Pixel 8 Pro USB‑C Port Cover Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Pixel 8 Pro USB‑C Port Cover Removal, Prepare your Pixel for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Prepare your Pixel for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Prepare your Pixel for disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Pixel 8 Pro USB‑C Port Cover Removal, Mark your opening picks: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Mark your opening picks: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Mark your opening picks: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You'll be using opening picks to separate the screen from the frame. If inserted too far, a pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. Pixel 8 Pro USB‑C Port Cover Removal, Tape over a cracked screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Tape over a cracked screen: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Glass shards can complicate disassembly—or worse, cause injury. If your phone has a cracked screen, follow these steps:
    • Apply overlapping strips of packing tape to the cracked glass until the whole screen is covered.
    • Only cover the glass itself—don't stick any tape to the frame.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  4. Pixel 8 Pro USB‑C Port Cover Removal, Heat the bottom edge adhesive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Adhesive and clips secure the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
    • Heat an iOpener and lay it on the bottom edge of the screen for two minutes to soften the adhesive.
    • Alternatively, you can use a hair dryer, heat gun, or hot plate—but be careful as extreme heat can damage the screen and/or battery.
  5. Pixel 8 Pro USB‑C Port Cover Removal, Secure the Anti-Clamp: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Secure the Anti-Clamp: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Secure the Anti-Clamp: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place your phone screen side up on an object so it will rest level between the Anti-Clamp's arms—the bottom edge should be hanging off.
    • Slide the arms over the left edge of your phone, so you have access to the bottom edge.
    • Position the suction cups as close to the center of the bottom edge as possible.
    • Squeeze the cups together to create suction.
  6. Pixel 8 Pro USB‑C Port Cover Removal, Twist the handle: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Twist the handle: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Twist the handle: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the handle forward to lock the arms.
    • Turn the handle clockwise one full turn (360 degrees), or until the suction cups begin to stretch.
    • As the cups stretch, make sure they stay aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
  7. Pixel 8 Pro USB‑C Port Cover Removal, Insert an opening pick: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Insert an opening pick: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Insert an opening pick: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wait one minute for a gap to form between the screen and frame.
    • If the adhesive doesn't separate, twist the handle clockwise one quarter turn and wait another minute. Apply more heat if the screen cools down.
    • Insert an opening pick into the gap.
    • Don't insert your opening pick more than 3 mm to avoid damaging the spring contacts.
    • Pull the blue handle backwards to unlock the arms and remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
  8. Pixel 8 Pro USB‑C Port Cover Removal, Apply a suction cup: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Apply a suction cup: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a suction handle to the center of the screen's bottom edge.
  9. Pixel 8 Pro USB‑C Port Cover Removal, Insert an opening pick: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Insert an opening pick: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Insert an opening pick: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the suction handle with strong, steady force until a gap forms between the screen and frame.
    • If you're having trouble creating a gap, apply more heat and try again.
  10. Pixel 8 Pro USB‑C Port Cover Removal, Prevent damage to your phone: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Prevent damage to your phone: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To avoid damaging your phone, don't insert your pick more than 3 mm as you separate the screen adhesive. Note the following areas:
    • The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
    • There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
  11. Pixel 8 Pro USB‑C Port Cover Removal, Separate the bottom edge adhesive: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Separate the bottom edge adhesive: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Separate the bottom edge adhesive: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick along the bottom edge to separate the adhesive securing it.
    • Leave the pick in the bottom right corner to prevent the adhesive from resealing.
  12. Pixel 8 Pro USB‑C Port Cover Removal, Heat the right edge adhesive: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the right edge of the screen for two minutes.
  13. Pixel 8 Pro USB‑C Port Cover Removal, Separate the right edge adhesive: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Separate the right edge adhesive: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Separate the right edge adhesive: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a second opening pick under the bottom right corner of the screen.
    • Slide the new pick to the top right corner to separate the adhesive securing the screen's right edge.
    • Leave the pick in the top right corner to prevent the adhesive from resealing.
  14. Pixel 8 Pro USB‑C Port Cover Removal, Leave a pick in the bottom left corner: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Leave a pick in the bottom left corner: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Leave a pick in the bottom left corner: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a third opening pick under the bottom edge of the screen.
    • Slide the new pick to the bottom left corner.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  15. Pixel 8 Pro USB‑C Port Cover Removal, Heat the left edge adhesive: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the left edge of the screen for two minutes.
  16. Pixel 8 Pro USB‑C Port Cover Removal, Separate the left edge adhesive: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Separate the left edge adhesive: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Separate the left edge adhesive: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a fourth opening pick under the bottom left corner of the screen.
    • Slide the new pick to the top left corner to separate the adhesive securing the screen's left edge.
    • Leave the pick in the top left corner to prevent the adhesive from resealing.
  17. Pixel 8 Pro USB‑C Port Cover Removal, Heat the top edge adhesive: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the top edge of the screen for two minutes.
  18. Pixel 8 Pro USB‑C Port Cover Removal, Separate the top edge adhesive: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Separate the top edge adhesive: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a fifth opening pick under the top edge of the screen, near the left corner.
    • Slide the opening pick to the top right corner to separate the adhesive securing the screen's top edge.
  19. Pixel 8 Pro USB‑C Port Cover Removal, Prop up the screen: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Prop up the screen: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cable.
    • Swing up the right edge of the screen like the front cover of a book.
    • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
    • Prop up the screen so you can access the screen cable without straining it.
  20. Pixel 8 Pro USB‑C Port Cover Removal, Remove the screen cable cover: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Remove the screen cable cover: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Remove the screen cable cover: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening tool to pry up the upper edge of the screen cable cover.
    • Remove the cover.
  21. Pixel 8 Pro USB‑C Port Cover Removal, Disconnect the screen: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Disconnect the screen: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Disconnect the screen: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of a spudger under the top right corner of the screen's press connector.
    • Gently pry up and disconnect the cable.
    • Remove the screen.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  22. Pixel 8 Pro USB‑C Port Cover Removal, Screen information: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
  23. Pixel 8 Pro USB‑C Port Cover Removal, Reassembly information: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Reassembly information: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Reassembly information: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you're installing a new screen with pre-installed adhesive, follow this step during reassembly. Otherwise, follow this guide to apply adhesive to your old screen.
    • Thoroughly check the entire screen for any plastic liners or tape and use the pull tabs to remove all of them. Look carefully for a large piece of plastic covering the back of the screen, a small one near the front camera cutout, and adhesive liners around the perimeter.
    • Reconnect the screen cable and reinstall its cover.
    • This is a good point to test your phone before sealing it up. Temporarily power on your phone and make sure it works as expected. Power it down before continuing.
    • Firmly press the screen into place on the frame—you should feel the clips "pop" into place.
    • Press firmly around the perimeter of the screen to secure it with the new adhesive.
    • Optionally, you can strengthen the adhesive bond by applying pressure evenly to the phone.
    • Follow this guide to calibrate the fingerprint sensor.
  24. Pixel 8 Pro USB‑C Port Cover Removal, Move the USB‑C cover tape: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Move the USB‑C cover tape: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Move the USB‑C cover tape: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of a spudger to gently lift the plastic shim that runs along the top of the USB-C port cover.
    • Remove the shim and set it aside or move it out of the way so you can access the USB-C port cover screws.
  25. Pixel 8 Pro USB‑C Port Cover Removal, Reassembly information: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Reassembly information: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Reassembly information: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • During reassembly, follow this step to replace the plastic shim that runs across the bottom of the midframe and loudspeaker. If you don't have a replacement, press the old one back into place.
    • Remove the larger rectangular liner from the shim.
    • Place the shim so the smaller piece of foam lines up with the bottom of the USB-C port cover.
    • Use the flat end of a spudger to firmly press down along the whole shim to secure it.
    • Remove the remaining liner.
  26. Pixel 8 Pro USB‑C Port Cover Removal, Remove the USB‑C port cover: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Remove the USB‑C port cover: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pixel 8 Pro USB‑C Port Cover Removal, Remove the USB‑C port cover: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    FixMat
    $36.95
    • While the Pixel 8 Pro uses Torx Plus screws, standard Torx bits will also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a T3 Torx screwdriver to remove the two 5 mm‑long 3IP Torx Plus screws securing the USB‑C port cover.
    • Remove the cover.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
118,659 crwdns2915208:0crwdne2915208:0
crwdns2935297:0837crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,567crwdne2935297:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 64
