iPad Pro 12.9" 3rd Gen Screen Replacement
  1. iPad Pro 12.9" 3rd Gen Screen Replacement, Prepare your iPad for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Allow your iPad's battery to fully drain before starting this repair. A charged battery may catch fire if damaged during the repair.
    • Unplug any cables and fully shut down your iPad.
  2. iPad Pro 12.9" 3rd Gen Screen Replacement, Heat the right edge: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the right edge of the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the iPad—the screen and internal battery are susceptible to heat damage.
  3. iPad Pro 12.9" 3rd Gen Screen Replacement, Anti-Clamp instructions: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Anti-Clamp instructions: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Anti-Clamp instructions: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backward to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. iPad Pro 12.9" 3rd Gen Screen Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Apply a suction handle to the screen as close to the center of the right edge as possible.
    • Pull up on the suction handle with a strong, steady force to create a small gap between the frame and screen.
    • The large screen is very fragile. Only create a gap big enough to insert an opening pick.
    • If you're having trouble making a gap, reapply a heated iOpener to the right edge for two minutes.
    • Insert an opening pick into the gap.
    • Don't insert the pick more than 5 mm to avoid damaging the screen.
  7. iPad Pro 12.9" 3rd Gen Screen Replacement, Right edge information: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Right edge information: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Right edge information: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are two 2 cm-long magnets along the right edge of the screen. Don't insert your opening pick more than 2 mm to avoid damaging the screen in these locations:
    • The first magnet begins about 3 cm from the top of the iPad.
    • The second magnet begins about 3 cm from the bottom of the iPad.
    • Everywhere else, don't insert your opening pick more than 5 mm.
    Every guide except one I checked including this one forgot to mention to transfer these magnets onto the the new screen/chassi.
    LunarStahr - crwdns2934203:0crwdne2934203:0
  8. iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the right adhesive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the right adhesive: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the right adhesive: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide your opening pick along the right edge of the screen to separate the adhesive.
    • Angle your pick downward and insert up to a 2 mm depth near the magnet cutouts and 5 mm everywhere else.
    • Leave the pick inserted in the bottom right corner before continuing.
  9. iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the corner adhesive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the corner adhesive: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide your opening pick around the bottom right corner of the screen to separate the adhesive.
    • Leave your pick in the bottom right corner to prevent the adhesive from resealing.
  10. iPad Pro 12.9" 3rd Gen Screen Replacement, Heat the bottom edge: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the bottom edge of the screen for two minutes.
  11. iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the bottom adhesive: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the bottom adhesive: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the bottom adhesive: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a second opening pick under the bottom right corner of the screen.
    • Don't insert your opening pick more than 5 mm.
    • Slide your pick to the bottom left corner to separate the bottom adhesive.
  12. iPad Pro 12.9" 3rd Gen Screen Replacement, Slice the corner adhesive: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Slice the corner adhesive: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate your opening pick around the bottom left corner of the screen.
    • Leave your pick in the bottom left corner to prevent the adhesive from resealing.
  13. iPad Pro 12.9" 3rd Gen Screen Replacement, Heat the left edge: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the left edge of the screen for two minutes.
  14. iPad Pro 12.9" 3rd Gen Screen Replacement, Left edge information: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Left edge information: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Left edge information: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are three cutouts along the left edge of the screen where the adhesive is very thin. Don't insert your opening pick more than 2 mm to avoid damaging the screen at these cutouts:
    • The upper cutout begins 4 cm from the top of the frame and is 3 cm long.
    • The middle cutout begins 12 cm from the top of the frame and is 3 cm long.
    • The bottom cutout is 4 cm from the bottom of the frame and is 3 cm long.
  15. iPad Pro 12.9" 3rd Gen Screen Replacement, Slice the left adhesive: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Slice the left adhesive: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Slice the left adhesive: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a third opening pick under the bottom left corner of the screen.
    • Slide your pick to the top left corner to slice the left adhesive, making sure to avoid the cutouts shown in the previous step.
    • Leave the pick inserted in the top left corner before continuing.
  16. iPad Pro 12.9" 3rd Gen Screen Replacement, Slice the corner adhesive: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Slice the corner adhesive: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide your opening pick around the top left corner of the screen.
    • Leave your pick in the top left corner to prevent the adhesive from resealing.
  17. iPad Pro 12.9" 3rd Gen Screen Replacement, Heat the top edge: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the top edge of the screen for two minutes.
  18. iPad Pro 12.9" 3rd Gen Screen Replacement, Top edge information: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Top edge information: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Top edge information: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While the top edge adhesive softens, note the following:
    • There are two ambient light sensors near the corners. Don't insert your pick more than 1 mm here.
    • The front-facing camera and additional sensors are in the center of the top edge. Don't insert your pick here—there is less than 1 mm of adhesive and you may damage the components.
    • For everywhere else, don't insert your pick more than 5 mm to avoid damaging the screen.
  19. iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the top adhesive: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the top adhesive: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide your opening pick 9 cm toward the top right edge, stopping just before the camera assembly.
    • If you slide any farther, you risk damaging the camera's sensors.
    • Leave your pick inserted before continuing.
  20. iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a new opening pick on the other side of the camera assembly, 4 cm from the previous pick.
    • Slide your pick to the top right corner to slice the remaining adhesive.
  21. iPad Pro 12.9" 3rd Gen Screen Replacement, Reposition the screen: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Reposition the screen: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Reposition the screen: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't fully remove the screen, as it's attached to the frame by several cables.
    • Grab two opposing corners of the screen and lift up to separate it from the frame.
    • If the screen feels stuck, slide your opening picks around the perimeter to separate any remaining adhesive. Pay attention to sensitive areas shown in previous steps.
    • Shift the screen towards the bottom right corner of the frame until the ribbon cable near the top edge is uncovered.
  22. iPad Pro 12.9" 3rd Gen Screen Replacement, Unfasten the upper cable shield: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    FixMat
    $36.95
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a Phillips screwdriver to remove the two screws securing the upper cable shield:
    • One 2.0 mm-long screw
    • One 1.8 mm-long screw
    • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
  23. iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the upper cable shield: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the upper cable shield: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to grab and remove the upper cable shield.
  24. iPad Pro 12.9" 3rd Gen Screen Replacement, Disconnect the upper sensors: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Disconnect the upper sensors: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to pry up and disconnect the upper sensors press connector.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  25. iPad Pro 12.9" 3rd Gen Screen Replacement, Reposition the screen: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Reposition the screen: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Reposition the screen: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the right edge of the screen and open it like a book.
    • Don't pull up on the screen—the display cables are still attached.
    • Lay the screen down over the left edge of the iPad.
    • Be careful not to strain the display cables.
  26. iPad Pro 12.9" 3rd Gen Screen Replacement, Unfasten the display cable bracket: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the five screws securing the display cable bracket:
    • Four 1.1 mm-long screws
  27. iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the display cable bracket: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the display cable bracket: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to remove the display cable bracket.
  28. iPad Pro 12.9" 3rd Gen Screen Replacement, Disconnect the top display cables: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Disconnect the top display cables: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Disconnect the top display cables: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect the two top display cable press connectors.
  29. iPad Pro 12.9" 3rd Gen Screen Replacement, Disconnect the bottom display cables: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Disconnect the bottom display cables: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Disconnect the bottom display cables: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect the two bottom display cable press connectors.
  30. iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the screen: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the screen: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the screen: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screen.
  31. iPad Pro 12.9" 3rd Gen Screen Replacement, Peel the display bracket tape: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Peel the display bracket tape: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Peel the display bracket tape: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel back the tape from the display cable bracket located at the bottom right of the screen.
    My display does not have this tape on it. The photo currently in step 30 of the removed display also does not contain the tape. The bracket we remove in step 34 is simply exposed.
    I am assuming that if the tape is not there these steps can simply be skipped and ignored.
    Tim Cosgrove - crwdns2934203:0crwdne2934203:0
    Like the other commenter, mine does not have this tape.
    Brendan T - crwdns2934203:0crwdne2934203:0
  32. iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue peeling the tape along its outer edge until the bracket is fully exposed.
  33. iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the tape.
    • Set the tape aside. You'll use it during reassembly.
  34. iPad Pro 12.9" 3rd Gen Screen Replacement, Unfasten the display cable bracket: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 1.3 mm-long screws securing the display cable bracket.
  35. iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the display cable bracket: crwdns2935265:035crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the display cable bracket.
  36. iPad Pro 12.9" 3rd Gen Screen Replacement, Peel the remaining tape: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Peel the remaining tape: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Peel the remaining tape: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off the tape connecting the display and digitizer cables.
    My iPad did not have this tape -- just leaving the comment in case others are surprised to find this missing. Also no tape on the microphone (step 44)
    Claude - crwdns2934203:0crwdne2934203:0
  37. iPad Pro 12.9" 3rd Gen Screen Replacement, Disconnect the display cable: crwdns2935265:037crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Disconnect the display cable: crwdns2935265:037crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Disconnect the display cable: crwdns2935265:037crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect the bottom display cable press connector on the screen.
    • Use tweezers to bend the bottom press connector away from the screen—exposing the top press connector.
  38. iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:038crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the top display cable press connector on the screen.
  39. iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the display cable: crwdns2935265:039crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the display cable: crwdns2935265:039crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The display cable is lightly adhered to the screen.
    • Use your fingers to peel the display cable from the screen.
    • Remove the display cable.
    • Set the cable aside. You'll use it during reassembly.
  40. iPad Pro 12.9" 3rd Gen Screen Replacement, Top sensor assembly information: crwdns2935265:040crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Top sensor assembly information: crwdns2935265:040crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The top sensor assembly is composed of four sensors:
    • Two ambient light sensors
    • One proximity sensor
    • One microphone
    • You'll need to separate each sensor from the screen before removing the entire assembly.
  41. iPad Pro 12.9" 3rd Gen Screen Replacement, Heat the top sensor assembly: crwdns2935265:041crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  42. iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the ambient light sensors: crwdns2935265:042crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the ambient light sensors: crwdns2935265:042crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert one arm of your angled tweezers between the ambient light sensor and the screen.
    • Pry up to separate the sensor from the screen.
    • This might take significant force.
    • Repeat this procedure for the other ambient light sensor.
  43. iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the proximity sensor: crwdns2935265:043crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the proximity sensor: crwdns2935265:043crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the proximity sensor: crwdns2935265:043crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be very careful during this step, as the sensor cable can tear. Work slowly and apply more heat if you encounter resistance.
    • Insert one arm of your angled tweezers between the proximity sensor cable and the screen.
    • Slide the tweezers toward the screen while prying to separate the sensor from the screen.
    • This might take significant force and multiple iOpener heating cycles.
  44. iPad Pro 12.9" 3rd Gen Screen Replacement, Peel the tape: crwdns2935265:044crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Peel the tape: crwdns2935265:044crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel off any tape covering the microphone.
  45. iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the microphone: crwdns2935265:045crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the microphone: crwdns2935265:045crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the microphone: crwdns2935265:045crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide an opening tool under the microphone to separate its adhesive.
    • Pry up to separate the microphone from the screen.
  46. iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the top sensor assembly: crwdns2935265:046crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the top sensor assembly: crwdns2935265:046crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the top sensor assembly: crwdns2935265:046crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide an opening pick under the top sensor assembly cable to separate it from the screen.
  47. iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:047crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:047crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 12.9" 3rd Gen Screen Replacement: crwdns2935265:047crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue sliding your opening pick along the top sensor assembly until it's completely separated from the screen.
    • Remove the top sensor assembly.
  48. iPad Pro 12.9" 3rd Gen Screen Replacement, Reassembly information: crwdns2935265:048crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Tesa 61395 Tape
    $5.99
    • During reassembly, perform the following:
    • Align the top sensor assembly on your replacement screen.
    • Use Tesa tape, or similar double-sided tape, to secure the cables to the screen.
    • Use E6000 adhesive, or similar adhesive, to secure the sensors to their cutouts on the screen.
    Warum ist im Set kein Kleber??? Hoffentlich geht es auch mit UHU....
    Christian - crwdns2934203:0crwdne2934203:0
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 12.9" 3rd Generation Answers community for help.
crwdns2935229:052crwdne2935229:0
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
197 526 crwdns2915208:0crwdne2915208:0
crwdns2935297:0935crwdne2935297:0
Staff
crwdns2935297:023 151crwdne2935297:0
crwdns2947412:042crwdne2947412:0
Most likely you may have damaged the flex of proximity sensor.
Check connector
Check placement with flash light make sure everything is aligned correctly
Mark D Schlossman -
why not get a new flex cable from ebay or aliexpress
imab -
What adhesive do you use to reattach their screen?
puppitkey - crwdns2934203:0crwdne2934203:0
What tool do you use to restore true tone ?
Damien Nojac - crwdns2934203:0crwdne2934203:0
I do not think there is a way without OEM Screen or serial transferring such as with iPhone X MAX screen repairs you would use
I will have to look into it when I have time for you
Mark D Schlossman - crwdns2934203:0crwdne2934203:0
I have the original screen. It’s still working, the glass is just completely shattered.
Is face id working
Mark D Schlossman -
Yes, it’s working
Damien Nojac -
Thanks couldnt find a guide for the 11 and the facial id threw me off
jimmy dixon - crwdns2934203:0crwdne2934203:0
Was working on one for the 11 but I am to busy repairing lately. But they are identical pretty
Mark D Schlossman -
Is the glass adhered to the LCD like the phones?
emholden - crwdns2934203:0crwdne2934203:0
Yes it is just like phones only on the iPad Air 2&3 and the Pro Series
Mark D Schlossman -
Mine didn’t start after screen replacement when using the power button. Was scared, but after connecting it to the charger it worked!
bartijn - crwdns2934203:0crwdne2934203:0
I forgot to turn off the power of the ipad and the LCD backlight went out. How can I fix it?
Valu - crwdns2934203:0crwdne2934203:0
It would be a board level repair you can send out for microsoldering iPad rehab can do
Mark D Schlossman -
Thanks for the great tutorial! I replaced my iPad Pro screen with no issues!
Sara - crwdns2934203:0crwdne2934203:0
Thanks for the feed back
Mark D Schlossman -
The cable that was supposed to be reused was damaged during the swap. Where can i get a replacement?
goober2432 - crwdns2934203:0crwdne2934203:0
what glue do you use to attach the face id flex to the new screen?
paul.lynch1 - crwdns2934203:0crwdne2934203:0
Hi Mark,
I have lost two screws and I am wondering what are the dimensions of all the screws in my iPad pro 12.9 3rd Gen so I can replace them? I don't want to put the wrong ones in because I have heard that's bad!
Rebecca Gray - crwdns2934203:0crwdne2934203:0
@rebeccaperth I might have a recycled ipad pro at my work I can sell you the screws email me at info@icarefargo.com
Question, if I rip the digitizer flex cable to the LCD. (The one with two pins) can you solder the flex cable back together?
Andere Edward - crwdns2934203:0crwdne2934203:0
Quick question even though it might sound stupid but could the 2021 screen work with the 2018/2020 model?
Shaun Eworh - crwdns2934203:0crwdne2934203:0
The guide doesn't show the part regarding the face ID. And it's the most sensitive one. Good guide despite that though.
Rafael Munoz - crwdns2934203:0crwdne2934203:0
Thank you for making the guide. It really helped me replace a friend's iPad Pro 12.9 4th generation cracked screen. I did it yesterday, and it only took me a whole day! 😆
jean rodriguez - crwdns2934203:0crwdne2934203:0
I broke the display cables when prying of a badly broken screen, is it possible to buy them seperately, the ones thad did not come with the new screen?
Bjarki Björgúlfsson - crwdns2934203:0crwdne2934203:0
Hi there.
Yes, we sell them! Here's the link!
Alex Diaz-Kokaisl -
My 10 year old helped with step 1. He’s a pro at draining batteries in record time. 😆
Breadman - crwdns2934203:0crwdne2934203:0
The first step in the tutorial is, "Allow your iPad's battery to fully drain before starting this repair. A charged battery may catch fire if damaged during the repair."
Ok, but that's not so simple. Is there a guide to efficiently and quickly draining the battery? Something besides app-oriented drains (like watching 6 hours of videos, turning the brightness up, etc.).
generalstuff1 - crwdns2934203:0crwdne2934203:0
Wow, this was nerve-wracking. The top 4 sensors, didn't realize they are all glued on, so pulling them off, thought I broke them. After doing my best to put it back together again (used a tiny bit of crazy glue), everything worked! Getting those tiny screws back in was difficult (mostly getting them to seat on the screwdriver). I bought the glass kit, and suggested tool kit, and clamp, but missed out on the tape (figured it was included). Also came with a sheet of outer tape, but the kit already had it assembled. So once I concluded that was the case, I just took a small strip of the new stuff and used it to "tape" down the 4 sensor array.
On the bottom left corner, I tore off a small piece of copper tape by accident. Not sure if it is functional in any way. There was another in the bottom center. Pretty much part of the black adhesive. Hopefully that doesn't create issues.
But the weirdest thing of all, my shipment literally included a single card: a king of spades. Why?!
Kris Morness - crwdns2934203:0crwdne2934203:0
Everything was fine, thanks for this good and detailed guide.
In der Anleitung fehlt lediglich, wie man die im "Repait Kit" mitgelieferten Klebestreifen anbringt - es ist zwar mehr oder weniger selbst erklärend, die Ergänzung dieser Beschreibung würde die Gesamtdokumentation perfekt abrunden.
Hinweis zur Hardware: bei meinem iPad 3rd Gen. (Wifi) fehlte der Klebestreifen (Steps 38,39, 43) - funktioniert auch ohne! :-)
Bazoo - crwdns2934203:0crwdne2934203:0
Just got my replacement screen and was able to replace it with ease because of these step by step instructions. Thank you!!
David Palmer - crwdns2934203:0crwdne2934203:0
Can I use the E6000 glue for the sensor cables during installation? I don't want to buy an entire roll of Tesa tape for that.
Ryan Hernandez - crwdns2934203:0crwdne2934203:0
I would say so. I used a clear Pattex 100% gel and it worked nicely to glue sensors to screen. It is about 1mm diameter thick glue so you can easily place it from left and right side of sensor and hold it for a while with your fingers. Then I used it to glue flex cables to screen, it’s a bit flexible too.
Liibo -
Bought an iPad Pro 12.9 3rd Gen Cellular 1TB for only 200 bucks with a broken screen and thanks to your great guide and iFixit's awesome parts I got the whole iPad for just about 400 bucks with display. Thanks again, great guide!
LR222006 - crwdns2934203:0crwdne2934203:0
I swapped the screen and now my iPad is bootlooping. Can somebody help pls?
Marco Dužević - crwdns2934203:0crwdne2934203:0
Hi, just replaced broken screen on my iPad Pro 12.9 and both FaceID and Truetone are working, thank you ifixit for supplying the good components and this guide with quality pictures showing all detailed operations.
Also I ordered it on Friday morning, it was shipped the same day from Germany and in Czechia it was delivered on Monday, very cool for a free delivery:-)
Liibo - crwdns2934203:0crwdne2934203:0
Good instructions! A few single steps were missing, but with the context of the other steps it was still possible to follow the instructions. Unfortunately, my new screen died after assembling and closing the iPad. It worked before closing it and after closing it, as well. Now it looks like something pressed too hard into the bottom of the screen from within. Very sad but I learned a lot.
Nilss - crwdns2934203:0crwdne2934203:0
Put the screen in upside down and make sure the case isn’t bent (which may have caused your crack in the first place). It should lie flat with no wobble. Grind or hammer back any dents protruding into where the glass sits. I replaced my screen TWICE because of this!
J Sinope - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 41
crwdns2936753:07crwdne2936753:0 289
crwdns2936753:030crwdne2936753:0 1,346
crwdns2942667:0crwdne2942667:0 79,858
