iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement
  1. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Prepare your iPad for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Allow your iPad's battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged during the repair.
    • If your battery is swollen, take appropriate precautions.
    • Unplug any cables and fully shut down your iPad.
  2. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Heat the right edge: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the right edge of the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the iPad—the screen and internal battery are susceptible to heat damage.
  3. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Anti-Clamp instructions: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Anti-Clamp instructions: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Anti-Clamp instructions: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken display.
    • Apply a suction handle to the screen as close to the center of the right edge as possible.
    • Pull up on the suction handle with a strong, steady force to create a small gap between the frame and screen.
    • The large screen is very fragile. Only create a gap big enough to insert an opening pick.
    • If you're having trouble making a gap, reapply a heated iOpener to the right edge for two minutes.
    • Insert an opening pick into the gap.
    • Don't insert the pick more than 5 mm to avoid damaging the screen.
  7. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Right edge information: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Right edge information: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Right edge information: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are two 2 cm-long magnets along the right edge of the screen. Don't insert your opening pick more than 2 mm to avoid damaging the screen in these locations:
    • The first magnet begins about 3 cm from the top of the iPad.
    • The second magnet begins about 3 cm from the bottom of the iPad.
    • Everywhere else, don't insert your opening pick more than 5 mm.
  8. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Separate the right adhesive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Separate the right adhesive: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Separate the right adhesive: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide your opening pick along the right edge of the screen to separate the adhesive.
    • Angle your pick downward and insert up to a 2 mm depth near the magnet cutouts and 5 mm everywhere else.
    • Leave the pick inserted in the bottom right corner before continuing.
  9. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Separate the corner adhesive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Separate the corner adhesive: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide your opening pick around the bottom right corner of the screen to separate the adhesive.
    • Leave your pick in the bottom right corner to prevent the adhesive from resealing.
  10. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Heat the bottom edge: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the bottom edge of the screen for two minutes.
  11. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Separate the bottom adhesive: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Separate the bottom adhesive: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Separate the bottom adhesive: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a second opening pick under the bottom right corner of the screen.
    • Don't insert your opening pick more than 5 mm.
    • Slide your pick to the bottom left corner to separate the bottom adhesive.
  12. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Slice the corner adhesive: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Slice the corner adhesive: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate your opening pick around the bottom left corner of the screen.
    • Leave your pick in the bottom left corner to prevent the adhesive from resealing.
  13. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Heat the left edge: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the left edge of the screen for two minutes.
  14. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Left edge information: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Left edge information: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are four 2 cm-long cutouts along the left edge of the screen where the adhesive is very thin. Don’t insert your opening pick more than 2 mm in these locations to avoid damaging the display:
    • The upper cutouts begin at 4 cm and 6 cm from the top of the frame.
    • The bottom cutouts begin at 4 cm and 6 cm from the bottom of the frame.
  15. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Slice the left adhesive: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Slice the left adhesive: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Slice the left adhesive: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a third opening pick under the bottom left corner of the screen.
    • Slide your pick to the top left corner to slice the left adhesive, making sure to avoid the cutouts shown in the previous step.
    • Leave the pick inserted in the top left corner before continuing.
  16. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Slice the corner adhesive: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Slice the corner adhesive: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide your opening pick around the top left corner of the screen.
    • Leave your pick in the top left corner to prevent the adhesive from resealing.
  17. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Heat the top edge: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the top edge of the screen for two minutes.
  18. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Top edge information: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Top edge information: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Top edge information: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While the top edge adhesive softens, note the following:
    • There are two ambient light sensors near the corners. Don't insert your pick more than 1 mm here.
    • The front-facing camera and additional sensors are in the center of the top edge. Don't insert your pick here—there is less than 1 mm of adhesive and you may damage the components.
    • For everywhere else, don't insert your pick more than 5 mm to avoid damaging the screen.
  19. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Separate the top adhesive: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Separate the top adhesive: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide your opening pick toward the top right edge, stopping just before the camera assembly.
    • If you slide any farther, you risk damaging the camera's sensors.
    • Leave your pick inserted before continuing.
  20. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a new opening pick on the other side of the camera assembly, about 4 cm from the previous pick.
    • Slide your pick to the top right corner to slice the remaining adhesive.
  21. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Reposition the screen: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Reposition the screen: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Reposition the screen: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't fully remove the screen, as it's attached by several cables.
    • Grab two opposing corners of the screen and lift up to separate it from the frame.
    • If the screen feels stuck, slide your opening picks around the perimeter to separate any remaining adhesive. Pay attention to sensitive areas shown in previous steps.
    • Shift the screen towards the bottom right corner of the frame until the ribbon cable near the top edge is uncovered.
  22. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Unfasten the upper cable shield: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    FixMat
    $36.95
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a Phillips screwdriver to remove the two screws securing the upper cable shield:
    • One 1.8 mm-long screw
    • One 1.4 mm-long screw
    • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
  23. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Remove the upper cable shield: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Remove the upper cable shield: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or your fingers to grab and remove the upper cable shield.
  24. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Disconnect the upper sensors: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Disconnect the upper sensors: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to pry up and disconnect the upper sensors press connector.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  25. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Reposition the screen: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Reposition the screen: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Reposition the screen: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the right edge of the screen and open it like a book.
    • Don't pull up on the screen—the screen cables are still attached.
    • Lay the screen down over the left edge of the iPad.
    • Be careful not to strain the screen cables.
  26. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Remove the logic board cover: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Remove the logic board cover: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Remove the logic board cover: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The logic board cover is lightly adhered to the logic board.
    • Peel the cover off of the logic board to remove it.
  27. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Unfasten the display brackets: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the seven screws securing the top and bottom display brackets:
    • Four 1.1 mm-long screws
    • Two 2.0 mm-long screws
    • One 1.0 mm-long screw
  28. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Remove the display brackets: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Remove the display brackets: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Remove the display brackets: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers, or your fingers, to remove the top and bottom display brackets.
  29. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Disconnect the bottom display cables: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Disconnect the bottom display cables: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Disconnect the bottom display cables: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect the two bottom display cable press connectors.
  30. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Disconnect the top display cables: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Disconnect the top display cables: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Disconnect the top display cables: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect the two top display cable press connectors.
  31. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Remove the screen: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Remove the screen: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Remove the screen: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screen.
  32. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Disconnect the charging port: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Disconnect the charging port: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the charging port cable press connector.
  33. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Separate the charging port adhesive: crwdns2935265:033crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Separate the charging port adhesive: crwdns2935265:033crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Separate the charging port adhesive: crwdns2935265:033crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The charging port cable is lightly adhered to the logic board.
    • Insert an opening pick between the charging port cable and the logic board.
    • Slide the pick toward the charging port to separate the adhesive.
  34. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Unfasten the charging port: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 1.8 mm-long screws securing the charging port.
  35. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Remove the grounding clips: crwdns2935265:035crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Remove the grounding clips: crwdns2935265:035crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Remove the grounding clips: crwdns2935265:035crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to remove the two small grounding clips next to the charging port.
  36. iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Remove the charging port: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Remove the charging port: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 5th Gen USB-C Charging Port Replacement, Remove the charging port: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to pull the charging port out of its slot in the frame.
    • Remove the charging port.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 12.9" 5th Generation Answers community for help.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
168.150 crwdns2915208:0crwdne2915208:0
crwdns2935297:0769crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:020.931crwdne2935297:0
There isn't a usb-c connector in the list of what you need. Looking through the store, I can only find a usb-c connector for the iPad pro 12.9 2018/2020 model. Does that usb-c connector also work for this 5th gen?
Kyle - crwdns2934203:0crwdne2934203:0
No you need to order from Amazon
Rodolfo Aramayo - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 84
crwdns2936753:030crwdne2936753:0 457
crwdns2942667:0crwdne2942667:0 9,083
