iPad Pro 9.7" Logic Board Replacement
  1. iPad Pro 9.7" Logic Board Replacement, SIM Card Tray: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, SIM Card Tray: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, SIM Card Tray: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a SIM card eject tool, bit, or a paperclip into the small hole in the SIM card tray, located near the bottom edge of the iPad.
    • Press firmly to eject the tray.
    • Remove the SIM tray.
    My iPad Pro 9.7 wifi only has no pinhole for sim card
    Michelle - crwdns2934203:0crwdne2934203:0
    You’re right! The Wi-Fi only model does not have a pinhole. Skip this step for your iPad.
    Arthur Shi -
  2. iPad Pro 9.7" Logic Board Replacement, iPad Pro 9.7" Opening Procedure: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, iPad Pro 9.7" Opening Procedure: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, iPad Pro 9.7" Opening Procedure: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    Covering the screen with tape proved an essential safety step with the ipad display/lcd I just replaced. The screen was so badly broken that a part of it was almost powder, but the combination of the tape and sticky adhesive residue kept most of that together, and cleanup was pretty easy as a result. One caveat, though, is that the tape will probably make the suction cup useless for pulling up on the display. It did for me, anyway.
    John Lasseter - crwdns2934203:0crwdne2934203:0
  3. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The following steps involve using an iOpener to soften the adhesive holding the front panel assembly in place. When using the iOpener, be sure to heat it in the microwave for no more than 30 seconds.
    • Handling it by the tabs on either end, place a heated iOpener over the top edge of the iPad.
    • Let the iOpener sit on the iPad for two minutes to soften the adhesive securing the front panel to the rest of the iPad.
    I see a lot of videos that show using a heat gun on low to soften the adhesive. I know there is inherent risk with this since you could start delaminating things, but is it something that could be considered (at your own risk)? Or is it something that could have more risks than I am realizing?
    joshcorey - crwdns2934203:0crwdne2934203:0
    Yes, you can definitely use a hair dryer, heat gun, or a heating pad. If you're using a heat gun, be careful not to overheat the display. The surface should feel slightly too hot to the touch.
    Arthur Shi -
  4. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While the iPad looks uniform from the outside, there are delicate components under certain portions of the front glass. To avoid damage, only heat and pry in the areas described in each step.
    • As you follow the directions, take special care to avoid prying in the following areas:
    • Home Button
    • Front Facing Camera
    • Main Camera
    Verwirrend: Es sollte heissen, dass man an den beschriebenen Stellen eben NICHT hebeln sollte.
    Felix - crwdns2934203:0crwdne2934203:0
    Danke! Ich habe den Teil mit dem NICHT hebeln nochmal hervorgehoben.
    Fabian Neidhardt -
    The screen cable is on the right side at the bottom. Be super careful not to slice too deeply there
    Gerald - crwdns2934203:0crwdne2934203:0
  5. iPad Pro 9.7" Logic Board Replacement, Anti-Clamp instructions: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Anti-Clamp instructions: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Anti-Clamp instructions: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Elevate the iPad enough for the Anti-Clamp's arms to rest above and below the screen.
    • Pull the blue handle towards the hinge to disengage opening mode.
    • Position the suction cups near the top edge of the iPad—one on the front, and one on the back.
    • Push down on the cups to apply suction to the desired area.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, you can use packing tape to create a grippier surface.
  6. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the blue handle away from the hinge to engage opening mode.
    • Turn the handle clockwise until you see the cups start to stretch.
    • Make sure the suction cups remain aligned to each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
    Do not use the anti clamp beyond this step. Doing so will run the risk of putting pressure on the screen and cracking it. Only use it for the initial opening of the device.
    Playincrzy - crwdns2934203:0crwdne2934203:0
  7. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place a suction cup over the iPad's front-facing camera and press down to create a seal.
    • To get the most leverage, place the suction cup as close to the edge as possible without going past the edge of the display.
    The dangerous place with ribbon cables is in the lower right corner. There is a cable at the edge, so insert the pick carefully. Or rather, the correct answer is not to put a pick up to 5 cm from the bottom right. Other than that, there are no other dangerous places.
    k.hama - crwdns2934203:0crwdne2934203:0
  8. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Firmly pull up on the suction cup to create a small gap between the front panel and the rear case.
    • Do not pull too hard or you may shatter the glass.
    • Once you've opened a sufficient gap, insert an opening pick into the gap to prevent the adhesive from resealing.
  9. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick along the edge of the display, towards the headphone jack.
    • If there is still a considerable amount of resistance when sliding the opening pick, repeat the iOpener heating procedure and apply additional heat.
    • Don't insert the pick past the bezel into the display area, or you will damage it.
    • A good rule of thumb is to never insert the opening pick more than a quarter inch into the iPad.
  10. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a second opening pick by the front-facing camera.
  11. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the second pick along the top edge of the iPad, towards the Sleep/Wake Button.
  12. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a third pick by the front-facing camera.
  13. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Bring the right opening pick down and around the top right corner of the iPad.
  14. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Bring the left opening pick around the top left corner of the tablet.
  15. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reheat the iOpener and lay it over the right edge of the display to loosen the adhesive underneath.
  16. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the right opening pick roughly halfway down the display.
  17. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reheat the iOpener and apply heat to the left side of the iPad.
  18. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the left-hand opening pick about halfway down the edge of the display.
  19. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opposite opening pick down to the bottom right corner of the iPad.
    • If necessary, reheat the adhesive on the right edge to loosen the display assembly.
  20. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the left-hand opening pick down the edge of the display until you reach the corner.
  21. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the iOpener to apply heat to the bottom edge of the iPad.
    You should avoid inserting the pick into the lower right corner as much as possible. The cable is nearby.
  22. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Bring the right-hand opening pick around the bottom corner of the iPad.
  23. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat for the left-hand pick.
    • Reheat and reapply the iOpener as needed.
  24. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the right-hand opening pick at the bottom of the iPad.
  25. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the left-hand opening pick along the bottom edge of the display, then remove it from the bottom right corner of the iPad.
    • Be very careful to not insert the pick more than a quarter inch into the display to avoid damaging the Home Button and display cables underneath.
  26. iPad Pro 9.7" Logic Board Replacement, Slice through the remaining adhesive: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Slice through the remaining adhesive: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Slice through the remaining adhesive: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use picks to ensure most of the adhesive has been cut through on the top, left, and bottom sides.
    • Twist the top and bottom picks to separate the display assembly from the rear case.
    • Do not attempt to remove the display—it is still attached to the rear case.
  27. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Swing the display assembly towards the right of the case, using the right edge as a hinge.
    • As you move the display assembly, make sure that the display ribbon cable is not being stressed.
    • Continue swinging the display assembly until it lays flat next to the rear case.
  28. iPad Pro 9.7" Logic Board Replacement, Disconnect the battery: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the eleven 1.3 mm screws securing the EMI shield.
  29. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the EMI shield on the logic board for one minute.
  30. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the logic board EMI shield, starting at the edge nearest the top of the iPad.
    • Slowly peel the EMI shield up from the logic board.
    • This takes a bit of force due to the many tiny clips securing the shield, and the shield may deform slightly. That's okay—try to keep the deformation to a minimum, and it will lay flat when reinstalled and screwed down.
    • Remove the logic board EMI shield.
    Don't peel the cover as shown from a short side. Lift the long side to avoid creasing the cover so much. This way it will lie flat when you reassemble it and not look so ugly. Also, you won't have to straighten so many creases with pliers
    Jim Meyers - crwdns2934203:0crwdne2934203:0
  31. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips driver to remove the 1.7 mm-long screw securing the battery connector.
    i get 1.65mm with my calipers but the 1.3s read 1.25 on my calipers too, so probably a 1.7mm
    bunjamins -
  32. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the EMI shield has any sharp protrusions after removal, you should flatten them before reinstalling the shield.
    • Squeeze the sharp protrusion with a pair of pliers to flatten it.
    • Repeat the process for all sharp protrusions along the edges of the EMI shield.
  33. iPad Pro 9.7" Logic Board Replacement, Battery connector information: crwdns2935265:033crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Battery connector information: crwdns2935265:033crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Battery connector information: crwdns2935265:033crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
    Le connecteur de batterie est il réparable si abîmé ?
    Maverick - crwdns2934203:0crwdne2934203:0
    If the connector broken on the battery side is from an old battery to be replaced, there is no problem if it breaks. I think breaking means tearing the loop, but it's impossible to repair it. However, if you plug it in and screw in the screw, it can be used as a connector for the time being.
  34. iPad Pro 9.7" Logic Board Replacement, Disconnect the battery: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Disconnect the battery: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Disconnect the battery: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
    • Ensure that the iFixit logo on the battery blocker is facing up.
    • Slide the battery blocker underneath the left side of the logic board's battery connector at a 35 degree angle.
    • The battery blocker's right prong should slide between the left side of the logic board's battery connector and the battery's contact pads. The left prong should slide under the logic board.
    • Don't push the battery blocker underneath the connector or logic board with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, refer to the next step for information on loosening the logic board. You can also try using a playing card to disconnect the battery instead.
    • The battery blocker or playing card should slide under the logic board without encountering any blockages. After insertion, they should rest at a 15 degree angle.
    • Leave the battery blocker in place as you work.
    le connecteur de la batterie est t’il remplaçable ou repérable si jamais abîmé ?
    Si le connecteur est abîmé, Il n'est ni remplaçable ni réparable, je crois. Donc, il faut lever le carte logique suffisamment pour enlever ou le mettre le connecteur de la batterie.
  35. iPad Pro 9.7" Logic Board Replacement, Logic board adhesive information: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Logic board adhesive information: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If the battery blocker doesn't easily slide under the logic board, follow these steps to partially loosen the logic board from the frame:
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the logic board to the left and right of the battery connection.
    • Wait one minute for the isopropyl alcohol to weaken the adhesive under the logic board.
    • Try to insert the battery blocker. If the logic board doesn't easily lift up, apply a few more drops of isopropyl alcohol.
    • This doesn't apply when using the playing card method to disconnect the battery because the playing card is only inserted between the battery connector and the battery contact pads.
  36. iPad Pro 9.7" Logic Board Replacement, Remove the display bracket screws: crwdns2935265:036crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the three 1.3 mm Phillips screws securing the display cable bracket.
    i think we need to talk about the battery situation here. apple change up the style of battery connector on this model as well as some others. if someone can add to this list and add the appropriate photos in the right spot should help someone else. the battery tabs are open towards the battery side and inserting a tool in this area can pry them open further and damage or rip off the tab. some have found that by lifting on either side of the battery tab, they would not even encounter the tabs.
    greg - crwdns2934203:0crwdne2934203:0
    This operation shuld be doen before 30th step, so that it's more easy to remove EMI shield.
  37. iPad Pro 9.7" Logic Board Replacement, Remove the bracket: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Remove the bracket: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the display cable bracket.
    A tab was folded over a connector of some sort on the bottom side. I found it was a better to pull from the top to the bottom to fold the tabs slightly to remove this cover.
    rosecitymech - crwdns2934203:0crwdne2934203:0
    Actually it helps to move the cover slightly towards the bottom of the iPad as that disengages to tabs…
    DeeAnn Hopings - crwdns2934203:0crwdne2934203:0
  38. iPad Pro 9.7" Logic Board Replacement, Disconnect the display assembly: crwdns2935265:038crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Disconnect the display assembly: crwdns2935265:038crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of the spudger to disconnect the display assembly connector from the motherboard socket.
  39. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:039crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:039crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the previous step for the two remaining connectors.
  40. iPad Pro 9.7" Logic Board Replacement, Remove the display assembly: crwdns2935265:040crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Remove the display assembly: crwdns2935265:040crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    You "CAN" skip steps 41 through 98 and 102-109 if you're confident in your repair abilities and PATIENT. Lots of alcohol around all the edges of the battery, and apply heat to the back cover on one half of the battery, the slowly ease your "card under the edges of the battery. Wiggle it back and forth and add more alcohol under the edges of the battery where your working; DONT PUSH your card to hard or you will sli[p and damage components. Then do the same for the other half. When both halves are loose, fold over one end and slide the flat edge off the spudger under the area of the logic board next to the battery connector, then do the same to the other side; you want just enough of a gap under the logic board to lift the battery tab off of the post then you can remove the battery.
    Gregg Stanley - crwdns2934203:0crwdne2934203:0
    ディスプレイアッセンブリを外して、黒くて古い接着テープをはがしすためにぴっぱったら、ディスプレイと本体基盤を接続するコネクターのテーブを不注意で切断してしまった。これで、交換はあきらめで中止。注意されたし。ちなみに、手順41~89は省いてもバッテリー交換ができるのではないかと思います。
    susuper - crwdns2934203:0crwdne2934203:0
    If you skip to 99th step, it's very recommended to remove the battery from the opposite side of the logic board. When you arrive at the connector battery-logic board, after warming around the back of the connector, you slightly lift up the logic board so that remove the loop of the battery's connector. It is a good idea to check the shape of the connector in advance.
  41. iPad Pro 9.7" Logic Board Replacement, Detach the right ambient light sensor: crwdns2935265:041crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Detach the right ambient light sensor: crwdns2935265:041crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Detach the right ambient light sensor: crwdns2935265:041crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide an opening pick under the right ambient light sensor to loosen its adhesive.
    • There are two pegs on the shelf that position the ambient light sensor—one on the bottom edge and one near the top edge.
    The "right ambient light sensor" can be replaced?
    If yes, where can I find the replacement part?
    Michael Rodriguez - crwdns2934203:0crwdne2934203:0
    The light sensor has a rubber collar. If you lift the cover you can see a tiny peg pushed upwards onto the bottom of the sensor base. It’s the base you need to lift and it is stuck down
  42. iPad Pro 9.7" Logic Board Replacement, Remove the four screws: crwdns2935265:042crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the four 1.9 mm-long screws securing the upper speaker to the frame.
  43. iPad Pro 9.7" Logic Board Replacement, Apply isopropyl alcohol: crwdns2935265:043crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Apply isopropyl alcohol: crwdns2935265:043crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Strong adhesive secures the upper speaker to the frame.
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the upper speaker.
    • Wait one minute for the isopropyl alcohol to weaken the adhesive under the upper speaker.
  44. iPad Pro 9.7" Logic Board Replacement, Pry up the upper speaker: crwdns2935265:044crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Pry up the upper speaker: crwdns2935265:044crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool to pry up the left edge of the upper speaker.
    • Try to avoid bending the upper speaker while prying it up. Some bending will likely happen during this process, but excessive bending may damage the upper speaker.
    • If the upper speaker isn't detaching from the frame, apply a few more drops of isopropyl alcohol.
    These next 3 steps are the most difficult of the whole process. The speaker is glued down along its whole length which must all be freed. Use the iopener underneath the top of the iPad whilst you are waiting for the alcohol to work to help soften the glue.
    On the left hand side, there is a flat cable glued to the back plate and the speaker is then glued on top of the cable. So when you put the alcohol down it’s most likely to deboned the cable which will remain attached to the speaker as you lever it up and need carefully separating somehow.
    There is a zif connector on that cable underneath the speaker and just to the left of the front facing camera so there’s not much play. If you are unable to remove cable from the bottom of the speaker, you’ll pull the cable out of the connector as you lift the speaker. Don’t lever the speaker downwards (next step) until this zif connector is detached or you’re trash the connector itself.
    There’s also a round wire which passes underneath the speaker, that’s a bit stronger.
  45. iPad Pro 9.7" Logic Board Replacement, Move the left side of the upper speaker: crwdns2935265:045crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Move the left side of the upper speaker: crwdns2935265:045crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to push the left side of the upper speaker toward the battery just enough for the left speaker to slide out of its recess in the frame.
    The external speaker (headphone socket) on the left side of the speaker must be removed. 2 screws for the cover, 1 for the socket support. As well as a sensor of some sort. The cover for the sensor came off separately.
    Rogie B - crwdns2934203:0crwdne2934203:0
    I didn’t remove that speaker but doing so may give to more access to lift the speaker unit upwards.
    DO NOT move the speaker downwards until you have completely separated the speaker from the flat cable glued to the bottom of it on the left hand side or disconnected the zif connector. See my comment in previous step.
  46. iPad Pro 9.7" Logic Board Replacement, Remove the upper speaker: crwdns2935265:046crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Remove the upper speaker: crwdns2935265:046crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the upper speaker from the frame.
    • There are multiple cables under the upper speaker. Be careful not to damage them while removing it.
    • If any cables are still attached to the upper speaker while you lift it up, carefully peel them off of the upper speaker. You can apply more isopropyl alcohol if they don't easily peel away.
    • If the ZIF connector sticker near the front camera comes off while removing the upper speaker, reapply it to the ZIF connector.
    • If the ZIF connector near the front camera disconnects while removing the upper speaker, use the pointed end of a spudger to flip up the locking flap. Then, reinsert the ribbon cable and close the locking flap.
    • During reassembly, make sure the right ambient light sensor is on top of its shelf.
    • If there's any alcohol solution remaining in the device, carefully wipe it off or allow it to air dry before reinstalling the upper speaker.
    You are going to disconnect the zif connector later. If it’s popped out there’s not need to put it back.
  47. iPad Pro 9.7" Logic Board Replacement, Disconnect the right antenna: crwdns2935265:047crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Disconnect the right antenna: crwdns2935265:047crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to disconnect the right antenna's coaxial connector from its socket.
    • To reinstall, hold the connector in place and gently press straight down. The connector will “snap” into its socket.
  48. iPad Pro 9.7" Logic Board Replacement, Disconnect the left antenna: crwdns2935265:048crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Disconnect the left antenna: crwdns2935265:048crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to disconnect the left antenna's coaxial connector from its socket.
  49. iPad Pro 9.7" Logic Board Replacement, Lift the antenna cables: crwdns2935265:049crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Lift the antenna cables: crwdns2935265:049crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to lift the bundled left and right antenna cables away from the frame.
    • Be careful not to puncture the battery with the spudger.
    • The sticker bundling the antenna cables together is lightly adhered to the frame.
  50. iPad Pro 9.7" Logic Board Replacement, Remove the adhesive: crwdns2935265:050crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of tweezers to remove the adhesive that was securing the bundled antenna cables to the frame.
    • Take care not to damage the antenna cables with the sharp tips on the tweezers.
    • During reassembly, apply pre-cut adhesive to the bundled antenna cables to secure them to the frame.
  51. iPad Pro 9.7" Logic Board Replacement, Separate the antenna cables: crwdns2935265:051crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Separate the antenna cables: crwdns2935265:051crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to peel up the sticker bundling the left and right antenna cables together.
  52. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:052crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:052crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel the right antenna cable off of the sticker.
  53. iPad Pro 9.7" Logic Board Replacement, Lift up the small sticker: crwdns2935265:053crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Lift up the small sticker: crwdns2935265:053crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to lift up the small sticker near the lower right speaker securing the right antenna to the frame.
  54. iPad Pro 9.7" Logic Board Replacement, Detach the foam spacer: crwdns2935265:054crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Detach the foam spacer: crwdns2935265:054crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Detach the foam spacer: crwdns2935265:054crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger to detach the foam spacer adhered to the second right antenna sticker.
  55. iPad Pro 9.7" Logic Board Replacement, Remove the foam spacer: crwdns2935265:055crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the foam spacer from the second right antenna sticker.
  56. iPad Pro 9.7" Logic Board Replacement, Detach the large sticker: crwdns2935265:056crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Detach the large sticker: crwdns2935265:056crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to detach the large right antenna sticker between the logic board and the antenna.
  57. iPad Pro 9.7" Logic Board Replacement, Lift up the first sticker: crwdns2935265:057crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Lift up the first sticker: crwdns2935265:057crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to lift up the small sticker next to the lower right speaker securing the left antenna cable to the frame.
  58. iPad Pro 9.7" Logic Board Replacement, Detach the second sticker: crwdns2935265:058crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Detach the second sticker: crwdns2935265:058crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to detach the large left antenna cable sticker near the lower right speaker.
  59. iPad Pro 9.7" Logic Board Replacement, Lift up the third sticker: crwdns2935265:059crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Lift up the third sticker: crwdns2935265:059crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to lift the left antenna and its third sticker away from the Lightning port area of the frame.
  60. iPad Pro 9.7" Logic Board Replacement, Detach the foam spacer: crwdns2935265:060crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Detach the foam spacer: crwdns2935265:060crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Detach the foam spacer: crwdns2935265:060crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger to detach the foam spacer adhered to the fourth left antenna cable sticker.
  61. iPad Pro 9.7" Logic Board Replacement, Remove the foam spacer: crwdns2935265:061crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the foam spacer from the fourth left antenna cable sticker.
  62. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:062crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:062crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:062crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to lift up the fourth left antenna cable sticker.
  63. iPad Pro 9.7" Logic Board Replacement, Remove the left ambient light sensor's sticker: crwdns2935265:063crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of tweezers to remove the sticker covering the left ambient light sensor's ZIF connector.
    Der ZIF Stecker liegt versteckt unter der GSM/LTE Antenne.
    Bernd Löhr - crwdns2934203:0crwdne2934203:0
  64. iPad Pro 9.7" Logic Board Replacement, Unlatch the ZIF connector: crwdns2935265:064crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Unlatch the ZIF connector: crwdns2935265:064crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to flip up the locking flap on the left ambient light sensor's ZIF connector.
  65. iPad Pro 9.7" Logic Board Replacement, Disconnect the left ambient light sensor: crwdns2935265:065crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Disconnect the left ambient light sensor: crwdns2935265:065crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to grip the left ambient light sensor ribbon cable as close as possible to its contacts.
    • Pull the ribbon cable out of the ZIF connector.
  66. iPad Pro 9.7" Logic Board Replacement, Disconnect the front camera: crwdns2935265:066crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Disconnect the front camera: crwdns2935265:066crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the front camera's press connector from its socket.
    • Be careful to pry only under the edge of the connector, and not under the socket itself. If you pry under the socket, you will separate it from the circuit board.
    • To reconnect, align the connector carefully over its socket and press down with your fingertip—first at one side, then the other—until it clicks into place.
    • Do not press down on the middle until the connector is fully seated—if it's misaligned, the connector can bend, causing permanent damage.
  67. iPad Pro 9.7" Logic Board Replacement, Disconnect the coaxial connector: crwdns2935265:067crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Disconnect the coaxial connector: crwdns2935265:067crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to grip the bottom coaxial connector on the top interconnect board by its metal frame.
    • Lift straight up to disconnect the coaxial connector from the interconnect board.
    I got to this step and the connector separated from the tiny interconnect board. Is there a way to jump these cables without that board?
    John Bauldree - crwdns2934203:0crwdne2934203:0
  68. iPad Pro 9.7" Logic Board Replacement, Apply isopropyl alcohol: crwdns2935265:068crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Apply isopropyl alcohol: crwdns2935265:068crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to the edges of the top interconnect board.
    • Wait thirty seconds for the isopropyl alcohol to weaken the adhesive under the top interconnect board.
  69. iPad Pro 9.7" Logic Board Replacement, Detach the top interconnect board: crwdns2935265:069crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Detach the top interconnect board: crwdns2935265:069crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening pick to cut through the adhesive under the top interconnect board and detach it from the frame.
  70. iPad Pro 9.7" Logic Board Replacement, Disconnect the rear camera: crwdns2935265:070crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Disconnect the rear camera: crwdns2935265:070crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the rear camera's press connector from its socket.
  71. iPad Pro 9.7" Logic Board Replacement, Disconnect the power button assembly: crwdns2935265:071crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Disconnect the power button assembly: crwdns2935265:071crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the power button assembly's press connector from its socket.
  72. iPad Pro 9.7" Logic Board Replacement, Disconnect the volume buttons: crwdns2935265:072crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Disconnect the volume buttons: crwdns2935265:072crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the volume buttons' press connector from its socket.
  73. iPad Pro 9.7" Logic Board Replacement, Remove the sticker from the ZIF connectors: crwdns2935265:073crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Remove the sticker from the ZIF connectors: crwdns2935265:073crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the sticker covering the ZIF connectors near the Lightning port.
  74. iPad Pro 9.7" Logic Board Replacement, Detach the right ribbon cable: crwdns2935265:074crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Detach the right ribbon cable: crwdns2935265:074crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening pick to cut through the adhesive under the right ribbon cable next to the lower speaker (Lightning port oriented up) and detach it from the frame.
    • Be careful not to pull the ribbon cable out of the ZIF connector. Pulling the ribbon cable out while the ZIF connector locking flap is closed may damage the connection.
  75. iPad Pro 9.7" Logic Board Replacement, Detach the left ribbon cable: crwdns2935265:075crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Detach the left ribbon cable: crwdns2935265:075crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening pick to cut through the adhesive under the left ribbon cable next to the lower speaker and detach it from the frame.
  76. iPad Pro 9.7" Logic Board Replacement, Disconnect the ribbon cables: crwdns2935265:076crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Disconnect the ribbon cables: crwdns2935265:076crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to flip up the hinged locking flap on the left ribbon cable ZIF connector.
  77. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:077crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:077crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to flip up the hinged locking flap on the right ribbon cable ZIF connector.
  78. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:078crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:078crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to grip the left ribbon cable as close as possible to its contacts and pull the ribbon cable out of the ZIF connector.
  79. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:079crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:079crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to grip the right ribbon cable as close as possible to its contacts and pull the ribbon cable out of the ZIF connector.
  80. iPad Pro 9.7" Logic Board Replacement, Remove the Lightning port screws: crwdns2935265:080crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four Phillips screws securing the Lightning port:
    • Two 2.5 mm screws
    • Two 1.5 mm screws
  81. iPad Pro 9.7" Logic Board Replacement, Logic board adhesive information: crwdns2935265:081crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Logic board adhesive information: crwdns2935265:081crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This image shows the device with the logic board removed.
    • Strips of adhesive secure the logic board to the frame. In the next steps, you'll weaken and cut through the adhesive to detach the logic board from the frame.
  82. iPad Pro 9.7" Logic Board Replacement, Apply an iOpener to the rear case: crwdns2935265:082crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Apply an iOpener to the rear case: crwdns2935265:082crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Apply an iOpener to the rear case: crwdns2935265:082crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully turn the iPad over.
    • Many cables are loose at this point. Make sure no cables are bent or torn while turning the iPad over.
    • Heat an iOpener and apply it to the top, left, and bottom edges of the rear case for one minute on each edge.
  83. iPad Pro 9.7" Logic Board Replacement, Detach the Lightning port ribbon cable: crwdns2935265:083crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Detach the Lightning port ribbon cable: crwdns2935265:083crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening pick to cut through the adhesive under the Lightning port ribbon cable to detach it from the frame.
  84. iPad Pro 9.7" Logic Board Replacement, Lift up the stickers: crwdns2935265:084crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Lift up the stickers: crwdns2935265:084crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to lift up the smaller sticker to the left of the Lightning port (when the Lightning port is oriented up).
  85. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:085crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:085crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to lift up the larger sticker to the left of the Lightning port.
  86. iPad Pro 9.7" Logic Board Replacement, Pull the Lightning port out: crwdns2935265:086crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Pull the Lightning port out: crwdns2935265:086crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to grip the Lightning port by the bottom right screw hole.
    • Pull the Lightning port out of its recess.
  87. iPad Pro 9.7" Logic Board Replacement, Apply isopropyl alcohol: crwdns2935265:087crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a few drops of high-concentration isopropyl alcohol under the left edge of the upper logic board arm (Lightning port oriented down).
    • Wait thirty seconds for the isopropyl alcohol to weaken the adhesive under the upper logic board arm.
  88. iPad Pro 9.7" Logic Board Replacement, Cut through the adhesive under the upper arm: crwdns2935265:088crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Cut through the adhesive under the upper arm: crwdns2935265:088crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening pick to cut through the adhesive under the upper logic board arm and detach it from the frame.
    • The upper logic board arm is thin. Be careful not to tear it during this process.
    • It may help to grip the upper logic board arm with your fingers and peel it away from the frame.
    • Apply a few more drops of isopropyl alcohol under the logic board arm when it becomes difficult to detach from the frame.
  89. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:089crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:089crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick about 0.5 inches (13 mm) under the top edge of the larger portion of the upper logic board arm.
    • Leave the opening pick under the upper logic board arm to prevent it from re-adhering to the frame.
  90. iPad Pro 9.7" Logic Board Replacement, Apply isopropyl alcohol: crwdns2935265:090crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Apply isopropyl alcohol: crwdns2935265:090crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a few drops of high-concentration isopropyl alcohol to the right edge of the logic board.
  91. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:091crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:091crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a few drops of high-concentration isopropyl alcohol to the left edge of the logic board.
  92. iPad Pro 9.7" Logic Board Replacement, Cut through the adhesive under the logic board: crwdns2935265:092crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Cut through the adhesive under the logic board: crwdns2935265:092crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide an opening pick about 0.5 inches (13 mm) under the top of the logic board's left side to cut through the adhesive.
    • Remove the opening pick.
  93. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:093crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:093crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick about 0.5 inches (13 mm) under the logic board's left side next to the battery connector.
  94. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:094crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:094crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick about 0.5 inches (13 mm) under the logic board on the other side of the battery connector.
  95. iPad Pro 9.7" Logic Board Replacement: crwdns2935265:095crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement: crwdns2935265:095crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick about 0.5 inches (13 mm) under the bottom of the logic board's left side.
  96. iPad Pro 9.7" Logic Board Replacement, Remove the battery blocker: crwdns2935265:096crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Remove the battery blocker: crwdns2935265:096crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery blocker from the logic board.
    • During reassembly, reinsert the battery blocker after you install the logic board into the device.
  97. iPad Pro 9.7" Logic Board Replacement, Remove the opening pick: crwdns2935265:097crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Remove the opening pick: crwdns2935265:097crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the opening pick from the upper logic board arm.
  98. iPad Pro 9.7" Logic Board Replacement, Remove the logic board: crwdns2935265:098crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Remove the logic board: crwdns2935265:098crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 9.7" Logic Board Replacement, Remove the logic board: crwdns2935265:098crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the logic board from the frame.
    • If the logic board doesn't easily lift out of the frame, apply a few more drops of isopropyl alcohol to any stuck areas and use an opening pick to cut through more of the adhesive.
    • If there's any alcohol solution remaining in the device, carefully wipe it off or allow it to air dry before installing your logic board.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card to secure the logic board to the frame.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Pro 9.7" Answers community for help.
crwdns2935229:05crwdne2935229:0
Kyle Smith
crwdns2935283:002/01/21crwdne2935283:0
45 422 crwdns2915208:0crwdne2915208:0
crwdns2935297:0123crwdne2935297:0
crwdns2936753:07crwdne2936753:0 38
crwdns2936753:030crwdne2936753:0 152
crwdns2942667:0crwdne2942667:0 8,902
