Retina MacBook 2017 Battery Replacement
  1. Retina MacBook 2017 Battery Replacement, Disable Auto Boot: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement, Disable Auto Boot: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement, Disable Auto Boot: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
    Is this step necessary? I can’t perform this step as I am attempting to repair water damage and need to remove logic board & most likely replace the battery.
    Macrepair SF - crwdns2934203:0crwdne2934203:0
    @mac_medic You definitely don’t want the power coming on while the board is wet. In your case, I think powering on the machine to disable Auto Boot would do more damage than it prevents. I agree, skip this step and be prepared to disconnect the battery quickly if the laptop automatically powers on. Good luck!
    Jeff Suovanen -
    Thats right! You don't want power running while working on your logic board.
    Dan -
    This did not work when running High Sierra.
    Kyle B - crwdns2934203:0crwdne2934203:0
    Tried this on a 2018 MBP 13” Touchbar (there’s no iFixit guide for this model yet). Need to replace a broken screen.
    Luckily I managed to connect to an external screen (Cmd-Down Brightness to switch displays) and enter above command. Seems to work, but there’s another problem with this model - it powers up as soon as any key is pressed……. ffs <gnashes teeth>
    Cool_Breeze - crwdns2934203:0crwdne2934203:0
    I unscrew the battery first and wrap electrical tape over the logic board battery connector before attempting any repairs to the board. Haven’t had any problems yet and I’ve worked on about 10 of these models already. Also when you open the bottom case use a suction cup at the bottom and pull up then run a plastic spudger along the edges to disconnect the clips. Also only use a plastic spudger on the board. Saw a youtube video from a repair shop and he did not disconnect the power and used all metal tools during the entire process of removing the board. His last step was to disconnect the battery terminal.
    Brian - crwdns2934203:0crwdne2934203:0
    Is this step necessary if my mac can turn on? Battery fully dead(
    Nursat b - crwdns2934203:0crwdne2934203:0
    BEFORE YOU START: The included torx head stripped off before I was done (and you might need an additional T4) so stop now and go buy a good one. Also they fail to warn you above to get some blue threadlocker ahead of time.
    Jason Sherron - crwdns2934203:0crwdne2934203:0
    This command did not work for me and I read that sometime in later 2020 Apple stopped this command from working…any ideas on a work around?
    Patrick Machacek - crwdns2934203:0crwdne2934203:0
    Not able to do that with damaged screen
    richardjgreen - crwdns2934203:0crwdne2934203:0
    If you have a damaged screen you can still use a converter from thunderbolt (USB 3) to HDMI and plug your Macbook Pro to your TV as monitor display. Just make sure to chose the right Source (HDMI IN) in your TV. I did it and to make it work I unplug and plug again in my Macbook and so I could disable the Auto boot
    Roberto Sanchez Bustos -
    Hi. This does not work on 2018 13” MacBook Pro with Touch Bar. I did exactly this to disable auto boot. But when I check by using nvram -p it says: auto-boot true. Am I doing something incorrectly? I did everything step by step. Copied and pasted the sudo command, pressed enter and then entered my password. I have Big Sur 11.1 installed. Is there any other way since I need to replace the screen. Thank you. Adrian
    Adrian Vizik - crwdns2934203:0crwdne2934203:0
    Hi everyone. This is also a little pointless if you can’t see anything on the screen, and you don’t have a display adapter to USB C to display it. I agree with Brian about removing the back and disconnecting the battery cable before you even think about opening the lid of the MacBook. Applying the insulation tape is also a handy little tip that just makes sure there is no way to discharge from either the board or battery.
    Roberto Enrieu - crwdns2934203:0crwdne2934203:0
    running `nvram -p | grep 'AutoBoot'` in terminal verifies that it was accepted
    result: `AutoBoot %00`
    Marek Polák - crwdns2934203:0crwdne2934203:0
    Running Big Sur 11.6.7 on a 2019 16" MBP, it's "auto-boot". So it's: nvram -p | grep 'auto-boot' to display the current state, the default is true - and then to change it, sudo nvram auto-boot=false which turns it off.
    Ed Mechem -
    This step is completely unnecessary if you follow the guide to disconnect the battery properly. Just put some tape between the battery and logic board connection to prevent it from accidentally touching and therefore powering on the laptop.
    Grant Ormsby - crwdns2934203:0crwdne2934203:0
    It took me a few tries to make this command work, as I was able to copy and paste the command into Terminal, but could not type in my laptop’s password. I finally typed my password into a text document, copied it (command C), and then pasted it into Terminal and it worked.
    tommy404 - crwdns2934203:0crwdne2934203:0
    I didn’t do this. Mine never auto-booted before I replaced the battery. Now it does.
    hatuxka - crwdns2934203:0crwdne2934203:0
    BEFORE YOU DO ANYTHING - CHECK THE BATTERY!
    I-fixit sent me a bad battery, which I didn’t realize until it was already install. They sent me a new one, but I wasted hours uninstalling and reinstalled.
    Get a volt meter and measure the voltage on the output of the battery pack. If it reads 0 V, SEND IT BACK. It should read over 2 V.
    bcardanha - crwdns2934203:0crwdne2934203:0
    I've just received my replacement battery and it reads 0,042V between the two main connectors. Do you think it's dead?
    peter sussex -
    When I did this from Terminal.app within Recovery Mode, the “sudo” was not recognized but I could invoke it without the sudo part. It seems to have been accepted when looking at “nvram -p”
    johann beda - crwdns2934203:0crwdne2934203:0
    When in Recovery Mode, you already have superuser powers. So you don't need to prefix commands with the sudo command to invoke them with root privileges; you already have them. Do a pwd (print working directory) after opening Terminal in Recovery Mode, and you'll see that you're in the root user's directory.
    Ed Mechem -
    I received the battery kit for my 2018 MacBook Pro and as per the above comment from bcardanha - Oct 12, 2021, I checked the voltage on the pads marked + and - . It was zero volts so I panicked a bit.
    I sent a message on the iFixiT Facebook page and I got no reply. I finally found the customer service email for Ifixit Europe and sent them an email voicing my concern as I was not keen to work for couple of hours just to discover that the battery is faulty. I had an almost instant reply on the email (kudos to them) and they adviced me to go ahead and install the new battery as the voltage measured when battery is not connected is not relevant.
    I took a leap of faith and after two hours… the new battery showed 50% charge and everything seems to be working just fine. I am happy it worked.
    Mircea Comanici - crwdns2934203:0crwdne2934203:0
    After removing the old battery and installing the new battery I powered up the MBP before screwing the bottom on. I discovered the my keyboard would not function. It took a few hours of investigation and frustration that I discovered the track pad power ribbon had become partially dislodged from the trackpad. I was able to see that this through the little machined slot where the battery sat. I had to remove the trackpad to reinsert the power ribbon back into the connector in the trackpad. after reassembling and reinstalling the battery etc the keyboard worked. Just food for thought if your run into the keyboard issue.
    Ed Mease - crwdns2934203:0crwdne2934203:0
    This should be the default. IMO I tell you to power on - not the lid.
    G Sena - crwdns2934203:0crwdne2934203:0
    Est ce que cela fonctionne sur un macbook pro 2017 sans touchbar ?
    maël muzelet - crwdns2934203:0crwdne2934203:0
    Bonjour Maël, oui, ce tutoriel concerne "les MacBook Pro 2016 (et plus récents) et les MacBook Retina 12" 2017 (et plus récents)"
    Claire Miesch -
    Excellent instructions. I was able to follow and install the new screen. I recommend that you get a good set of tools before you begin. I started with an inexpensive repair kit bought online. The Penta and torx bits failed. I bought an IFIXIT kit with quality bits and I was able to do everything I needed.
    Tom Markham - crwdns2934203:0crwdne2934203:0
    If you're not running an admin account the sudo command won't work (which honestly, you should not be running admin). Rather than logging in to your admin amount via the OS, in the terminal type "login [admin username]," then the password and you'll be able to do the sudo command as described above. Once you're complete, type "logout [admin username]" and you'll be good to go. Obviously replace [admin username] with whatever the account name for your admin user is.
    arichard2401 - crwdns2934203:0crwdne2934203:0
    For those unable to complete this step because the screen is too damaged I recommend leaving your macbook on until the battery dies.
    Nicholas R Licato - crwdns2934203:0crwdne2934203:0
    Just replaced my 2018 15" MBP battery. Running Sonoma.
    I found no way to disable AutoBoot (The status can be checked in the Power section of system report).
    Anyway, i left my battery completely drain before opening the MBP, and had no issues during the process.
    Cédric Bontems - crwdns2934203:0crwdne2934203:0
    After sending this command in terminal when I checked what happens if I now open the lid, instead the screen lit slightly up (still black) then a battery symbol showing the charging state showed up.
    Now, after replacement of the battery, this is all I get to see.
    No reset of NVRAM nor PRAM helped.
    Currently the new battery charges (58% atm) and it feels like it‘s mocking me.
    webrockers - crwdns2934203:0crwdne2934203:0
    I suspected the keyboard or TouchID sensor wouldn’t work, so I went on and checked every connector.
    I missed connecting the left TouchID sensor from step 31.
    webrockers -
    Read the comments section at the bottom of the article before proceeding with the repair. It is unnecessary to remove the logic board. I actually removed the 45mm plastic bar to enable the cables to slip out then in. It is only there to frustrate repairers!
    Jack - crwdns2934203:0crwdne2934203:0
    I followed the instructions on my old 2017 MacBook Pro A1707 and I have to say these were the clearest and best instructions I have found on the internet for anything, really. I am about to power up the machine, so we'll see. I'm sure if it doesn't work, it something I was careless with - the instructions matched the hardware perfectly. Def impressed.
    Michael L - crwdns2934203:0crwdne2934203:0
  2. Retina MacBook 2017 Battery Replacement, Unfasten the lower case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Remove the following eight screws securing the lower case:
    • Two 1.8 mm P5 Pentalobe screws
    • Four 2.9 mm P5 Pentalobe screws
    • Two 6.1 mm P5 Pentalobe screws
    • Note the orientation of the screws as you remove them—they need to be reinstalled at a slight angle.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    IMPORTANT. You’re not removing the bottom, yet. This step is solely to separate the panel from its clips, permitting inside access.
    Chris Leeds - crwdns2934203:0crwdne2934203:0
    The screws go in tangent to the curve of the case. If you aren’t used to handling small hardware try turning the screw counterclockwise while you feel for the hole until you feel it drop, that means the threads have aligned. It takes only light finger torque when they are threaded correctly
    abscate - crwdns2934203:0crwdne2934203:0
    Can you please show a picture of all the screws, and where they go? My table got bumped and all the screws stuck to the lid magnet on the MacBook. Gaaaah! Thank you!
    TwiddledUp - crwdns2934203:0crwdne2934203:0
  3. Retina MacBook 2017 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wedge your fingers between the upper case and the lower case, starting from the rear of the MacBook between the hinges.
    • Lift the lower case only slightly to avoid damaging the cables that connect the lower case to the upper case.
    • Keeping a firm grip, lift steadily until the lower case separates slightly from the upper case.
    • You may experience a lot of resistance when lifting the lower case. If necessary, slide an opening pick or other ESD-safe pry tool down the side edges of the lower case to pop the two hidden retaining clips free.
    • During reassembly, to re-engage the clips, press firmly near both side edges of the lower case (near where the pick is inserted in the third image) until you hear the clips snap into place.
  4. Retina MacBook 2017 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While holding the lower case in place, carefully flip the MacBook over so the Apple logo faces up.
  5. Retina MacBook 2017 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the upper case and display together from the front edge and raise it to about a 45˚ angle.
    • It may be helpful to prop the MacBook open in this position for the next step.
    This displays two black pics to prop up the MacBook, but the kit only includes one black pic.
    Kyle Swafford - crwdns2934203:0crwdne2934203:0
  6. Retina MacBook 2017 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
    • If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
    • If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
    • This step ensures the MacBook is fully powered down and safe to work on.
    cannot turn on the led after replacing the new screen, even after following the turn on instructions upper…
    Laurent Pierre - crwdns2934203:0crwdne2934203:0
    on reassembly, I had to plug my laptop in to reactivate the LED light
    aaron_vandyke2003 - crwdns2934203:0crwdne2934203:0
    Does anyone know how to turn it back on..? I plugged the laptop in and saw the LED Light, but it won’t turn on
    mmcsorley - crwdns2934203:0crwdne2934203:0
    After reassembly I could not restart my MacBook using the power button or after SMC reset (shift-ctrl-option-pwr). I had to connect my MacBook to its charging cable to get the battery LED to re-illuminate. After that it was all normal.
    Richard Lovatt - crwdns2934203:0crwdne2934203:0
    It took a few minutes on the power adapter for my computer to turn on after it was reassembled.
    Luk Chl - crwdns2934203:0crwdne2934203:0
    mine doesnt turn on w anything, i forgot to click the buton to disconnect :_/
    cristian.campuzano - crwdns2934203:0crwdne2934203:0
    Same issue as above peeps. Followed ifixit directions verbatim and wasn't getting anything after screwing everything back in. Plugged in original 45W power block and waited, after few minutes battery LED came on and a min. or two after that, was able to get screen to turn on. Hope this helps somebody else.
    Brandon Elliott - crwdns2934203:0crwdne2934203:0
    May I ask how to get screen to turn on. I cannot get it work..
    Xiubo Zhang - crwdns2934203:0crwdne2934203:0
    For those whose Mac won't turn on.
    See step 16
    To reconnect this cable, first line up the metal bracket over the screw holes, then "PRESS DOWN" on the middle of the bracket.
    There is a connector under the bracket, which you can't see if you don't see under.
    Not having it in mind, you will not PRESS DOWN the middle of the bracket and there is no connect.
    hls2005 -
    Thank you @Xiubo Zhang - This solved my problem! Please everyone check this connector if you have trouble turning your Macbook on after replacing the battery.
    Miksu -
    There needs to be mention of procedure for getting the repaired MacBook to power up again after the repair is completed.
    I also am running into the issue described by others. MB will not come on again, even after being plugged into power and performing an SMC reset.
    Kinda stuck….
    Carlos Perez - crwdns2934203:0crwdne2934203:0
    Hi, I tried everything and my MacBook will not start up after replacing the bottom case with a battery installed. I decided to put back on the old case with the battery that needs servicing and it still will not power on. I am fairly experienced taking apart laptops I was an Apple service tech for 15 years. this has me baffalled. Any hints BTY the logic board does not show any power coming from the AC charger the power LED is not lit up
    eestern - crwdns2934203:0crwdne2934203:0
    I had trouble with this as well. What worked for me is to plug in power using the stock 29W USB C power brick that originally came with this Macbook. Trying other, lower powered, power adapters did not work. Use this advice with caution as there are multiple (i.e substantiated) comments that indicate that first power up should only be with a 5W adapter! So perhaps try this strict sequence: try with a 5W adapter, then and only then try with the 29W adapter. Or even slightly better, if everything else has completely failed, only then try full power 29W adapter.
    LexxOne - crwdns2934203:0crwdne2934203:0
    How long did you wait to get it power back on? I replaced my logic board and tried to connect the power charger but it doesnt still turn on.
    Herb -
    The easiest error to make when working on this motherboard if applying full voltage after re-assembly. According to the big A, the motherboard on these Macbooks need to be “woken up” with a 5 watt (phone size) charger. Applying the normal 29 watts may render your system unusable.
    Noah - Feb 18, 2021
    Hello Noah,
    It seems your remark is only valid for the 2015 and not the 2016 edition.
    David - Mar 3, 2021
    While it’s true that the internal documentation specifies this for a 2015, after frying 2 motherboards with a normal charger, I spoke with the engineers and they told me that this also applies to 2016 and 2017 macbook main logic boards. I say- It can’t hurt to try to wake them up with a 5 watt charger first! Please take 5 minutes to save your motherboard.
    Noah - Mar 4, 2021
    Noah - crwdns2934203:0crwdne2934203:0
    I plugged in my charger and the LED came on. The computer gets warm but the screen is not turning on. The keyboards doesn’t seem to respond to recovery options. Any suggestions?
    J'Trel Sapp -
    Hello in muy case the power LED does not go dark (off) . Holding more than 10 sec and nothing. Somebody?
    Flavio - crwdns2934203:0crwdne2934203:0
    The led light doesn’t turn off on mine either. Held for 10 sec 3 times and still on. How do I turn it off now? And will it damage the computer if I work on it with the light on?
    sfalba - crwdns2934203:0crwdne2934203:0
    Also, which way should the track pad flex cable face when reinstalling it?
    When I try to restart, I see the battery symbol flash on the screen. It shows 100% (hooray?) but then never boots up.
    paul0 - crwdns2934203:0crwdne2934203:0
    I had basically this when doing a screen replacement (and the ZIF connector ribbon which basically crumbled to dust as I touched it). Including no sound, no light, no boot, no logos, I had a USB connected sound once when plugging it into my windows PC which i guess confirmed it wasnt totally fried, but I had left it plugged in to a few different chargers (not the 20w or whatever one since I read it could damage it if it was not powering normally. could be total BS) and had it sit from 15-30 minutes on each. all nearly no sign of life, though one re-disassembly showed the previously unlit power LED was on again. I went to let it sit on the officical charger overnight thinking it was dead, but it just randomly booted and is working fine now. TLDR be patient with apples BS.
    MrRooter forthewin - crwdns2934203:0crwdne2934203:0
    Mine wouldn’t switch on at all, completely dead. I tried all tricks in the comments here, nothing worked. I expected the battery was completely gone because it had been sitting on a shelf for months. Upon checking the voltage directly on the battery pads, zero volts measured. So I assumed the battery management was preventing the laptop from switching on.
    To overcome this I tried carefully heating the battery with a heat gun, which raised the voltage to 2.2 Volts. Then I decided as a last resort to put the whole laptop in the oven at 70 degrees C. It worked! Plugging in the charger a few times after the laptop had cooled somewhat, it switched on and started charging as normal, to 100%.
    Toon van Duin - crwdns2934203:0crwdne2934203:0
  7. Retina MacBook 2017 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close the MacBook and carefully flip it upside-down.
  8. Retina MacBook 2017 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lifting from the front edge, open the lower case to an angle of about 45°.
    • Take care not to damage the ribbon cables that still attach the lower case to the MacBook.
  9. Retina MacBook 2017 Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to peel back the tape covering the trackpad cable ZIF connector.
    Where can I find a replacement cable?
    John Comix - crwdns2934203:0crwdne2934203:0
    Just worked on one that was missing the tape from the factory, so yours may not have it either.
    maccentric - crwdns2934203:0crwdne2934203:0
    that cable got damaged, and now my macbook won't turn on anymore. Does this cable prevent the macbook from working?
    ITZ CRONOMO - crwdns2934203:0crwdne2934203:0
    I have the same issue. Th trackpad cable snapped while I was replacing the LCD screen. I have ordered a new cable from Amazon but I am not sure if that would cause the laptop to not power up (it's not power related)
    Raj Venkat -
    My trackpad doesn’t really click (almost no sound/movement) after I replaced the battery.
    Any pointers on what I need to do to get it clicking again. Like tighten screws inside or something? Cheers!
  10. Retina MacBook 2017 Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
    The small retainer flips up about 90 degrees from locked position
    The keyboard and trackpad don't work after the repair, what can I do? They don't even show up in System Report.
    bredelet - crwdns2934203:0crwdne2934203:0
    I found that the connector was not pushed enough in. Works now.
    bredelet -
    I flipped up the small retainer -- but when I tried to flip it down, it flew off. The tabs that mount the retainer are very small, and I couldn't get it back on. Left it out, taped down the cable.... and so far the computer, battery, and trackpad are working.
    Bessel Sphere - crwdns2934203:0crwdne2934203:0
  11. Retina MacBook 2017 Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame.
  12. Retina MacBook 2017 Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully close the MacBook and flip it over once again, so that the Apple logo faces up.
    • Lifting from the front edge, raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
    • Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
    • It's possible to open the MacBook all the way and lay both sides down flat, but this may damage the flex cables and is not recommended.
  13. Retina MacBook 2017 Battery Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board.
    From my experience it’s important to carefully press and hold the small button above left of the Battery Discharge label. Use a plastic spudger or finger tip. The illuminated yellow LED to the right will go off. I believe this discharges remaining electricity from logic board protecting it during repair.
    * I cannot find any documentation to support this, but I have damaged boards by not including this step.
    I don't know what guide your on, but step 6 of the guide to replacing the USB-C cable has you press this button (3 times even).
    maccentric -
    What is with the all plastic end of this cable that appears to just be glued right on top of its connector?
    Does the new one just stick back right on top?
    (In this photo it is the bottom side of the cable below the white water indicator sticker)
    Elizabeth Erkelens - crwdns2934203:0crwdne2934203:0
  14. Retina MacBook 2017 Battery Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Battery Blocker
    $3.99
    • As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
    What happen if you don’t disconnect the battery? I didn’t and I saw smoke coming out when I connected the pad flex cable and the computer still started up
    DSANTIAGOSOY - crwdns2934203:0crwdne2934203:0
    If you don’t disconnect the battery you might accidentally short something on the logic board since power is still running through everything while you’re working on it. You can complete the repair without disconnecting the battery, but you risk accidentally breaking your logic board. It’s much safer to keep the battery disconnected while you’re working.
    Adam O'Camb -
  15. Retina MacBook 2017 Battery Replacement, USB-C and Audio Jack Disconnect: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws securing the USB-C port cable bracket:
    • 1.1 mm Phillips #00 screw
    • Some variations of this model may use a Tri-point Y00 screw.
    • 3.5 mm T5 Torx screw
    I’m at this point and the 1.1 mm Phillips #00 screw won’t budge and now I fear it could be stripped? Now what???
    Y'vonne Feeney - crwdns2934203:0crwdne2934203:0
    You could try to cover the tip of your screwdriver with a thin rubber glove to improve the grip on the screw while applying a little more downward force for the initial jolt. That might loosen the screw.
    Tobias Isakeit -
    The USB-C ribbon cable breaks very easily when being attached. Any particular tricks for ensuring that it won’t snap somewhere while being installed?
    bfg737 - crwdns2934203:0crwdne2934203:0
    With my iFixit screwdriver kit, these were Philips #000, not #00.
    Paul Nishikawa - crwdns2934203:0crwdne2934203:0
    This was #000 for me as well
    Adam Hupp - crwdns2934203:0crwdne2934203:0
    I was at the 1.1 mm and couldn't get it open with the 00. I ordered the 000 but it still won't budge. I tried the glove idea and as much pressure as I'm comfortable giving. I'm pretty sure the screw is stripped. Any ideas or advice or am I in trouble?
    johnny gutierrez - crwdns2934203:0crwdne2934203:0
    Got stuck here too. Bought a Chinese laptop/phone servicing kit and guess what? No 1.1mm philips. The 1.2mm it does include doesn’t sit tightly enough. Had to order separately….
    David Miller - crwdns2934203:0crwdne2934203:0
  16. Retina MacBook 2017 Battery Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board.
    • To reconnect this cable, first line up the metal bracket over the screw holes, then press down on the middle of the bracket. Make sure it's aligned correctly, or you may damage the connector.
    At re-assembling, when you reconnect this cable, pressing centre of metal plat is extremely important. You should feel tiny click when it connected properly. I encountered unrecognised external HDD and external monitor through USB-C even though charging in/out was OK, i.e failure of data transmission. I needed to re-open the back cover and pressed the metal plate again, then USB-C connection worked properly.
    Aki Mochi - crwdns2934203:0crwdne2934203:0
    After this step, I flipped the Macbook over once more and opened it up 90 degrees, supported on the back. Proceeded directly to step 25. Seems safer, those fragile connectors and flimsy cables give me heebie jeebies.
    I endorse maccentric's comment above. I think it's better to remove the battery (carefully) with the logic board in place. I did that and the computer works fine after reassembly.
    In fact, I removed a couple more cables than this step, but got creeped out by the many delicate cables being moved, and user comments about failed disconnect and reconnect, so I skipped to step 25 lower down.
  17. Retina MacBook 2017 Battery Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector.
  18. Retina MacBook 2017 Battery Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the audio jack board ribbon cable by pulling it straight back out of the ZIF connector.
    • During reassembly, orient the ribbon cable so the white stripe faces you. Insert the cable until the white line disappears under the socket.
    • At this point it is possible to open the macbook all the way and to lay it flat on a table without causing any damage to the flex cables.
    Make sure at reassembly that you insert the ribbon cable in to the jack board fully. It seems to take an extra push. The white line should disappear when it is seated properly. I didn’t get it in all the way by a fraction of a mm and had no sound (internal speakers weren’t even recognized). Went back and seated the cable fully and sound was back.
    Timothy Dinkelman - crwdns2934203:0crwdne2934203:0
    I had that same problem, too.
    lyonmissions - crwdns2934203:0crwdne2934203:0
    Had the same problem, (no audio after reassembly) it did have the startup chime though.
    after re-seating the ribbon cable, it worked for a few days, but then nothing after waking up.
    not even the startup chime.
    Any body got pointers on how to check if i broke the cable or the board? (looks fine...)
    Christian Stanner - crwdns2934203:0crwdne2934203:0
  19. Retina MacBook 2017 Battery Replacement, Lower Case Assembly Removal: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Retina MacBook 2017 Battery Replacement, Lower Case Assembly Removal: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to peel back the tape covering the display cable connector.
    I won’t have my daughter’s MacBook with its banana encrusted USB-C port until she returns home during spring break — just doing some homework before then. But if the case can lie flat after the audio board ZIF cable is detached, why do you need to detach the display cable connector (Steps 19-24)? It seems that you could jump straight to Step 25 to replace the USB-C port and avoid those steps.
    John Conklin - crwdns2934203:0crwdne2934203:0
    Hi John, disconnecting the display cable is not necessary, but is recommended to avoid accidental damage to the cable during the rest of the procedure. If you feel confident in the safety of the cable then you can skip ahead. Good luck with the repair!
    Adam O'Camb -
    I skipped ahead to step 25 successfully by making a secure stand for the display and being careful to not strain cables. If you are decently motor skilled this saves you 15 minutes or so. Not recommended if you live with cats who love little screws to chase
    From here I only did step 34 and then 37 onwards, skipped all the other steps.
    I did use tape to mate top&bottom to make sure the cables couldn't be torn. Saved me a lot of fiddly flat cable work.
    Great howto. Glad I found it.
    I thought replacing this battery would be like in my 2013 13" air. Remove the bottom, replace battery, done. No tape, no nothing. This macbook (my daughters) is a real pain. But this description made it possible to do anyway.
    Janis - crwdns2934203:0crwdne2934203:0
  20. Retina MacBook 2017 Battery Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • It's possible the metal retaining flap on the display cable connector may flip open, remaining stuck to the tape.
    • If so, use the flat end of a spudger to hold down the retaining flap while peeling the tape away with the tweezers.
  21. Retina MacBook 2017 Battery Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of a spudger to flip open the retaining flap on the display cable connector.
    • Try to keep it clear of the tape, or it may re-adhere and make cable removal difficult.
    I found it helpful to stick one of the triangular picks in between the table and the retaining flap to keep them separated.
    Kofi Kantanka - crwdns2934203:0crwdne2934203:0
  22. Retina MacBook 2017 Battery Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    iOpener
    $14.99
    • Carefully slide the flat end of a spudger underneath the display cable to separate the adhesive holding it to the lower case.
    • Take care not to damage the cable. If the adhesive is very strong, heat the case directly beneath the cable with an iOpener to soften the adhesive, and then try again.
    Great, another new fragile display cable to deal with. Thanks Apple.
    I didn't manage to get the display cable unstuck just using a spudger. I didn't have an iOpener. So I successfully just skipped ahead to step 24, working on the top half while still attached.
    andrew987 - crwdns2934203:0crwdne2934203:0
    Some of the black covering on the display cable came away. How much of an issue is that going to be?
    Jim Stafford - crwdns2934203:0crwdne2934203:0
  23. Retina MacBook 2017 Battery Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the retaining flap open.
    • Disconnect the display cable by gently pulling it straight out of its connector.
    • Immediately close the retaining flap. Keep it closed throughout your repair.
    • During reassembly, keep the flap closed while you insert the display cable. Remember to orient the cable so its gold contacts face down, making sure not to crimp or fold it—it'll click into place when it's connected.
    I’m pretty sure I understand the instructions here, but I had to think about it a little longer because “… must remain closed when the cable is reinserted during reassembly …” was not clear to me right away. The retaining flap I discovered, is super delicate, and hence my paranoia, so I wanted to point this out in case anyone else felt like me: ''''Is it correct to assume that your instructions could be interpreted as:
    “After disconnecting the cable, close the retaining flap for now to avoid damaging it. When reinstalling the cable, flip up the retaining flap once again, realign and slide the cable with gold contacts facing down.”
    I bent the USB-C corner of the lower case from a short drop onto laminate flooring, so in I went to shape it so the edge wouldn’t snag or scratch things. I am typing on my MacBook that received the body work.
    Thank you for your guidance!
    John Torquido - crwdns2934203:0crwdne2934203:0
    For @seriouslyjohn and anyone else who might be wondering: “the flap must remain closed when the cable is reinserted” means keep it closed. Do not reopen the flap to insert the cable; just insert it carefully while leaving the flap closed. I know it probably runs counter to the procedure you’re used to, but Apple’s documentation is very clear on this, and I have to think it’s for a reason. My advice is to follow the instructions as written and don’t try to reinterpret them ;) Congrats on a successful repair!
    Jeff Suovanen -
    Oops! I most definitely did NOT reinsert the cable into a closed connector. We can only wonder why Apple instructed this step to be counter-intuitive. I’ll pay closer attention to any weirdness that may arise, but the MacBook has been traveling and performing as it should; I’m going to avoid reopening the case, as easy as it is, until I have a good reason to do so. Thank you for replying and updating the guide!
    I would argue that you should NOT close the retaining flap. I followed the directions to the letter, and when I started up the MacBook, the display did not register since the I wasn’t able to reseed the cable fully without worrying about tearing the cable. I did hear the computer charging and saw that the keyboard lit up, so I knew the MacBook was working besides the display. I looked up another video on Youtube that left the retaining flap open when reinstalling, so I took apart the Macbook again and tried it that way, and IT WORKED! The cable wasn’t fully reseated with the retainer open and I’m not sure if that was my fault or not, but with the retainer flap open, it was easier to see that. My 2 cents. Good luck everyone!
    Sulmo Kim - crwdns2934203:0crwdne2934203:0
    I initially tried inserting the cable with the retaining flap closed (as described), however after completing reassembly the MacBook could be heard to start but without any display action (no backlight, no graphics - also tried resetting the SMC). Being suspicious of this step based on the comments above, I tried re-inserting the cable with the retaining flap open before subsequently closing the flap. It may have just been my perception but insertion with the retaining flap open certainly appeared to result in a more robust mating of cable and connector. After reassembly and reset of the SMC I at least saw backlight action although no graphics still. A subsequent boot into to diagnostics mode resulted in the graphics coming to life.
    Maybe my re-insertion while the retaining flap was closed was not quite correct (although I was certainly trying to be careful), but my experience was that success was achieved making the cable insertion while the retaining flap was open.
    Paul Richards - crwdns2934203:0crwdne2934203:0
    It is kind of nice that I don't have to worry about that. The screen cable is literally plug & play. Super easy.
    In my case that metallic part with the flap came loose ... Is it a problem if the metal part is removed and the cable simply kept in place with tape ?
    What is the purpose of this metallic part aside for holding the display cable down ?
    iridium - crwdns2934203:0crwdne2934203:0
  24. Retina MacBook 2017 Battery Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the upper case assembly from the lower case assembly.
  25. Retina MacBook 2017 Battery Replacement, Logic Board: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement, Logic Board: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement, Logic Board: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to peel up the tape covering the two ZIF connectors—one for the right speaker cable, and one for the audio jack board cable.
    Removing the logicboard must be safer way, but battery replacement can be accomplished if you skip here to step 32, and omit 36.
    I'm not sure removing the logic board is safer, you have many more opportunities to break something. I left it connected but removed the screws so I could maneuver the battery underneath. Faster and safer imo.
    maccentric -
    I would strongly advise anyone tempted to follow this advice and skip to 36 to NOT DO THAT. The hardest part of this whole project is removing the old batteries and adhesive. You’re going to want to use the adhesive remover liberally. Getting that on your board, or accidentally gashing at it when you’re trying to wedge out the old battery, is going to ruin it. Trust me, you would hate to go through all this just to find out you fried your board because of this (admittedly tempting) comment. There are seemingly a lot of steps from here to 36, but they’re all pretty easy and fast. KEEP GOING! KEEP FOLLOWING THE INSTRUCTIONS. YOU WILL MAKE IT!
    RDG -
  26. Retina MacBook 2017 Battery Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to flip up both ZIF connector retaining flaps.
  27. Retina MacBook 2017 Battery Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull straight back on the two pieces of tape you just peeled up to disconnect the two ribbon cables.
  28. Retina MacBook 2017 Battery Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to peel up the foam pad covering the two antenna connectors.
  29. Retina MacBook 2017 Battery Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert one arm of your angled tweezers under the metal neck of the first antenna connector and pry up to disconnect it.
    • The antenna connectors and sockets are extremely fragile. Be very careful to lift only on the connector, and not on the socket itself. Do not lift under the cable, or put any unnecessary strain on it.
    The supplied tweezer is no good. You need one with grooves as shown in the picture. When re-inserting the antenna connectors, make sure that they are seated properly before pushing down. If you have magnifying equipment, use that to get visual confirmation. I used tactile feedback from my fingers to discern proper alignment. Try not to force it.
    Ki Park - crwdns2934203:0crwdne2934203:0
    I used the tweezers provided by iFixit. I struggled with both connectors and finally managed to disconnect both, but when I came back to reconnect them, I realized that both connectors on the logic board were loose. Long story short, it turns out that my little exciting adventure changing the battery cost me $530 to send it for repair at Apple Care. I am quite good at troubleshooting Mac and used to work for Apple for many years. This one step is more dangerous than it seems, because you can end up like me, without wifi on your mac. Honestly, for those who think they can do it, think twice. You can thank me later…
    Arthur Liegeois - crwdns2934203:0crwdne2934203:0
    For me this step was the only point where I had a bit of trouble. The supplied tweezers were not the best for disconnecting the antenna connectors as Ki Park points out already. In my case the outer ring of one of the connectors on the logic board bended slightly. It bended back in place during assembly and the wifi works as normal again after the repair. It is very tricky though, really be careful in this step and use other tools as necessary.
    Arie Machgeels van Ziel - crwdns2934203:0crwdne2934203:0
    BY FAR THE MOST DANGEROUS PART OF THE JOB!. I broked one connector and spent an hour with high powered magnifiers to try a repair. Wasted an hour on this. Id suggest leaving the logic board in place if possible
    Crisis Guy - crwdns2934203:0crwdne2934203:0
    I had no problem with this. The key is to come toward the connectors from the opposite direction from that shown in the photo. Easier to grip the connector.
    david - crwdns2934203:0crwdne2934203:0
    I broke one. Looking back, it may have been safer to detach the motherboard from the case before disconnecting the antenna, as it allows more angles to access them. 😢
    I actually put one of the tweezer tines under the connector and used it as a lever gently to pop the antenna connector off the housing. Worked well, but I had to be super careful not to break anything.
    Woodward Price - crwdns2934203:0crwdne2934203:0
    These connectors are incredibly finicky to reinstall. Precise alignment is critical. You can sort of get a sense of when the connectors are properly aligned by trying to slide them side to side with your finger, but mostly it's a case of trial and error. Don't apply excessive force because you risk damaging the edges of the connectors. When properly aligned they don't exactly click, but you do feel them go in.
    nigel - crwdns2934203:0crwdne2934203:0
    DO NOT REMOVE THESE. As others have stated these are fragile and finicky to remove and reinstall. Instead, leave them intact and lift up the logic board at a 70 to 80% angle. Use a piece of tape secured to the bottom edge of the computer and the top edge of the logic board to hold it up and out of the way. If you are diligent, you can remove the batteries without touching or messing with the logic board. Use caution, don't get too overzealous, take your time.
    Steven Gibson - crwdns2934203:0crwdne2934203:0
    tough one - you guys scared me... SOLUTION: HOLD A SECOND TWEEZERS WITH STRAIGHTEDGE ON THE INSIDE EDGE WHILE GENTLY USING PROVIDED POINTY TWEEZER ON THE OPPOSITE SIDE TO PRY UP THE CONNECTOR. FLAT TWEEZER PROVIDES JUST A HINT OF BACK PRESSURE, KEEPS THINGS STRAIGHT WHILE YOU INSERT THE POINTED TIP AND PRY UP GENTLY. INSERT AND LEVER IT UP - I.E. AFTER INSERTION, TWIST THE POINTED END SO PRESSURE IS STRAIGHT UP, FROM UNDER THE MIDDLE OF THE CONNECTOR - DON'T INSERT AND PUSH AWAY FROM YOU. MINE POPPED RIGHT UP THIS WAY (after exploring all other options). IMPORTANT - THE POINTED TIP (PRY SIDE) COMES FROM OUTSIDE OF CASE , OPPOSITE SHOWN IN PICTURE (AS MENTIONED BY PRIOR COMMENTER.). I ACTUALLY NEED RELATIVELY LITTLE PRESSURE USING THIS METHOD TO GET THE CONNECTORS TO POP. INSERT POINTY TIP UNDER THE NARROW SPOT JUST AHEAD OF THE WIRE, BUT BEFORE THE SOCKET
    David Nagle - crwdns2934203:0crwdne2934203:0
    For reassembly I found it helped to temporarily put the torx screw from Step 14 in so that the logic board is fixed firm and you are not aiming for a moving target with the tiny connectors.
    Tim - crwdns2934203:0crwdne2934203:0
  30. Retina MacBook 2017 Battery Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry up the second antenna connector to disconnect it.
    Broke a connector. Now what?
    chrisadams - crwdns2934203:0crwdne2934203:0
    BEWARE - there are no instructions on how to reassemble this. It goes to step 52 - battery installed and that is it. Easy to pull out, almost impossible to put back in afterwards. So STUDY this to get an idea of how to reattach.
  31. Retina MacBook 2017 Battery Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the left speaker cable connector by prying it straight up from the logic board.
    Reassembling NOTE. The left speaker cable needs to be below the logic board when screwing in the right screw. Otherwise you will have to backtrack.
  32. Retina MacBook 2017 Battery Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to flip up the retaining flap on the trackpad cable ZIF connector.
  33. Retina MacBook 2017 Battery Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the trackpad cable from the logic board by gently pulling it straight out of its connector.
    • During reassembly, check that your ZIF connector flaps are flipped up before reinserting their cables.
    Once the logic board has been replaced, when following these instructions in the reverse order it should be pointed out that the all the flaps are flipped down. A distracted person might try to force in the flat connector before realising that he has to flip up the flap of the new logic board.
    Davide Dante - crwdns2934203:0crwdne2934203:0
    Ok, went decent but on reconnecting the trackpad cable which I had to replace, it isn't clear which side goes up and which side goes down. From the photos, it appears the copper coated side is down at least on the logic board. Is this the same on the trackpad connector?
    I can't quite find a clear photo of the copper surface position on either end of the ZIF trackpad insertion.
    HELP!
    Marc - crwdns2934203:0crwdne2934203:0
  34. Retina MacBook 2017 Battery Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 3.5 mm T5 Torx screw securing the logic board to the lower case.
  35. Retina MacBook 2017 Battery Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:035crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:035crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip up the front edge of the logic board.
    • Handle the logic board only by its edges.
    • Lift and detach the EMI tape securing the logic board to the lower case.
    • If the tape feels stuck, heat it with a hair dryer or iOpener to soften the adhesive.
    • Reattach the tape securely during reassembly.
    “Reattach the tape securely during reassembly.”
    In my case the tape did not stick properly to the lower case anymore and also came a bit loose from the logic board. Nonetheless my macbook works fine after the repair, so I'm not sure how important the EMI tape is. If I experience problems in the future I might open the macbook up again and check the tape and perhaps reattach it better with some new glue. There is probably special glue needed, so I'll look into that when it becomes an issue.
  36. Retina MacBook 2017 Battery Replacement: crwdns2935265:036crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the logic board.
    If you are replacing the logic board once the machine has been rebuild the 2015 model has to have a 5W power adapter plugged into the machine first before the full 29W power supply otherwise there is a risk of damaging the logic board. Once the power is supplied the battery disconnect LED will switch on and once this has occurred you can remove the 5W and supply the machine with the full 29W power adapter.
    Aaron Dalziel - crwdns2934203:0crwdne2934203:0
    Noah -
  37. Retina MacBook 2017 Battery Replacement, Battery: crwdns2935265:037crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement, Battery: crwdns2935265:037crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement, Battery: crwdns2935265:037crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the back edge of the lower case assembly and prop it up at an angle using a book or foam block.
    • In the following steps, you'll apply liquid adhesive remover along the edges of the battery cells. Keeping part of the MacBook elevated will help the adhesive remover flow underneath the battery.
    • You can reorient the MacBook as needed throughout this procedure, but try to prevent the adhesive remover from touching any components other than the battery and metal chassis.
    • If necessary, add a layer of aluminum foil underneath your MacBook to protect your workspace from wayward drops of adhesive remover.
  38. Retina MacBook 2017 Battery Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:038crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about skin irritation, put your gloves on now.
  39. Retina MacBook 2017 Battery Replacement: crwdns2935265:039crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:039crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:039crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull off the black rubber stopper from your bottle of adhesive remover.
    • Twist to loosen or remove the bottle cap before you cut the applicator tip.
    • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Use scissors to cut off the sealed tip of the applicator.
    • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
    • Twist and close the bottle cap securely before you proceed further.
    My kit has black cap with added curved clear piece attachment
    My kit has a screw-on black plastic cap, with an applicator with a pre-cut hole inside.
    I am not sure why one should use this substance, since it turns out that isopropyl alcohol dissolves the glue, as the directions note below.
  40. Retina MacBook 2017 Battery Replacement: crwdns2935265:040crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:040crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:040crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The adhesive securing the battery cells to the lower case is located in the areas marked in red.
    • You may use this step for reference when applying the adhesive remover in the following steps.
  41. Retina MacBook 2017 Battery Replacement: crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a few drops of adhesive remover along the top edge of the front right battery cell.
    • You don't need to use very much. The small bottle contains more than twice the amount of solvent needed to remove all six battery cells.
    • Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
    Das ist nicht nötig. Ich habe mit einer schmalen Spachtel die Akkus sehr gut und vorsichtig vom Klebstoff getrennt.
    Hat wunderbar geklappt.
    Gruß aus München, Tom
    Thomas Schroeder - crwdns2934203:0crwdne2934203:0
    The applicator on the new bottles of the adhesive remover are much bigger, which makes it harder to get the product under the battery.
    Léonie Lefebvre - crwdns2934203:0crwdne2934203:0
  42. Retina MacBook 2017 Battery Replacement: crwdns2935265:042crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:042crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:042crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Plastic Cards
    $2.99
    • After 2-3 minutes, slide one corner of a plastic card underneath the battery cell.
    • This should require minimal force. If you have trouble, apply more adhesive remover along the other edges of the battery cell and give it 2-3 additional minutes to penetrate.
    • Try not to deform the battery. A damaged or punctured battery can leak dangerous chemicals and/or catch fire.
    • It may help to gently twist the card to open up a slight gap between the battery cell and the MacBook's case.
    • Slide the card farther underneath the battery cell to separate it from the adhesive securing it to the case.
  43. Retina MacBook 2017 Battery Replacement: crwdns2935265:043crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:043crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery cell from the right edge to fully separate it from the adhesive, but don't try to remove it.
    • Leave the plastic card underneath the battery cell to prevent it from re-adhering as you proceed to the next step.
  44. Retina MacBook 2017 Battery Replacement: crwdns2935265:044crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:044crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the previous three steps to separate the front left battery cell.
  45. Retina MacBook 2017 Battery Replacement: crwdns2935265:045crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:045crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:045crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous steps to separate the large battery cell on the left side of the MacBook.
  46. Retina MacBook 2017 Battery Replacement: crwdns2935265:046crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:046crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the previous steps to separate the large battery cell on the right side of the MacBook.
    • Be careful not to damage the audio jack flex cable, near the back edge of the battery cell.
  47. Retina MacBook 2017 Battery Replacement: crwdns2935265:047crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:047crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:047crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay the lower case assembly down flat, and apply adhesive remover to the two middle battery cells—at each side, and along the front edge (opposite the logic board area).
  48. Retina MacBook 2017 Battery Replacement: crwdns2935265:048crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply some additional adhesive remover down the middle between the two battery cells.
    • Wait 2-3 minutes for the adhesive remover to penetrate before you proceed.
  49. Retina MacBook 2017 Battery Replacement: crwdns2935265:049crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:049crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:049crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert your plastic card under the front edge one of the battery cells and separate it carefully.
    • If you're having trouble getting the card underneath the battery cell, try working a piece of floss or wire underneath the battery cell and pull it side-to-side in a sawing motion to separate the adhesive.
  50. Retina MacBook 2017 Battery Replacement: crwdns2935265:050crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat the previous step to separate the final battery cell.
  51. Retina MacBook 2017 Battery Replacement: crwdns2935265:051crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:051crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:051crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery by lifting it away from the speaker and logic board area.
    • Take care not to drag the battery over the lower case assembly, or you may damage the speakers or flex cables.
    • Before installing your new battery, remove all the remaining adhesive from the MacBook's case.
    • Peel off larger pieces of adhesive using tweezers or gloved fingers.
    • Scrape away any remaining adhesive with a plastic tool, and clean the underlying areas with adhesive remover or isopropyl alcohol. Wipe in one direction, not back and forth, until all the adhesive residue is gone.
    • This can take quite a bit of work, so be patient.
    Change the battery: 25 minutes
    Remove the adhesive: 2:35 hours
    Andrea Moretti - crwdns2934203:0crwdne2934203:0
    Frankly, this is the hardest and time consuming step throughout replacement task. I strongly recommend to utilize chemical tools to get rid of residue of adhesive tape. I used unused credit card to scrape it away. Be patient.
    I used citrus oil. It’s vegan. Mr Jobs would approve ;) Made it very easy - less than an hour. After removing battery with the method shown in this iFixit, apply oil to remaining adhesive (black stuff included). Wait five minutes. Scrape black stuff away with plastic card etc. Wipe glue residue from edges towards middle (of each cell) with cloth. I used an old face washer. The nap picks up the clumps of dissolved glue residue nicely. Finish with clean cloth and alcohol. Looks like new!
    Pete Smith - crwdns2934203:0crwdne2934203:0
    I applied some isopropyl alcohol to the adhesives then broke up one corner and lifted it up, then slowly pull it the same method to remove an iPhone’s battery’s adhesive. The old adhesives came off with ease and cleanly — less mess to wipe off afterwards.
    Trung Dang - crwdns2934203:0crwdne2934203:0
    I’ve removed pieces of glue very very easy, with ceramic hob scraper.
    Everything was as new in 5 minutes.
    davor - crwdns2934203:0crwdne2934203:0
    Once the big, black adhesive strips are removed, cleaning up the remaining detritus can be time consuming. I found the best way to proceed was to continuously apply small quantities of the adhesive remover while wiping away the detritus immediately.
    Didn't see these comments b4 removing the adhesive so spent 2 hours scraping it off. Next time I might use some Goo Gone or alcohol.
    Andrew Mohan - crwdns2934203:0crwdne2934203:0
  52. Retina MacBook 2017 Battery Replacement: crwdns2935265:052crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:052crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retina MacBook 2017 Battery Replacement: crwdns2935265:052crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Tesa 61395 Tape
    $12.99
    • Test your new battery's fit and alignment carefully before installing it.
    • Unlike most laptop batteries, the MacBook's battery is precisely contoured to fit the "terraced" shape of the lower case. Each cell must be correctly positioned, or the MacBook may not close correctly and damage may result.
    • Your replacement battery may come affixed to a thick plastic top liner to help keep the individual cells in position as you install it. Don't remove this liner until after the battery is installed.
    • If your battery came with adhesive pre-installed on the bottom, peel away the bottom plastic liners to expose the adhesive. If your battery did not come with adhesive, apply a thin double-sided adhesive tape such as Tesa 61395 to the lower case in the areas marked in red.
    • Carefully position the battery and set it into place. Press and hold each cell firmly for 5-10 seconds to secure it to the lower case. Afterward, peel off the plastic top liner along with any foam padding.
    hola a todos, yo le he cambiado la batería a todos mis Macbook pero el cambio de esta batería fue verdaderamente aterrador, les recomiendo que si está en su posibilidad económica pagar a un agente autorizado o una macstore hagalo, el cambio de mi batería lo realice yo y fue satisfactorio, pero me faltaron muchas herramientas. el Macbook no encendido a la primera destapar revisar volver a cerrar. la batería tiene una pega extremadamente dura y me costo mucho sacarla Suerte
    jesset81 - crwdns2934203:0crwdne2934203:0
    hello to all, I have changed the battery to all my Macbook but the change of this battery was truly terrifying, I recommend that if it is in your financial possibility to pay an authorized agent or a macstore do it, the change of my battery makes it  me and it was satisfactory, but I lacked many tools.  the Macbook not turned on the first uncover review close again.  the battery has an extremely hard tack and it cost me a lot to take it out, luck
    To remove the battery, I applied acetone on the edges of the battery. Kept it tilted fir a few minutes and started prying with a credit card. Reapply acetone to the edge of the card, pry again, wait a few minutes and pry again. I thought it would be harder than it was. Removing the battery and all adhesive probably cost 30 minutes work.
    vanblerk123 - crwdns2934203:0crwdne2934203:0
    I found after reassembly I had no response from the display, although I could hear the boot up sequence and USB-C cable insertion audio. After reset of the SMC I at least began seeing the backlight on boot. Subsequently forcing entry to diagnostics mode caused the display itself (i.e. graphics) to also come to life. The diagnostics found no issues but did seem to trigger the display to start working... hopefully helpful to someone.
    I managed to fit the battery with the help of this guide, but I have turned it on, and it does not recognise the pad or the keypad and yet it recognises the keypad button to turn it on and off.
    The start screen shows, but I cannot put my password in because the keyboard doesn't work and yet it went into a mode telling me to use a Bluetooth mouse which I did that connected and the mouse cursor works but then tells me to attach a Bluetooth keyboard. So the keyboard and the mouse pad on my retina does not function. Has anybody got any suggestions? Are there any of the connectors inside that I took off that out the obvious ones to check the connection?
    david p white - crwdns2934203:0crwdne2934203:0
    Has anyone else completed this and then had the haptic feedback on the mousepad not work? Mouse works fine, along with everything else, just no haptic (yes I double checked my settings). Worst case, I’ll open it back up and reinsert the ribbons, but wanted to check here first. Thanks
    RDG - crwdns2934203:0crwdne2934203:0
    Lots of people lost keyboard + trackpad after this. Here is how I recovered it. Read through all the posts
    Keyboard and trackpad not working after battery replacement
    Howard - crwdns2934203:0crwdne2934203:0
    Thanks for the guide. Could exchange the battery and the mainboard to breath in new live into an MB 2015. Now running perfectly under Sonoma with Open Core Legacy Patcher and Sonoma.
    christopher - crwdns2934203:0crwdne2934203:0
For optimal performance, calibrate your newly installed battery after completing this guide.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
crwdns2935229:034crwdne2935229:0
Jeff Suovanen
crwdns2935283:008/06/13crwdne2935283:0
443.344 crwdns2915208:0crwdne2915208:0
crwdns2935297:0259crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.995crwdne2935297:0
crwdns2947412:023crwdne2947412:0
When will the battery Start to swell?
Any warning sign for emergency replacement?
Keyur chakurkar - crwdns2934203:0crwdne2934203:0
Is this Battery compatible with my Macbook 12-inch 2015 Retina?
Alberto Pomales - crwdns2934203:0crwdne2934203:0
Absolutely fantastic instructions. Just follow step by step. There will be no surprises. Took about 2-2,5 hours.
Guys! I did it! took me 2.5 hrs. really appreciate the thorough instructions!
austenschultz - crwdns2934203:0crwdne2934203:0
Instructions are great. But I think I either shorted something or broke something. I can feel the battery getting warm during charging. But it will not power up.
Kevin - crwdns2934203:0crwdne2934203:0
Keyur, when the battery starts to swell, the trackpad will lose some travel and will be hard to press. Also, the lid of the MBP will start to gap a bit when closed, and will worsen gradually.
jonathan - crwdns2934203:0crwdne2934203:0
I replaced the battery and plugged my Mac in but it won't turn on. I double checked that everything is connected. Do I just need to wait longer?
Ashley - crwdns2934203:0crwdne2934203:0
Same problem as Ashley. This did not help. I replaced the battery with the ifixit battery and instructions, and the usb-c port and the unit has no life. What next?
Peter Schmitt - crwdns2934203:0crwdne2934203:0
A heads up I had these symptoms when first attempting this repair (similar to Ashley/Peter):
* Laptop will not power on
* Heat when first plugging in USB-C cable and/or letting battery contacts mate w/logic board (I first noticed this near the speaker grill)
For me this was caused by accidentally reversing one of the cables during reassembly (right audio jack assembly cable, white strip should face you, step 18). This cable was running hot when the machine was under power and the laptop would not boot. From my limited troubleshooting, all cables need to be correctly attached for the machine/display to power on. This includes booting the machine w/out the battery (all cables need to be correctly seated to power on). Sucked at the time, but this kit is still worth it!
Tyler Holmes - crwdns2934203:0crwdne2934203:0
Battery, Tools and instructions are perfekt. My MacBook is now again as good as new. Repair took less than 3h. Top and thank you guys!
Stefan Fischer - crwdns2934203:0crwdne2934203:0
Does the macbook (2017) work without a battery?
Marton Sari - crwdns2934203:0crwdne2934203:0
Hi all, once finished, when I try to restart, the MacBook is just showing 100% battery but never restarts. Did anyone had to fix this issue as well ? Thank you very very much for your help.
Thank you!! "Waking up" the logic board for 5 minutes with a 5V power supply, like someone suggested, worked great and without issues. Awesome instructions as always!!
Sjaan - crwdns2934203:0crwdne2934203:0
Nice instructions.
Just completed in about 2.5 hrs. recommend a good magnifying glass in order to confirm the flex connector latches are in correct positions for removal and after reinsertion.
Antenna connectors were a little challenging to reinsert - not sure how much force to apply - confirm alignment good 1st.
Right speaker flex connector also a challenge to realign then reinstall.
Mark Elgood - crwdns2934203:0crwdne2934203:0
Hi, I replaced the battery in my daughters MacBook with one purchased from yourselves, all worked fine until recently when it suddenly wouldn't charge, the power page of system report says that the battery has 0 charging cycles and needs attention. Any suggestions as to why this might have happened?
Thanks
Chris
Chris Murley - crwdns2934203:0crwdne2934203:0
Instructions appear very thorough, but this would be a little like trying do learn to dance the polka from a written description with photographs. Has someone done a video?
wbeag - crwdns2934203:0crwdne2934203:0
i finished install and it was very easy. But when I completed it and did the calibration for battery it still didn’t turn on. I don’t know what else to trouble shoot now I can’t access computer at all.
Jeremy - crwdns2934203:0crwdne2934203:0
Hi. As some have suggested, it is much easier and less risky to just remove the touch cable and 3 screws, isolate then remove the battery. The battery info now shows '1 cycle' but it still says 'service recommended'. Is there a way to reset this? (aftermarket battery)
bearzac - crwdns2934203:0crwdne2934203:0
Mañana debo reemplazar la batería de un equipo, que la buena vibra me acompañe.
Miguel Lopez - crwdns2934203:0crwdne2934203:0
Hi everybody! Thanks for the guide, I managed to replace my battery following all the instructions. At first I was really scared of doing it, especially after reading through all the comments, but after two months or so I decided to tackle it and I have to say that it is really doable if you follow step by step. Just make sure to be very careful and to plug in everything correctly during reassembly. I used the kit from iFixit which had all the necessary tools. Now my MacBook has some fresh life in it, thanks to you guys. To anyone who is thinking about doing it, you can do it! It was the first time I ever opened a laptop and changed something. It is doable, just trust yourself and be careful! Thank you iFixit!
soytubandolero - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 40
crwdns2936753:07crwdne2936753:0 272
crwdns2936753:030crwdne2936753:0 1,246
crwdns2942667:0crwdne2942667:0 98,008
