Follow this guide to replace the head strap clip on a Valve Index VR headset.
Power off and unplug your Index before you begin your repair.
Insert the flat end of a spudger in between the bottom of the head strap clip and the head strap padding.
Pry up on the head strap clip until it is unclipped from the head strap.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
crwdns2947412:07crwdne2947412:0
Why are these clips so expensive? At $39.99 it's like someone mashed an extra 9 when putting in the price, the face gasket which is much larger, uses more material and is more robust costs less than half, even the power adapters are $5 cheaper.
Seems that the price has been corrected to $4.99
Dor -
Yeah. The price is seriously insane! Two smaller zipties fit through that opening just fine and cost me pennies and work better than that cheap plastic clip.
Maybe i might have a older verison of the index because the larger clip piece on the top doesnt even clip in
scratch that you need to put the SMALLER side in last which is was this post doesnt say :)
Don't bother buying a clip, just buy some zipties. I bought 2 clips and they both only lasted 2 weeks. The plastic they use is to weak for long term use.
Are these things ever in stock? I've been waiting for them to be in stock fort weeks. I can't imagine that too many people need them so why are they always sold out?
Do you sell replacement clips?
TomCatT - crwdns2934203:0crwdne2934203:0
I didn't really see the need to unclip this or do the next step so I skipped it. It seems easy enough to unplug the cable while it's still attached to these, so unless you're really concerned about the cable bending a little more than it already does it seems unnecessary.
Stephen Smith - crwdns2934203:0crwdne2934203:0
(above comment is meant for the eye tube replacement guide, since the steps appear to be shared between guides)
Stephen Smith -
