Use this guide to replace the front glass and digitizer assembly on an iPad 6.
The Touch ID sensor in the Home button is paired to the logic board. In order to retain Touch ID functionality, you need to transfer the original Home button to the new front panel assembly.
Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage. If you choose to complete the guide without isolating the battery, avoid using metal tools except when completely necessary (like when removing screws) to prevent shorting the battery and damaging sensitive circuit components.
Heat an iOpener and apply it to the left edge of the device for two minutes.
While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
Front camera
Antennas
Display cables
crwdns2935267:0crwdne2935267:0Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Place an object under your iPad so it rests level between the suction cups.
Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
Pull the blue handle forward to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
Wait one minute to give the adhesive a chance to release and present an opening gap.
If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
Skip the next step.
Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
Insert an opening pick into the gap between the digitizer and the frame.
I had a screen that was lightly cracked, and when I pulled up on the glass it cracked even further and made a mess of my removal. So, I would recommend taping cracks even if you can get suction so that you don’t induce even more cracks.
I actually had a really badly cracked digitizer. Using the suction cup did nothing but shatter the digitizer more. I intentionally drove a flat head screw driver into the digitizer to reveal the recess in the body where they are showing the opening-pick. Working around the edge, the glass shattered. You still need to be careful at all of spots noted in step 2.
Do not go under the digitizer more than the 1 mm along the sides or 3-4 mm at the corners as shown in step 29 using the flat grey ring around the edge for a reference. Direct all of your tool force into the body to prevent slipping into critical parts.
The antennas at either side of the home button were the trickiest part as they were thin and slightly attached to the digitizer. I would recommend using a plastic tool for these parts if you are having to 'scrape' the glass off of the tabs of the antenna.
Insert a second opening pick into the gap you just created.
Slide the pick toward the bottom-left corner of the device to separate the adhesive.
Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
Heat an iOpener and apply it to the top edge of the device for two minutes.
Rotate the pick around the top-left corner of the device to separate the adhesive.
There is a lot of adhesive in this corner, so if the glass is very shattered here, this procedure is extremely difficult. Even when heated up and glass surface taped, the adhesive is stronger than the shattered glass. This means that attempting to move the pick below it will shatter the glass even more, rather than separate the digitizer from the adhesive.
Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
Pull the pick out until only the tip is between the digitizer and the frame.
Slide the pick above the front camera to separate the adhesive.
Leave the pick near the right side of the front camera before continuing.
Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
Heat an iOpener and apply it to the right edge of the device for two minutes.
Rotate the pick around the top-right corner of the device to separate the adhesive.
Insert a new opening pick and slide it to the middle of the iPad's right edge.
There are sensitive display/digitizer cables no less than five inches from the bottom edge of the iPad. Insert the pick further down than this, or deeper than 1mm beyond this point and you risk irreparably damaging these cables.
Three inches is much too far down this side of the iPad to use picks.
Heat an iOpener and apply it to the bottom edge of the device for two minutes.
Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
Leave the pick in the bottom-left corner before moving to the next step.
Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
Slide the pick over the antenna, stopping just before the home button.
Leave the pick to the left of the home button before continuing.
Insert an opening pick into the gap you just created.
Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
Be careful with this step. Only insert the tip, 2-3mm. I broken the touch id and home button. No replace or fix to get the touch id working again.
Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
Leave the pick to the right of the home button before continuing.
Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
While reassembling, REALLY make sure the display cables and the home button cable won't be folded / bent while closing the digitizer. I'm not exactly sure what I did, but I broke the home button and touch ID since I bent the home button cable to the point that it broke. These ribbon cables are SUPER fragile.
Remove any tape obscuring the LCD screws.
Remove the four Phillips #00 4.3 mm screws securing the LCD.
Both of the iPad 6th gen models i have seen so for (note they were cellular also) had the LCD secured with a grey silicone kind of adhesive in each corner under the screws. So you can’t just lift the LCD as you normally would after removing screws, it would break. I found you could pick at the corner closest to the rear camera easiest, slightly lift that corner and gently separate the other side next to the headphone jack. Then while supporting the LCD , lever the other end free with a up-and-down motion making slight progress each time.
I found the same thing on my 32GB wifi only ipad. Was unable to lift the screen off once I’d removed the screws so followed the instructions above and gently prized the screen up from the top left-hand screw bracket and it came away. Then moved onto the top right hand one.
One YouTube video said to dig all that glue out. I didn’t and it seems to not hurt to leave it there but you do have to break free from it.
On my iPad 6, there were small rubber tabs covering the two screws on the front camera side. I carefully held them out of place with tweezers while unscrewing the screws.
Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers. There may be glue around the screw holes that needs to be cut with a knife.
Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
Lay the LCD on its face to allow access to the display cables.
When you replace the LCD be sure to make sure it is screwed in fully. It is easy not, especially on the cornet where the digitizer cables are. The LCD is very sensitive and if you bend it then it can stop working. I was just pressing the digitized in place at the end of a repair and the screen was covered in white lines.
I have no idea of what the logic board looks like !!!
Remove the single 2.3 mm Phillips #000 screw securing the battery connector to the logic board.
Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
Leave the battery blocker in place as you work.
If you insert a regular pick without a gap then you can damage this connector and will need a new motherboard. If in doubt just insert into the left corner enough to raise it a tiny bit. Arguably, if you are not sure, then it is safer just power off and don’t power back on until everything is fully connected. A photo of how this connector looks with its cover off would really help for people that have not seen this type of battery connector before. You just need to get it to lift a tiny bit, Do not try to slide anything under the contacts….
I bumped this darn thing several times, it was twisted and skewed making me freak out but the iPad still works. I am thinking you should pull it out and put the screw back in right after the LCD is removed. Then use it again just before putting the LCD screen back in. The pick is sticking out there waitng to be be bumped.
Hi Robin,
Unfortunately, there is no easy way to pull the battery connector out of the logic board. If you try to pry this connector off, you will irreparably damage it. The easiest solution is to insert the battery blocker in-between to cut the power.
The battery isolation pick or battery blocker is an outdated way of isolating the battery, as you risk damaging the battery pins underneath the logic board.
So what is the new method?
This is my question as well. Seems like this phrase contradicts the instructions. Confusing. Any reply?
We are currently working on a better isolation procedure! In the meantime, I’ve updated the warning to hopefully clarify the issue.
Why do you need to “To reduce the risk of a short”? There does not seem to by any risk of a “short” in this process. I can see other reasons for disconnecting the battery. I am an electrical engineer so I would appreciate a professional grade answer to this question.
I’ll give it a shot!
When you remove the screw, it doesn’t disconnect the battery, as the connector uses spring contacts to touch the battery pads.
If you leave the battery connected, it leaves the logic board energized. As there are many exposed traces and SMT components on the logic board, there is a chance that you accidentally bridge a trace with a metal tool, resulting damage. In addition, the display connector contains tiny pins, and the pinout is such that if you pry the connector from an energized logic board, there is a chance that a voltage rail pin may accidentally touch something it shouldn’t, blowing out the backlight circuitry.
My battery was dead when i did the repair. Did not really need to perform this step
Take a waterproof playing card, cut out the shape of the battery blocker and slide that under. Battery blocked and pins not at risk of damage. Got that from a YouTube video made by a microsolder repair tech fixing the damage caused by jamming a blocker in between the contacts.
Thanks for the tip Melody! I’ve updated the instructions to include the playing card method.
I could not for the life of me get the playing card in there, but my iPad was turned off, so I decided to ‘risk’ a short, instead of potentially damaging the battery connectors by jamming the card in there as hard as possible. My repair went fine, no short, however I realized AFTER closing everything up that I forgot to put the battery screw back in. Really hoping this doesn’t become an issue long term, because I don’t want to pry this brand new screen off just to put the battery in.
Let us know! I wasn't able to use the screw again after removing the battery blocker. Now my iPad turns off and on every so many minutes and when it restarts it's 1% and then shows actual charge.
When you come to screw this back together, do not overestimate how little force it takes to strip the thread on this #000 screw. I did, and I now I can't screw this back down and have the problem where the iPad restarts every 3 mins 20 sec after you turn it on due to a poor connection here. I've used card to pack this out so the LCD puts a little clamping force on the terminal once you screw it back in, but it's not really enough so the iPad still suddenly restarts occasionally.
I use a small screwdriver and pry underneath that brown bracket from the top edge by the camera (with the elongated metal cover removed of course) all the way before the battery, then lift up just enough for me to unhinged the battery out of the secure post. I don't know why Apple has to go through ALL THIS just to connect the battery since there is a small screw AND ADHESIVE securing it anyway. Nonetheless the whole job (replacing the lcd screen and battery was a major pain in the neck!
Remove the three 1.4 mm Phillips #000 screws from the display cable bracket.
I believe these are also Phillips #00, not Phillips #000.
I lost a 1.4mm screw where can I buy these small screws and how big are they? 1.4mm x? flared or flat head
ferdinando.gregis@gmail.com - crwdns2934203:0crwdne2934203:0
Is this part important? It seems like I lost it.
You don't have to remove any of this when replacing the battery but doing so will make the job easier and can prevent from accidentally knocking the adjacent cables.
Use the flat end of a spudger to gently pry the display cable bracket straight up from the logic board.
Remove any tape covering the home button ribbon cable connector.
Attention attention en retirant le scotch /adhésif, de ne pas toucher la broche ZIF qui bloque la nappe !!!
Cela m'est arrivé et j'ai pu bloquer la nappe avec un gros scotch "américain" ... et cela fonctionne
Be careful when removing the tape/adhesive, not to touch the ZIF pin which locks the tablecloth !!!
This happened to me and I was able to block the tablecloth with a large piece of "American" tape ... and it works ! ouf :-)
Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
Carefully pull the home button ribbon cable straight out of the ZIF connector.
I'm confused about the home flex cable connector required for the 6th generation iPad. It was my understanding that this model required an 18 pin connector. But these excellent pictures clearly show a 14 pin connector, just like the one for the first generation iPad Air AKA the iPad 5. I know this is not the primary focus of this guide, but can anyone clarify this for me?
I did the whole repair but this part is the problem HELP !!! I unlocked it but it took me 1 hour to carefully pull out the HOME BUTTON RIBBON CABLE. It finally came out with tweezers but now I CAN'T GET IT BACK IN and as a result my touch I.D. won't activate. It seems there was a tiny bit of black tape overlapping the connector on the ribbon which I carefully cut off exposing only the connector on the ribbon itself but how the heck does it slide in before you lock it. It seems easy on Youtube videos but mine just doesn't slide in with hand or with tweezers. OR in fact is there another connector that controls the TOUCH I.D. ???
Failed this step- broke the connector. If I try this again, I'd be inclined try to remove the home button from the front panel without unplugging it. Everything else seems to work fine.
I too failed this step. Needed some up close pics of how this works. Now what do I do the connector on the board is broken?
Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
Where can I get a good used motherboard for a A1954 iPad 6 gen everywhere I look, there sold out ?...
Carefully peel the home button ribbon cable up off of the adhesive holding it to the rear case.
If you can make sure to not pull on the home button side, i would leave out this step. i replaced two displays so far, on the first i removed it, but left it connected on the second attempt. worked like a charm
crwdns2935267:0crwdne2935267:0Polyimide Tape$9.99
Remove the front panel assembly.
If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
Gently begin peeling the home button cable off the back of the front panel.
Continue peeling until you reach the metal shield on the cable.
START using extreme caution at this point. This ribbon IS VERY FRAGILE, especially after the silver rectangle/shield. That gold piece is attached to the cable.
Insert an opening pick between the metal shield and the front panel and gently pry it from the digitizer.
I lifted the metal shield from the outside edge so not to tear the ribbon cable. I think I even used the razor blade (the tool of last resort).
Gently peel the metal contact from the home button bracket.
I ripped the ribbon cable out of the button at this step… be extremely gentle!
So what exactly does this metal contact do? Can the HB work without that single gold contact?
Can anyone answer this question? The gold metal rectangle contact ripped off even horizontally with the rest of the home button cable. Do I need to order a whole new home button with cable? Or will I at least get functionality from the home button, only missing that little gold rectangle ?
PC Ops -
I ripped mine. Reattached the metal contact to the cable with some tape as best as I could. The button and touch ID work, so not sure if the metal contact is absolutely needed…? If it’s just for grounding?
Thank you for showing the bracket up close!
EXTREME CAUTION!!! The little metal contact is very fragile. I ripped mine off. Well, when I say ripped I mean I breathed on it.
I would suggest maybe warming that part up before pulling and don’t just pull up from the main ribbon. Work it slowly.
CAUTION!!! that little gold contact got me too!! Please update the instructions to include this.
Did you find out if the home button still works without the rectangular gold contact?
PC Ops -
I wish I didn’t peel this last piece off, I don’t think you need to. It seems to be what keeps the bracket lined up over the button. Now I have to try to glue it back on perfectly so the bracket is centered over the home button.
Use a plastic opening tool to pry the home button bracket off the back of the front panel.
Once you've separated one side of the home button bracket, firmly grasp the bracket and peel it off the front panel.
I'd recommend using something stronger than double sided tape. I completed this whole repair without too much lasting trouble, but the biggest issue was I didn’t get the home bracket secured firmly enough. A few weeks after the repair, the home button got pressed in and lodged under the hole cut for it, so I can’t unlock my iPad at all (the home button can’t be “pressed” in its current state). So I’m ordering a second screen and have to go through everything again. This time I’m using super glue to get that thing welded on there. If anything breaks in the future, I’m just getting a new iPad.
I had this problem too. Very frustrating. Not sure what I’d do to fix this. If you are repairing this for someone else, then super glue would not be the best option.
I don’t see why iFixit does not simply sell an optional iPad screen with a new home button pre-installed - other competing companies do it, and with iFixit’s pro reputation, having a pre-installed option would certainly be an excellent sales option. My 2¢ worth.
The home button that came with your iPad is the only one that will allow touchID to function. This is why this must be migrated from the old to the new screen. Of course, if your iPad does not have touchID, this is not a concern.
Robert -
TIP FOR HOME BUTTON REMOVAL
I found it to be simpler by using the same pry tool shown in the image and pry the tab furthest from the flex cable. Its an easy start knowing that if you damage the cable you can loose Touch ID permanently.
My steps were basically as follows in this specific order:
1. Using a guitar pick, release the cable from the adhesive and SLOWLY lift up the cable and the components with it
2. Once you reach the tabs that hold the home button in place, pry the tab furthest from the flex cable (this requires a little more force)
3. Once the tab furthest from the home button is lifted away, you can hold on to the metal piece (The whole tab) and lift it away safely.
4. Using your finger, press in the home button to release it from the glass and your done.
After replacement m home button works fine, but it’s very loose in the housing. I can tip it around by moving my fingers to the edges. Any ideas what I did wrong?
I had to use far more pressure to remove the bracket than I was comfortable with and when it came loose it went flying. Re-attaching is easy, but I used some hobby glue to secure it in place, so if the screen breaks again, that part is NOT coming off again. I’m guessing because I did this I don’t have the “depressed” issues that others have described, it seems to be like new at this point.
I agree, the bracket needs glueing when refitting. Replaced the glass on my iPad and after a couple of days the home button came loose and stopped working. Now i just broke the glass when opening the iPad to fix the home button bracket. I love my life! :-)
I used a piece of the rectangular section of an adhesive strip cut to the exact size of the home button bracket feet to reattach it to the digitizer for reassembly. It is very strong and worked better than double sided tape or glue.
agree. I did same. Also do not forget to remove protective film from the inner side of the new digitizer. Do it before you start reassembly.
Press the home button from the external side of the digitizer to break up the adhesive holding it in place.
Are these last several steps necessary in just replacing the front glass panel that is cracked? my ipad is a wi-fi only
Yes, even if you’re only replacing the front glass panel, you still have to transfer your original home button from the old panel to the replacement. Even if the new panel comes with a new home button, Touch ID will only work with the original home button.
Buy an extra home button adhesive gasket. The adhesive from the original will not be reusable
I second this advice. I skipped it the first time, and the home button was too wiggly (although it worked). Now that I’ve replaced the screen a 2nd time (ugh), this time adding a new gasket, it’s a bit more firm, but still more wiggly than originally. If you don’t mind the button being lose, you probably can reuse the gasket, but if I have to do this again, I’ll probably get another gasket.
Yep, tore mine even as delicate as could be. I would highly recommend hitting the home button with a heat gun prior to attempting to remove. On the plus side, the replacement gaskets are cheap and easy enough to replace.
Notice the sharp crease in the ribbon cable near the home button? I thought I bent it at some point but it was already there.
My screen was damaged in such a way that removing the old gasket didn't tell me how to install the new one.
I completed the reassembly of my digitizer. the process was pretty simple. After reviewing all the feedback and issues mentioned by others, I made sure to properly attach the home button/touch ID to my new screen by carefully installing it and ensuring the gasket was firmly in place. I used a small amount of liquid glue to secure the bracket as well. While everything is working correctly, I did notice that my repair kit came with a new bracket and home button gasket (with adhesive on the parts I used glue- I assume) lol. I clearly didn't utilize that… do you think I’ll be okay? I just hope I won't need to redo the whole process again just for the home button. 🤦🏻♀️ I don’t know how I missed that little baggie…
Remove the home button assembly.
Nicely done!
Be very careful !!!!
I did a screen replacement and it’s impossible to place the home button bracket in the correct position, now the home button doesn’t click anymore. Works, but you have to press harder.
Given the delicacy of this stage, I believe it behooves iFixit to offer a panel replacement option with a new Home button pre-installed.
Others do; with iFixit’s reputation, such a purchase option would be a welcome, stellar addition to its inventory. Yes, you would have to cancel your Touch-ID setting prior to repair, but that’s a small inconvenience to having to negotiate such a procedure. My 2¢ worth.
Thanks, iFixit, for the excellent instructions
I second this - tore the home button cable during disassembly and ordered another home button assembly just to figure out that I need the gasket and holder as well as it was not included. -
Yes - the metal contact on the home button tore… now I have to figure out how to do another repair. Also, my replacement screen comes with plastic on both sides and multiple tabs in different colors. Now I’m too scared to remove those for fear of ripping something.. you should have glass replace directions here too.
Hi sir
Iam try replace ditigizer on iPad 6th gen
Will my home button and finger print if I replace the home to another the home button will if I buy it from you guys
replaced the display with new home button assembly, new gasket, and holder - button works but fingerprint sensor not anymore - It would be great to have detailed instructions for the complete the home button assembly with all the different parts, not only the teardown for reference. - i.e. it seems you need to push the button through the gasket before assembly so the cable leaves inside and the order is glass-button-gasket-holder.
The article explicitly states that the Home Button and the Motherboard are a BONDED PAIR. If you replace one without the other, Touch ID will stop working. This is why the instruction say you have to retain the button.
While I’m a fairly tech savvy person, telling people to reverse the steps is ridiculous—you need to show people what to expect. Second, include the home button on the new screen sale. I’m in the middle of the repair at this point, I’ve given you $100 and this seriously frustrating, especially when the home button you sell (which I had to buy after the screen, because I inadvertently tore off a bit) DOESN”T include the proper adhesive. PS—trying to get the adhesive on the new button is a practice in torture.
Now the adhesive ring in on the old glass and rips apart if you pull it off. I think you don’t need the adhesive ring but it keeps the button splash proof. I am going to use tiny amounts of glue but all the more reason to buy a new assy just for that ring.
I had to notch out the glass adhesive just slightly where bottom right corner of the home button bracket sits against it. It is curved and needed to be squared off to match the bracket. I held the ribbon cable, button and bracket in place with tape before I glued the bracket. I also used a flashlight behind the bracket and button gap to see that the bump on the bracket was lined up with the button’s switch.
I'm quite disappointed the fact that this is a replacement guide but does not include re-assembly steps.
We ordered a new home button and gasket for an iPad 5, which works with the iPad 6 home button as well.
Neither guide has re-assembly instructions for the home button.
My customer service is important and I would like to see better guides that include disassembly and reassembly steps.
I need to know how to properly apply a home button gasket to the home button.
If I am missing something, please let me know.
PS. It's not good practice to use metal tools so close to the main board. An insolated pair would be more ideal.
The small black dot on the home button microswitch comes off no matter how careful you are. Home button will not work properly if you loose the black dot. I have done 5-6 repairs and on 4 of them the black dot just fell off. I have been successful using a small piece of Kapton tape and reinstalling the black dot in the center of the home button microswitch.
I also removed a metal ring that sits between the gasket and the glass. It has the same shape of the gasket, and it’s glued to the glass after removing the home button assembly. Used a thin double-sided tape with strong glue when reassembling; maybe B7000 glue would be easier.
It's so frustrating seeing these guides that just say “follow these steps in the reverse order" when I'm really searching for a technique and guidance on replacing the rubber gasket and and proper placement of the bracket so it clicks as it should and doesn't sink in.
Agree with previous comments. Would be helpful to go over replacing the button gasket, and the actual reassembly instead of just ‘reverse order’.
it would be nice to see how to re assemble when to pull backing off glue, how to add grommet, how to bend new wires in place to seat correctly
Would I be able to use the new replacement home button as to go back to home page? Or is it just going to he for the decoration?
I needed 6 hours for
1) removing the cracked display glass with a scalpell,
2) to remove the glue with glue remover,
3) to install a new home button (because I cutted the homebutten flex-cable) and
4) to glue the touchdisplay (digitizer) with T7000 diplay glue!!!. The delivered glueband on the digitizer shouldn't be used, because it is to weak.
There is a HowTo missing to install a new home button. I also didn't found a new homebutton from iFixit. So I had to buy it somewere else.
crwdns2935229:0194crwdne2935229:0
crwdns2947412:048crwdne2947412:0
does the front panel of the ipad5 fit here?
The display connectors on the iPad 5 and iPad 6 are at different angles and not directly compatible with each other. We have not yet tried to force the connectors from an iPad 6 display onto an iPad 5 and vice versa to see what happened.
Thank you for providing the walk-through. I was able to follow it and complete the repair without issue.
Hi ,
thank you very much for this howto.
i have one issue when I replaced the digitizer.
Everything is working fine but as soon as I put on the glass to the body I can hear some „brrrrrr“-Sound when i put my ear on the upper side towards the camera.
Maybe some contact issue with ground ?
Do anybody know what this could be or what i can double check?
thank you very much!
Will the ipad 6th gen still work with the apple pen after replacing the assembly?
The Apple pen should still work with a replacement assembly.
My biggest comment would be to double check the iPad glass to ensure there isn’t a backing film on it. I got mine all assembled to find out that there was a near invisible film on the inside of mine. Also it is important to note the importance of not touching the LCD screen and to use something like a camera lens cleaner/blower to touch this up right before you seal the iPad up. The packing tape/duct tape trick didn’t do much for me and pretty much made the suction cup unusable. Other than that, you had a very great guide! Thanks for the help!
We did our first iPad 6 repair at our shop. Went without a hitch. Helpful to check these out and know where all the cables are routed and such ahead of time. If only they came in with digitizers that just didn’t work instead of completely shattered ones! What a mess!
Does the ipad air 2 front panel fit here?
Thanks for the guide. I was able to replace my wife’s shattered digitizer on her iPad 6th gen!
I tried using the heat pad that came with the tool kit. It was taking to long to heat the adhesive. So I got out my heat gun. That worked much better. The directions were very helpful.
Thanks..
The walkthrough was great, just wish there was an ending to walk through the reassembly. I was able to figure it out by back tracking the original instructions and had no issues. But would have been nice to have some straight forward steps. Thank you again!
Yes! I made it, probably one of the hardest renovations but this walk-through helped a lot!
Great guide. Thanks. Plan on spending a lot more time if your screen is shattered - took me many hours just to remove all the little shards. Covering it with packing tape definitely helped. It took a lot of reheating the iOpener (and I frequently reheated it at 15 seconds every few minutes without any problems).
My iOpener was not strong enough to open the screen but after reading about people using heatguns (which I had one lying around) I was able to open the case. - My screen was severely cracked which did not allow for a smooth working on the edges. - I finally got the screen off but damaged the home-button cable in the process - ordered a new one so repair is on hold until part arrives.
Has anyone had an issue with sections of the screen not responding to touch? I replaced the glass and everything seems to be working in terms of turning off and on; home button is fine; and most of the screen is functioning normally. But there are two bands that run through the screen (horizontally) where the touch screen won’t work. They just stay blank when you try and draw using an app. I haven’t been able to see anyone else having this issue and I’m not sure where/how to address it
Hi Adriane,
I think the dead bands are the result of the screen digitizer touching something conductive and shorting. Try this step and seeing if that helps.
the two long black strips with adhesive that touch the digitzer’s connection cables to the copper border of the digitizer needs to be stretched out to completely cover the portion of the digitizer that it is meant to cover. If you can see any exposed wire marking from this area you need to pull it out further to cover them.
I also found the iOpener ineffective: the aluminium frame of the iPad conducts the heat away too quickly.
Mine had super-strong adhesive. I used a larger-than-regulation suction cup, and when I pulled hard enough to separate the warmed-with-a-heat-gun adhesive, the digitiser shattered.
At this point I would have been better off, I think, abandoning the guide and just tearing off the digitiser in shards, working from the center outwards, and keeping just enough at the right edge to hinge up at step 30. By following the guide, I let sugar-grain sized shards onto the LCD, and wherever I slid a pick across them, I scratched the LCD. Once you get to an edge of the shattered digitiser, the adhesive tape is strong enough to pull up with pliers, with the glass shattering as you go.
Step 34: “There may be glue around the screw holes” — Hold your knife vertically. It’s all 4 screws, not just the top 2. In all cases, you need to cut 90 degrees or so worth of glue, on the sides of the screw closest to the edge of the iPad.
Completed after 10-15 reassemblies. I’d not have done it again. Problems I had include: 1. Ghosting. 2. Home button lose twice. 3. Home button failure. 4. Screen not setting properly. Advice A. Get the following: A1. Tape 3M for attaching screen properly, A2. Non conducting tape apply all copper sides on the digitalizer, I used a utility knife and a plastic ruler to cut it to size after applying. A3. Get the jewelry glue and secure home button bracket or reinforce, it will come lose easily.
I FIXED IT!!! But in all seriousness, the directions do need some modifications. Removing the home button cable—proceed with EXTREME CAUTION. And there needs to be some guidance (not 40+ steps) for going back and replacing the home button and the screen. I seriously felt like I was hung out to dry at that point.
I did NOT FixIt. I tried. I really tried. I managed to get a VERY cracked screen taken apart. But the reassembly should be better than, “Drop that baby in reverse!” I did get it back together and it looks clean and neat but it doesn’t work. The home button works but the digitizer itself does not allow input. I can’t input password nor can I shut off and restart. I took it apart again and made sure everything was connected and all the plastic peel offs were removed and still nothing. Very frustrating.
I should add that the guide and comments are excellent for disassembly.
Hi Aaron,
It is indeed terrible feeling when the repair does not go as planned. Does the screen work and light up? I would suggest looking carefully at the two digitizer connectors and their cables shown in this step. Even slight amounts of dirt/grease can cause problems. You may also have a short on the digitizer edge. Look over the perimeter shown in this step and make sure nothing is exposed.
That was crap. I want my money back. Taking apart the screen/home button’ was fine, but the lack of instructions for reinstalling the screen, caused me to crack the new screen due to the ribbon not sitting flush when closing it back up. Following the steps in reverse is grossly inadequate for this repair.
Hi James,
I’m sorry to hear of your experience! I’ll add an additional note in the step to look out for the connector. If you bought the part from us, please contact our customer support and we will work something out!
The guide is very complete and I was able to change the digitizer of the ipad. Only a couple of comments, first, the iopener did not help me, it cost me a lot to loosen the glue and I lost a lot of time, in the end I ended up using a hair dryer, it was more effective and practical. On the other hand, a part would be missing explaining how to start working with the new part, in my case with so much adhesive film I did not know where to start and I had to look for other videos on YouTube to know what to do.
After front panel removal (which is the hardest step…because a broken panel…is borken in thousands pieces and can’t be removed as easily as shown in this tutorial) all steps are really easy and clearly explained. Thank you for this tutorial which saved my iPad.
It is important also to take time to clean screen surface before closing / gluing front panel. I forgot this obvious step and dust is stucked between the two layers.
I purchased some very thin plastic credit card size pieces and trimmed them down to use for the shield from the logic board to battery.
This may work better for others as well, I used to use the trimmed guitar pic until a piece broke off and lodged under the logic board.
This turned an hour screen replacement into a 2 hour tear down and it increased the chances blowing fuses, ect.
Thank you for the valuable guide.
Paul
Of course, my screen break would be on that top-left-hand corner. Thankfully with some extra prying, I was able to get the left edge pried up and the glued-down glass dust pulled out without too much blood loss. The replacement screen had some weird insulating film on the flex cables and its own home button, but after removing all that and swapping in the old button, it slapped back together without any hassle!
My own retrospective thoughts - having recently pulled apart my old Samsung Galaxy S7 to do a motherboard swap and battery replacement, I thought I knew what to expect. This bad boy was NOT as simple or straightforward as all that. It’s a very good thing I followed EVERY WORD of this tutorial (including taking the extra care around the charging port, going off the left-hand edge first, working on opposite sides of the camera, investing in the microwavable heating pad and extra picks and tools…).
Hi my iPad 6th gen touchscreen has stopped working, I have done a factory reset, held power button and home button down and nothing has worked.the iPad starts up, home and volume buttons work, but not the touchscreen. If I replace the screen, and the digitiser will this solve the problem?
Unfortunately, I could not fix my Ipad 6. The heating pad took more like 10 minutes to soften the glue on the screen edges, not 1 minute, so it is a slow process. Using the razor blade to get things started worked very well. I then switched to the plastic tips. After removing the screen, I simply tightened the screws to the charging port, but after replacing the screen, the touchscreen no longer worked. It would be nice to have a video showing how to replace the adhesive strips and the screen. Since I had to guess, I assume I did something wrong for the touchscreen not to work. The tools are nice. I did use them successfully for a screen replacement on an HP laptop.
I placed the new button on the new screen but I not able to make it click how it should. What should I do?
Hi David!
The home button presses against the home button bracket in order to click. If your home button isn’t clicking, it may be that the bracket is slightly misaligned. Check the bracket alignment and try again. Another potential issue is that the adhesive you used to reattach the bracket is too thick and it’s bumping the bracket out of reach of the back of the button.
Why don’t you have the iPad 6 digitizer for sale in Australia?
Step44:
Does anyone have a tip for me how to get the touchscreen cables onto the front glass so that when I close it the full touch is still working? Because it seems to have an issue with the aluminium part that's a bit longer when I close the glass onto the tablet, and half the touch stops working.
Thank you!
The Guide is perfect, but i had some dificulty in the part of taking out the old front panel assembly. I don't know if it was because of the IOpener not heating enough, or the fact that the screen suction cup, didn't had enough grip, In the end i just destroy the front panel assembly carefully to not damage anything important, and clean the little screen parts that spread everywhere. Now that i instaled the new front Panel assembly, everything works fine, just the glue that hold the screen in th right bottom corner, sometimes just unglue it self, and the screen gets a bit outside of the case, but for that i solved by using a full cover case (with screen protector) .
Today I fixed the IPad6 front panel of my daughter successful. That was really hard as the glass was totally shattered! It took more than two hours to get rid of all glass item. Even the home button is working but I have a problem mounting the new front panel on the frame. On the right side where the data cable goes into the Ipad the Front glass still comes up. The tape isn't enought or the is some cable tension. Do you have some idea?
Thx.
Be careful with the protecting films - on both sides of the digitizer - and ribbon cable. You can use a hair dryer instead of a heat gun or iOpener.
I forget to remove the digitizer's ribbon cable-protecting sticker. It would be nice to have a brief instruction about the assembly.
sorry I'm repairing ipad 6 at step 45 of the guide you see a foamy adhesive in the red boxes I would like to know what type it is and where I can find it
thx
My screen was shattered in such a way that removing all of it was a huge project. Transferring the home button needed a little more direction than to put it back together the way it came apart. In the end I broke the connector so the home button doesn't work but everything else seems fine.
Hi, I have followed all the instructions in this guide with the correct iFixit tool and new digitizer and the IPad won't turn on or charge. I have tried recovery mode and left it to charge for a while. I didn't have any trouble with any of the steps, I used the battery blocker and the new digitizer fits perfectly with the home button. So everything has gone to plan - except that it won't turn on. Any recommendations on troubleshooting here?
I took it apart and put it back together again and it works now. Thanks so much for this guide!
Thank you!!! Repair worked perfectly, you guys rock! #righttorepair
I had dropped the iPad and cracked the glass, so I hoped this was a viable path to fixing my iPad. Instructions are good - key is to heat the iOpener and ensure the adhesive is soft - with an 1000 W microwave, it needed 2 x 30 sec to really warm up. I was able to follow the instruction but the digitizer had dead spots so the it was not possible to use the keyboard. I thought it might be dirt between the glass and the LED, or possibly a loose connection so purchased fresh adhesive tape, removed the glass again, reset the connection and carefully cleaned both the LED and the screens before reassembly. Dead spots remained, but fewer and in different locations (!). After a couple of days, the LED has died. Lesson is - don't drop the iPad.
i was able to replace the screen, eventually. I used a spare part bought on Amazon (which came w/o any instruction) and the reassembling was quite challenging. I'm pretty sure that I improvised here and there, but the result paid back.
I can confirm that the most difficult part is removing the screen. Mine was broken in a thousend shards, and although the tape trick helped keeping the pieces together, the suckers could not adhere properly on the tape. Using a dozen picks (more! luckily, I play guitar and bass, so I'm never short of picks) and an air drier, after 1 hour i could remove the broken screen.
