Motorola Moto G Power (2020) Battery Replacement
  1. Motorola Moto G Power (2020) Battery Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Position a suction cup securely on the back panel of the device.
    • Insert the opening pick into both sides of the phone and carefully slide it along to open the back panel of the device.
    • Do not fully remove the back panel; disconnect the fingerprint sensor first.
    I am finding it extremely difficult to find an insertion point between the casing and the screen. I've even brought a Stanley No. 199 Utility knife into play. Still, no separation. These instructions should include the use of a heat gun to soften the adhesive that holds the case and screen together. I may have to bring this to a cell phone repair shop.
    Jerry Weinhausen - crwdns2934203:0crwdne2934203:0
    Light heat with a blowdryer/heatgun will help it flex more, but you can do it this way. It's definitely challenging as you have to pull on the suction cup close to the edge and you might only get like .5mm of gap.
    If you don't have a good spudger or thin piicks like in the picture, heat gun is absolutely necessary.
    Zach M -
    One thing to note: be careful with a spudger or prying near the right side of the phone. A small wire runs from top to bottom of the phone about 5mm past the phone edge. You can see it in the pictures, it's a black wire that's very tiny. It's easy to see in Step 7 where it connects to the board above the right corner of the battery.
    Zach M - crwdns2934203:0crwdne2934203:0
    I had a terrible time with the adhesive on the back cover, I lost most of the black film around the camera lens and some around the middle of the bottom edge. I put modest effort towards reinstalling the touch sensor into the back cover, but since I use an external case I did not go overboard. I did test the touch sensor before firmly seating the back cover into the remaining adhesive.
    Richard Ekblaw - crwdns2934203:0crwdne2934203:0
  2. Motorola Moto G Power (2020) Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply gentle pressure to the fingerprint sensor with your finger to detach it from the back panel.
    • You may need to apply firm pressure to remove the circular sensor from the panel.
  3. Motorola Moto G Power (2020) Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fully remove the back panel from the device.
  4. Motorola Moto G Power (2020) Battery Replacement, Fingerprint Sensor: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Torx T3 screwdriver, remove nine 2.2 mm screws.
    When I re-installed the back cover, I found that the left side around the camera lenses was the hardest part to get back into place, so I put the 4 left screws in first (lower left corner, then upper left corner, then left of the 3 lenses, then lower right of the top lens). I don't know what torque spec they use in the factory, but only 2 of the 9 screws came out easily so I put them back in with the "stop when you feel resistance" standard.
  5. Motorola Moto G Power (2020) Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Moto G Power (2020) Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Moto G Power (2020) Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger to gently lift the cover.
    • If needed, use the spudger's tip against a corner of the cover to help lift it.
    • Set the back cover aside.
    • DO NOT use excessive force when lifting up the back cover.
    As shown, the bottom left corner is a good place for the first lift of the cover, then the bottom right side which should release the bottom edge, then pivot the cover up toward the top, and it should lift off easily.
  6. Motorola Moto G Power (2020) Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully use the spudger to lift the sensor cable, disconnecting the fingerprint sensor from the motherboard.
    • WARNING: Handle the sensor cable with care; it can be easily damaged.
  7. Motorola Moto G Power (2020) Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the fingerprint sensor from the device and set it aside.
    • Do not use excessive force when lifting the back cover or any other component.
  8. Motorola Moto G Power (2020) Battery Replacement, Protective tape: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If present, carefully remove the protective tape using a plastic spudger as shown, ensuring the delicate flex cable is not torn in the process.
    • Be careful to not puncture or bend the battery! If punctured, it could start a fire. This is why we recommend discharging your device below 20% before beginning any repairs. Combustion could potentially cause damage to the device and your skin/clothing.
  9. Motorola Moto G Power (2020) Battery Replacement, Disconnect the flex cable: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G Power (2020) Battery Replacement, Disconnect the flex cable: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic spudger or non-conductive tweezers to disconnect the battery cable from the motherboard.
    • Ensure the tweezers are not pointed or sharp. Be gentle to avoid tearing the flex cable. This could cause a short-circuit in the battery connector, or scratch and damage traces on the motherboard.
  10. Motorola Moto G Power (2020) Battery Replacement, Seperate the old battery from the frame: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Moto G Power (2020) Battery Replacement, Seperate the old battery from the frame: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide an opening pick under the battery and gently work it back and forth to separate the adhesive from the battery.
    • This adhesive is quite strong and will require careful attention to apply the correct amount of force to remove the battery without damaging it in the process. Be patient and take it slow.
    It was at this point that I completely destroyed my plastic pick, so I used the blade of a utility knife (removed from the knife, just using the bare blade) to pry each side of the battery in turn. After 4 or 5 pry times on each side, I used a blade on each side to lift the battery out, that worked quite well.
  11. Motorola Moto G Power (2020) Battery Replacement, Out with the old, in with the new: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the old battery and insert the replacement battery, connecting it to the motherboard.
    • (Optional) Two-sided tape can be used to secure the battery to the frame if the original adhesive isn't strong enough to keep the new battery in place also.
    You complete the reassembly by doing everything I Reverse I understand that ... but you don't say anything about securing the back cover in place do you use 1/8" double sided Tape or an Adhesive / Glue Thanks for these instructions VERY well Done except for attaching the back cover LOL. HAPPY NEW YEAR
    Jax One - crwdns2934203:0crwdne2934203:0
    What about attaching the back cover onto the phone ? Do you use 1/8" double sided tape or an adhesive glue ? Please reply and Thank You so much for this information here. its Greatly appreciated
To reassemble your device, follow these instructions in reverse order, excluding the battery removal, of course.
Harry Jung
crwdns2935283:006/23/22crwdne2935283:0
769 crwdns2915208:0crwdne2915208:0
UC Santa Barbara, Team 1-1, Bator Summer 2022 crwdns2935289:0UC Santa Barbara, Team 1-1, Bator Summer 2022crwdne2935289:0
UCSB-BATOR-SU22S1G1
crwdns2947412:07crwdne2947412:0
THIS OS THE WRONG BATTERY!!!!! IT's ABOUT 1/4" TOO LONG!!! WTF?!?!?!
Tweedle - crwdns2934203:0crwdne2934203:0
You link to the 'replacement" battery all say it's for the G Power (2022) but the GUIDE AND MY PHONE ARE THE 2020!!!!!
Your link goes to the JK50 battery.... but my Motorola g Power (2020) uses a KZ50 !!!! - OM<G I NEED MY PHONE!!!! AND NOW I HAVE TO WAIT TO SEND IT BACK, GET THE REFUND, AND THEN WAIT FOR THEM TO SEND BACK THE RIGHT ONE?!?!?!? - As you can tell because I OWN A CHEAP P.O.S. phone I CANNOT AFFORD TO 'just buy another one" ARRGGHHH!!!!!
Oh and my finger print sensor even broke off too... I tried SOOOO HARD not to break the wire... but it moved less than a 1/2" away and had already split.....
DO NOT BUY THIS PHONE!!! - Now I have no fingerprint sensor, the phone is NO LONGER WATER PROOF, AND IT DOESN'T EVEN WORK RIGHT NOW!!!!! AAARRGGGGHHHHH!!!!!!!!!!!! :'(
How hard would it be for phone manufacturers to create a back cover to access battery for replacement...but NO, they make it as difficult as possible so they can make money selling new phones and/or sell repair services.
Tony Kawon - crwdns2934203:0crwdne2934203:0
I was an LG phone customer for many years because they were the last ones selling smart phones with user replaceable batteries. When they quit making their phones like that I switched to Motorola because i do like them better overall
Cee64E -
I purchased my "not Motorola" KZ50 battery from an eBay seller, it was a drop-in replacement for the original battery. I did have to do my own "fold" for the flex cable, not a big deal. I used my own T3 screwdriver, the "free" tools included with the battery are worth what I paid for them.
This guide worked great for me! Thank you. However, a couple of suggestions to make it a bit better. On the first step, I had a little trouble separating the back. The back is attached with glue (the guide doesn't say this) and I wasn't exactly sure which grove on the edge was the back. And edge picture would be helpful. Also, while removing the back, most of the glue came off the back and was unusable for re-assembly. Some suggestion on how to deal with that would be helpful. I used a bit of double stick tape, which seems to work ok, but I'm mostly relying my protective phone case to hold it together.
Matt J - crwdns2934203:0crwdne2934203:0
Ok, I looked at some other guides on this site and found a great deal more detail and help. So while this guide worked, but it's pretty lacking in detail. Take a look at this one for example, and how much information it has about how to soften the adhesives, notes on re-assembling the connectors, and links to re-assembling adhesive-attached parts. Motorola Moto G Play (2021) Screen Replacement
Matt J -
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 67
crwdns2936753:030crwdne2936753:0 232
crwdns2942667:0crwdne2942667:0 9,610
