Use this guide to replace the 3.5mm audio jack in an iPad 6 Wi-Fi.
Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage to the logic board. If you choose to complete the guide without isolating the battery, avoid using metal tools except when completely necessary (like when removing screws) to prevent shorting the battery and damaging sensitive circuit components.
            Heat an iOpener and apply it to the left edge of the device for two minutes.
            While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
            Front camera
            Antennas
            Display cables
   crwdns2935267:0crwdne2935267:0Clampy - Anti-Clamp$24.95-
            Pull the blue handle backwards to unlock the Anti-Clamp's arms.
            Place an object under your iPad so it rests level between the suction cups.
            Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
            Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
            Pull the blue handle forward to lock the arms.
            Turn the handle clockwise 360 degrees or until the cups start to stretch.
            Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
            Wait one minute to give the adhesive a chance to release and present an opening gap.
            If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
            Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
            Skip the next step.
            Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
            Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
            Insert an opening pick into the gap between the digitizer and the frame.
            Insert a second opening pick into the gap you just created.
            Slide the pick toward the bottom-left corner of the device to separate the adhesive.
            Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
            If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
            Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
            Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
            Heat an iOpener and apply it to the top edge of the device for two minutes.
            Rotate the pick around the top-left corner of the device to separate the adhesive.
            Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
            Pull the pick out until only the tip is between the digitizer and the frame.
            Slide the pick above the front camera to separate the adhesive.
            Leave the pick near the right side of the front camera before continuing.
            Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
            Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
            Heat an iOpener and apply it to the right edge of the device for two minutes.
            Rotate the pick around the top-right corner of the device to separate the adhesive.
            Insert a new opening pick and slide it to the middle of the iPad's right edge.
            Heat an iOpener and apply it to the bottom edge of the device for two minutes.
            Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
            Leave the pick in the bottom-left corner before moving to the next step.
            Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
            Slide the pick over the antenna, stopping just before the home button.
            Leave the pick to the left of the home button before continuing.
            Insert an opening pick into the gap you just created.
            Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
            Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
            Leave the pick to the right of the home button before continuing.
            Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
            Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
            While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
            Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
            Remove any tape obscuring the LCD screws.
            Remove the four Phillips #00 4.3 mm screws securing the LCD.
            Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers. There may be glue around the screw holes that needs to be cut with a knife.
            Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
            Lay the LCD on its face to allow access to the display cables.
            Remove the single 2.3 mm Phillips #000 screw securing the battery connector to the logic board.
            Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
            Leave the battery blocker in place as you work.
            Remove the three 1.4 mm Phillips #000 screws from the display cable bracket.
            Use the flat end of a spudger to gently pry the display cable bracket straight up from the logic board.
            Remove any tape covering the home button ribbon cable connector.
            Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
            Carefully pull the home button ribbon cable straight out of the ZIF connector.
            Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
            Carefully peel the home button ribbon cable up off of the adhesive holding it to the rear case.
   crwdns2935267:0crwdne2935267:0Polyimide Tape$9.99-
            Remove the front panel assembly.
            If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
            Remove the three 1.4 mm Phillips #000 screws securing the upper component cable bracket.
            Remove the upper component cable bracket.
            Use the flat end of a spudger to disconnect the front-facing camera connector from the logic board.
            Fold the front-facing camera cable out of the way.
            Lift the tape covering the headphone jack cable toward the top of the iPad to free the cable for removal.
            Use the flat end of a spudger to lift the headphone jack cable connector straight up from its socket on the logic board.
            Slide the flat end of a spudger under the headphone jack cable to free it from the adhesive securing it to the rear case.
            Continue to slide the spudger under the end of the headphone jack cable to remove the last of the adhesive.
            Remove the single 4.3 mm Phillips #000 screw from the headphone jack.
            Use the headphone jack cable to gently remove the headphone jack from its recess in the case.
crwdns2935229:05crwdne2935229:0
So is the iPad Air/ iPad 5 headphone jack flex cables compatible with the 6th gen 2018 model? That part is listed here but on the actual description on the part page, it doesn’t mention the 6th gen as compatible.
Yes, the iPad Air/iPad 5 headphone jack is compatible with the iPad 6th gen.
