Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement
  1. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
  2. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Heat the right edge: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  3. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Adhesive information: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Adhesive information: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While you wait for the adhesive to soften, note the following:
    • There's adhesive securing the back cover around the perimeter of the frame.
    • The adhesive is strongest in the bottom right and top left corners.
  4. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Insert an opening pick: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Insert an opening pick: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Insert an opening pick: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  5. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the right adhesive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the right adhesive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the right adhesive: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick back and forth along the right edge to separate the adhesive.
    • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
  6. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Heat the bottom edge: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  7. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a second opening pick at the bottom right corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom right corner.
    • Be careful while working around the corners, as the glass is very fragile here. Work slowly to avoid cracking the glass.
  8. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the bottom adhesive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the bottom adhesive: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide your opening pick to the bottom left corner to separate the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  9. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Heat the left edge: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  10. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a third opening pick at the bottom left corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom left corner.
  11. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the left adhesive: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the left adhesive: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the left adhesive: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide your opening pick along the left edge to separate the adhesive, stopping when you reach the power button.
    • Only insert the pick up to 5 mm, as you may damage the antenna flex cable or the power button cable.
    • Leave the pick in the left edge to prevent the adhesive from resealing.
  12. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Heat the top edge: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  13. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick in the gap at the top right edge.
    • Angle the pick upward to match the curved edge and rotate it around the top right corner.
  14. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the top adhesive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the top adhesive: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the pick to the top left corner to separate the adhesive.
    • Only insert the pick up to 4 mm, as you may damage the cameras or sensors.
    • Leave the pick in to prevent the adhesive from resealing.
  15. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick in the gap at the top left edge.
    • Only insert the pick up to 4 mm, as you may damage the cameras.
    • Angle the pick upward to match the curved edge and rotate it around the top left corner.
  16. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the remaining adhesive: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the remaining adhesive: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the pick toward the bottom camera to separate through the remaining adhesive, stopping before you reach the power button.
  17. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the back cover: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the back cover: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the back cover: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  18. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the NFC antenna and charging coil: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the NFC antenna and charging coil: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the NFC antenna and charging coil: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger to pry up and disconnect the NFC antenna press connector from the motherboard.
    • Repeat for the wireless charging coil press connector.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  19. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the coil adhesive: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the coil adhesive: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the coil adhesive: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The wireless charging coil is lightly adhered to the battery.
    • Insert an opening pick between the right edge of the wireless charging coil and the battery.
    • Slide the pick along the right edge to separate the adhesive.
  20. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick between the top edge of the wireless charging coil and the frame.
    • Slide the pick toward the right edge to separate the remaining adhesive.
  21. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Unfasten the NFC antenna and charging coil: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the five 3.5 mm-long screws securing the NFC antenna and charging coil.
  22. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Unfasten the loudspeaker: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the six 3.5 mm screws securing the loudspeaker.
  23. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Unclip the loudspeaker: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Unclip the loudspeaker: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the pointed end of your spudger between the upper right corner of the loudspeaker and the frame.
    • Pry up to unclip the loudspeaker from the frame.
    • Don't pry against the battery. Use protrusions in the frame for leverage.
    • During reassembly, press around the perimeter of the loudspeaker to clip it to the frame.
  24. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the charging coil and loudspeaker assembly: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the charging coil and loudspeaker assembly: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the charging coil and loudspeaker assembly: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab and remove the NFC, wireless charging coil, and loudspeaker from the frame.
  25. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the battery: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the battery: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your spudger to pry up and disconnect the battery press connector.
  26. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the interconnect cables: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the interconnect cables: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the interconnect cables: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your spudger to pry up and disconnect the secondary interconnect cable press connector from the motherboard.
    • Repeat for the primary interconnect cable.
  27. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your spudger to pry up and disconnect the secondary interconnect cable press connector from the charging board.
  28. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the interconnect cables: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the interconnect cables: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab and remove the interconnect cables from the frame.
  29. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Unfasten the charging board: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the three 3.5 mm-long screws securing the charging board.
  30. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the charging board: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the charging board: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the charging board: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of your spudger under the top right of the charging board.
    • Pry the charging board up from its recess until you can grab it with your fingers.
    • Pull the charging board toward the top of the device to remove it from its recess.
    • During reassembly, reinsert the charging board at a downward angle to guide the USB-C port into its recess.
    The charging board cannot be removed until the SIM card tray is removed. I did not see this mentioned anywhere. Trying to remove the charging board first risks damage to the board.
    David Amos - crwdns2934203:0crwdne2934203:0
    literally Step 2...
    Alexander -
  31. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the earpiece speaker: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the earpiece speaker: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of your spudger to pry up and disconnect the earpiece speaker press connector.
  32. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Unfasten the motherboard cover: crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the five 3.5 mm-long screws securing the motherboard cover.
  33. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the motherboard cover: crwdns2935265:033crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the motherboard cover: crwdns2935265:033crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the motherboard cover: crwdns2935265:033crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of your spudger between the bottom right corner of the motherboard cover and the frame.
    • Pry up on the cover to unclip it from the frame.
    • Remove the motherboard cover.
    • During reassembly, press down on the cover to secure its clips to the frame.
  34. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the front-facing camera: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the front-facing camera: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of your spudger to pry up and disconnect the front-facing camera press connector.
  35. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the fingerprint reader: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the fingerprint reader: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your spudger to pry up and disconnect the fingerprint reader press connector.
  36. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the screen: crwdns2935265:036crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the screen: crwdns2935265:036crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of your spudger to pry up and disconnect the screen press connector from the motherboard.
  37. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of your spudger to pry up and disconnect the screen press connector from the display cutout near the bottom of the phone.
  38. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the screen cable: crwdns2935265:038crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab and remove the screen cable from the frame.
  39. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the right 5G mmWave antenna: crwdns2935265:039crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the right 5G mmWave antenna: crwdns2935265:039crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of your spudger to pry up and disconnect the right 5G mmWave antenna press connector.
  40. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the stylus: crwdns2935265:040crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the stylus: crwdns2935265:040crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of your spudger to pry up and disconnect the stylus press connector.
  41. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the left 5G mmWave antenna: crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the left 5G mmWave antenna: crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of your spudger to pry up and disconnect the left 5G mmWave antenna press connector.
  42. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Unfasten the motherboard: crwdns2935265:042crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips screwdriver to remove the single 4 mm-long screw securing the motherboard.
  43. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the motherboard: crwdns2935265:043crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the motherboard: crwdns2935265:043crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the motherboard: crwdns2935265:043crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of your spudger between the top left of the motherboard and the frame.
    • Pry the motherboard up until you can grab it with your fingers.
    • Grab the motherboard and remove it from the frame.
    • Be careful not to snag any loose cables.
    • During reassembly, make sure the cables are above the motherboard when reinserting it.
  44. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Heat the front-facing camera: crwdns2935265:044crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the top of the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display is susceptible to heat damage.
  45. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Pry the front-facing camera: crwdns2935265:045crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Pry the front-facing camera: crwdns2935265:045crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Pry the front-facing camera: crwdns2935265:045crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The adhesive securing the camera is very strong. Work slowly and apply more heat if the camera feels stuck. Avoid separating the circuit board from camera housing, such as this.
    • Use the flat end of your spudger to pry the front-facing camera from its recess.
    • If the camera doesn't loosen, use your SIM card eject tool to scrape away the epoxy surrounding the camera.
  46. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Prepare the new frame: crwdns2935265:046crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Prepare the new frame: crwdns2935265:046crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • During reassembly, prepare your new frame for the front-facing camera:
    • Remove the black adhesive liner from the front-facing camera recess.
    • Peel and remove the foam liner from the new frame.
    • This liner isn't necessary for the repair.
  47. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Apply new adhesive: crwdns2935265:047crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Apply new adhesive: crwdns2935265:047crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Apply new adhesive: crwdns2935265:047crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before installing the front-facing camera in your new frame, apply new adhesives onto the frame and the camera:
    • Remove the two large clear rectangular liners from the adhesive sheet and place the adhesives on the sides of the camera recess.
    • Remove the liner from the main adhesive piece and place it in the center of the camera recess with its pull tab facing the bottom of the frame.
    • Remove any adhesive residue from the front-facing camera module.
    • Remove the liner from the thin piece of adhesive and place it on the top edge of the camera.
  48. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Install the front-facing camera: crwdns2935265:048crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Install the front-facing camera: crwdns2935265:048crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Install the front-facing camera:
    • Remove all four blue adhesive liners from the camera and the frame.
    • Insert the front-facing camera into its recess in the frame and apply pressure to secure it.
  49. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Unfasten the left 5G mmWave antenna: crwdns2935265:049crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips driver to remove the two 2.4 mm‑long screws securing the left 5G mmWave antenna.
  50. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the left 5G mmWave antenna: crwdns2935265:050crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the left 5G mmWave antenna: crwdns2935265:050crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the left 5G mmWave antenna: crwdns2935265:050crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the left 5G mmWave antenna connector and lift up to separate the bracket from the frame.
    • Remove the antenna.
  51. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, mmWave antenna reassembly: crwdns2935265:051crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, mmWave antenna reassembly: crwdns2935265:051crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, mmWave antenna reassembly: crwdns2935265:051crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before reinstalling the lower 5G mmWave antenna, replace the bracket with a new one. If you don't have a new bracket, skip this step.
    • Remove the antenna and connector from the old bracket.
    • Remove the L-shaped adhesive liner from your new bracket.
    • Place the antenna in the bracket's recess with the connector fed underneath the longer screw mount.
    • Remove the thin adhesive liner on the outside of the bracket before installing it in the frame.
  52. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the right 5G mmWave antenna: crwdns2935265:052crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the right 5G mmWave antenna: crwdns2935265:052crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the right 5G mmWave antenna: crwdns2935265:052crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger between the frame and the right 5G mmWave antenna connector.
    • Pry up with the spudger to separate the adhesive.
  53. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement: crwdns2935265:053crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement: crwdns2935265:053crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab and remove the right 5G mmWave antenna from the frame.
  54. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Upper 5G mmWave antenna reassembly information: crwdns2935265:054crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Upper 5G mmWave antenna reassembly information: crwdns2935265:054crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Upper 5G mmWave antenna reassembly information: crwdns2935265:054crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Replace the adhesive on the upper 5G mmWave antenna before reinstalling it. If you don't have replacement adhesive, reuse your old one or use custom-cut adhesive.
    • Remove the existing adhesive from the antenna with blunt nose tweezers or your fingers.
    • Remove the clear liner from your new adhesive.
    • Apply the new adhesive to the bottom of the antenna, with its round end farthest from the connector.
    • Remove the green liner from the adhesive before reinstalling the antenna in the frame.
  55. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Only the screen and battery assembly remains: crwdns2935265:055crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You're now left with the screen and battery assembly.
    • Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
crwdns2935229:09crwdne2935229:0
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
169,202 crwdns2915208:0crwdne2915208:0
crwdns2935297:0769crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,513crwdne2935297:0
Can you share a propper way to change the screen
Muzakkir - crwdns2934203:0crwdne2934203:0
Hola, compre une caisse completo para remplazar la pantalla, pero en el lugar de la pantalla tengo los revestimientos adhesivos azules de la cámara, como lo quito? por favor una ayuda
Efrain Luna - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 36
crwdns2936753:07crwdne2936753:0 251
crwdns2936753:030crwdne2936753:0 1,095
crwdns2942667:0crwdne2942667:0 22,400
