Follow this guide to remove or replace the battery in an iPad Air 3. You’ll need to remove the logic board in order to replace the battery—both are held in place by strong adhesive.
This guide shows step-by-step instructions for the Wi-Fi only model. The cellular model requires disconnecting the upper cellular antennas, which are not covered in this guide.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
You may need to reapply heat repeatedly throughout this process to prevent the adhesive from cooling and hardening.
Prepare an iOpener and place it on the bottom edge of the iPad's screen for about two minutes.
crwdns2935267:0crwdne2935267:0Clampy - Anti-Clamp$24.95
Place a suction cup next to the iPad's home button and press down to create a seal.
Firmly pull up on the suction cup to create a small gap between the front panel and the rear case.
Once you've opened a sufficient gap, insert an opening pick into the gap.
Slice through the adhesive under the screen by sliding the pick along the edge of the display, towards the bottom left corner.
Leave the pick in place temporarily to prevent the adhesive from re-sealing.
Apply heat to the left edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably.
If necessary, re-heat your iOpener for a few seconds or until it's a bit too hot to touch. Be careful not to overheat the iOpener, or it may burst.
Insert a second opening pick at the bottom left corner of the iPad.
Slide the second opening pick along the left side of the display to separate the adhesive underneath.
Leave the opening pick inserted near the top left corner of the iPad to prevent the adhesive from re-sealing.
Apply heat to the top edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably.
Insert a third opening pick at the top left corner of the iPad.
Use the opening pick to cut the adhesive under the top edge of the iPad by sliding it to the top right corner.
Apply heat to the final, right edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably.
Insert a fourth opening pick at the top right corner of the iPad.
Slide the opening pick down to the bottom right corner to cut the adhesive.
Slide the opening pick around the bottom right corner—pausing to apply more heat if needed—and cut the remaining adhesive on the bottom edge, but stop before you reach the home button.
Insert a fifth opening pick at the top of the iPad near (but not directly on) the front-facing camera.
Gently twist the pick to separate the display assembly from the iPad.
If needed, apply more heat and/or cut any remaining adhesive that prevents the display from separating.
Lift the display assembly from its top edge and carefully slide it up (towards the front-facing camera and headphone jack), until the screw that secures the battery power connector is revealed at the bottom.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Remove the 1.9 mm Phillips screw that secures the battery power connector.
To disconnect the battery, slide one prong of a battery blocker or the tip of an opening pick under the battery power connector to ensure the power circuit is interrupted.
Leave the battery blocker in place as you work.
Slowly lift the display from its top edge, being careful not to strain the attached ribbon cables.
Remove the two 1.3 mm Phillips screws securing the display connector cover bracket.
Remove the display connector cover bracket.
Use a spudger to disconnect the two visible display flex connectors by gently prying them straight up from their sockets.
Use your spudger to gently pry them up and disconnect them.
Use a Phillips screwdriver to remove the five screws securing the upper component bracket:
Three 1.4 mm-long screws
Two 2.4 mm-long screws
Use a spudger to push the upper component bracket towards the upper edge and off of the clips located near the rear camera.
Remove the upper component bracket.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to disconnect a logic board antenna cable by lifting up on the cable as close to the connector as possible.
Repeat for the other logic board antenna cable.
Use a pair of tweezers to lift the antenna cables away from the logic board.
Use a pair of tweezers to unwrap the tape securing the two antenna cables together.
Use a pair of tweezers to unwrap the lower tape strip securing the antenna cables together.
Separate the two antenna cables.
Use a pair of tweezers to peel the right antenna cable away from the logic board.
Fold both the left and right antenna cables out of the way.
Use a pair of tweezers to peel up the tape covering the right speaker connector.
Repeat for the left speaker connector.
Use a pair of tweezers to remove the tape from the back of both speaker connectors.
Use the flat end of a spudger to disconnect the headphone jack cable by lifting straight up on the press connector.
Repeat to disconnect the front camera and microphone assembly cables.
Use the pointed end of a spudger to disconnect the volume button cable by lifting straight up on the press connector.
Repeat to disconnect the rear camera and power button assembly cables.
Use a Phillips screwdriver to remove the 1.3 mm-long screw securing the logic board shield.
Insert the tips of a pair of tweezers into the gaps under the the logic board shield on the upper right corner.
Pry up slightly to loosen the logic board shield.
Insert the tips of a pair of tweezers into the gaps under the logic board shield on the upper left corner.
Insert the edge of an opening tool under the top edge of the logic board shield.
Pry up to loosen the shield.
Continue prying until you've loosened the entire top edge of the shield.
Grip the logic board shield with your fingers.
Slowly lift the shield up and remove it.
Use the pointed end of a spudger to disconnect the Smart Connector cable by lifting straight up on the press connector.
Use a Phillips screwdriver to remove the four screws securing the charging port to the rear case:
Two 1.7 mm-long screws
Apply a heated iOpener to the top edge of the rear case for a minute.
Insert an opening tool underneath the logic board arm near the rear camera.
Pry up the arm until you can slide in an opening pick underneath it.
Push the opening pick up towards the rear camera to slice the adhesive under the logic board arm.
Insert another opening pick underneath the logic board arm.
Slide the opening pick towards the front camera to slice the adhesive underneath the arm.
Apply a heated iOpener lengthwise down the center of the rear case to soften the logic board adhesive.
Insert an opening tool under the logic board next to the front camera.
Pry up the logic board until you can slide an opening pick underneath the logic board.
Push the opening pick underneath the logic board to slice the adhesive.
Insert another opening pick under the upper left corner of the logic board.
Slide the pick down towards the bottom of the iPad to slice the adhesive.
Slide the opening pick down the left edge of the logic board until you get near the Smart Connector cable.
Use a spudger to move the Smart Connector cable behind the opening pick.
Slide the opening pick past the Smart Connector cable and down to the antenna connectors.
Insert an opening pick under the upper right edge of the logic board.
Slide the opening pick down the right edge until you encounter the battery connector.
Remove the battery blocker.
Slide the left opening pick down the left edge to the speaker connectors.
Slowly lift the logic board up and pull the charging port out of its recess.
Cut a strip of painter's tape or masking tape to the width of the iPad.
Press the bottom edge of the tape strip onto the rear case below the upper components.
Press the top edge of the tape strip over the upper components.
Cover the lower components with a strip of tape.
Use a pair of tweezers to remove the two pieces of tape securing the battery to the lower buffer blocks.
Wear eye protection when handling and applying the adhesive remover.
Do not wear contact lenses without eye protection.
Protective gloves are included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
Pull off the black rubber stopper from your bottle of adhesive remover.
Use scissors to cut off the sealed tip of the applicator.
The red boxes show the locations of the adhesive strips that secure the battery to the rear case.
The orange box shows the location of the Smart Connector cable that runs underneath the left battery cell. Be careful not to damage this cable when you pry up the battery.
Apply a few drops of adhesive remover along the perimeter of each battery pack.
Wait for a minute to allow the adhesive remover to work.
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Insert a plastic card under the top of the left battery cell.
Slide the plastic card as far as you can under the battery to cut the adhesive.
Leave the plastic card inserted.
Insert another plastic card under the top of the right battery cell.
Remove the plastic card from under the left battery cell.
Insert it under the battery above the Smart Connector cable.
Take care not to touch the Smart Connector cable to avoid ripping it.
Use the adhesive remover and the opening cards to loosen the remaining battery adhesive strips.
crwdns2935267:0crwdne2935267:0Tesa 61395 Tape$12.99
Remove the battery.
Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all traces of adhesive residue from the rear case.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Air 3 Answers community for help.
crwdns2935229:011crwdne2935229:0
