.
Insert the edge of an opening tool under the home button bracket lip.
Pry up with steady force to loosen the bracket.
crwdns2935267:0crwdne2935267:0Tesa 61395 Tape$8.95
Remove the home button bracket.
Scrape off as much of the old adhesive residue as you can, then clean it with acetone or high concentration (>90%) isopropyl alcohol.
Secure the bracket with E6000 glue, superglue, or high-strength double-sided tape. Make sure the bracket is aligned correctly before allowing your adhesive to cure, or the home button will not click when pressed.
Gently push the home button from the front of the display inward using the tip of a finger.
Compare your new replacement part to the original part. You may need to transfer remaining components (such as the camera bezel) or remove adhesive backings from the new part before installing.
To reassemble your device, follow the above steps in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Repair didn’t go as planned? Check out our iPad Pro 9.7” Answers community for troubleshooting help.
crwdns2935229:040crwdne2935229:0
crwdns2947412:018crwdne2947412:0
How would you re-attach that EMI shield after it has been peeled off?
Garrett Coyle - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi Garrett,
Try to straighten it as much as possible and remove any jagged edges around the edges. The screws will hold the shield in place.
Arthur Shi - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have a broken glass cover on the LCD screen on my iPad pro 9.7, is it possible to just replace the glass?
Esko Ala-Nisula - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
It is possible, although extremely difficult. You will need to remove the lcd/digitizer without doing any damage to the lcd. Then you need to separate the lcd from the cracked digitizer, clean the lcd, and then glue the lcd to the new digitizer. The fact that your asking this leads me to believe that you don’t have the many expensive machines and supplies to complete this correctly. I would just replace the lcd, as there is a fair chance you will damage it doing this removal anyways - depending on your skill level.
Hope this helps!
Steve Noah - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Doing a screen replacement, I followed the instructions but, it won’t come back on no picture and I don’t think its the back light because i shined a light on it and I can’t see anything. It will charge but no picture, tried the original broken screen and two others. Any Ideas?
Zachary Swagger - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
