This guide demonstrates how to replace the LCD display panel in your 2022 Motorola Moto G.
Note: This procedure is for a screen without the frame (a.k.a. chassis). If you're replacing the screen with a genuine Motorola screen pre-installed in a new frame, follow this guide instead.
Before you begin, download the Software Fix app to backup your device and diagnose whether your problem is software or hardware related.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Insert a SIM card eject tool or a straightened paperclip into the hole adjacent to the SIM card tray.
Press firmly to eject the tray.
Remove the SIM card tray from the phone.
I need a new Sims card tray for xT2271DL
Can you please send me a new phone with the same number
Take note of the following seams along the edge of the phone:
Screen seam: This seam separates the display panel from the frame. Don't pry at this seam.
Bezel seam: This is where the plastic back cover meets the rest of the phone. It's held in place by plastic clips. This is where you should pry.
Insert an opening tool in the bezel seam halfway between the bottom-right corner of the phone and the power button.
Insert an opening pick in the gap you just created.
This is my first phone repair using a guide like this. However, this step is...completely and totally useless! That is especially true if the battery is inflated, which is what this guide should assume is why someone would be here in the first place. Attempting to open the case on the side with the power/volume buttons just marred the plastic and accomplished nothing. I found a much easier way to get the initial opening pick inserted that doesn't damage the case: Use the SIM card slot as the entry point instead of the method shown here. You have to be gentle with the opening tool since the plastic for the slot is pretty thin, but I couldn't get in any other way. Use the blue opening tool in the SIM card slot to pull the plastic away just enough to insert the pick into the top as shown. Then go to town on popping the clips. Getting around corners with the opening picks is still really tough AND there's no mention in this guide that Motorola applied glue around the cameras.
Slide your opening pick toward the bottom-right corner of the back cover and release the clips.
Continue sliding your opening pick towards the bottom left corner to unclip the bottom edge of the back cover.
Slide your opening pick toward the top left corner to unclip the left side of the back cover.
Slide your pick around the top left corner and along the top edge to release the clips.
Slide your pick around the top right corner to release the last clips securing the back cover.
With SIM card slot facing you, swing the back cover open and away from you like you're opening a book.
Rest the cover parallel to the frame.
My version has a finger print scanner on the back cover and the integrated side buttons. The only connection to the back cover was the scanner. The power and volume buttons are built into the side of the frame.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers or your fingers to unhook the power button's rubber arm from its recess and remove it.
You're now left with the back cover.
Don't forget to clip the hyperchloric fuu b button to discharge the static or you may cause a Cascade of fried chips on your circuit board it's located behind the power button don't skip this step or you'll fry the phone
Use a PH00 screwdriver to remove the two 3.9 mm-long screws securing the power button cable bracket.
Use your fingers or a pair of blunt nose tweezers to grab and remove the bracket from the power button cable.
And don't neglect the interconnect routine b and c this is vital!
Unintended pregnancies have resulted. Divide this make sure you marry the components then it's okay 👍
Use the pointed end of a spudger to pry up and disconnect the power button's press connector.
Looking for the on off volume control how to
I was looking for the on off volume button replacement?
Hi Stan! The volume buttons are held in the back cover, which comes off earlier in the repair. We don't have a dedicated guide to replace just the volume buttons, but, beginning at this step, you can get an idea for how to replace the buttons and their cable. If you only need to replace the plastic piece, you might start by looking at the back cover. Good luck!
I find using the fudger works better I find using the correct tool makes this job of breeze unfortunately it's not included in most tool kits 0 check with batteries R us
Grab and remove the power button.
But if you're bored a good fire can brighten up your day!
I enjoyed seeing a cell phone repairman go up in flames he was a jerk anyway
Use your Phillips screwdriver to remove the eight 3.9 mm-long screws securing the motherboard cover.
And trust me the motherboard can be a mother you know what!
Insert an opening pick between the bottom-left corner of the cover and the motherboard.
Pry up to release the cover's small clips securing it to the frame.
Grab and remove the motherboard cover from the phone.
The finger print scanner on the back cover couldn't be disconnected until after the motherboard cover was removed. Therefore the back cover could not be moved out of the way until the scanner was disconnected at this point.
Use the pointed end of a spudger to pry and disconnect the battery's press connector.
Heat an iOpener and apply it to the left edge of the screen for about two minutes.
Apply the isopropyl alcohol into the gaps between the sides of the battery and the frame.
Apply a suction cup to the battery, as close to the center of the right edge as possible.
Insert an opening pick between the right edge of the battery and the frame.
Pull on the suction cup and pry the battery upward.
Lift the battery out of its recess and remove it.
Peel and remove the foam strip from the bottom of the battery.
Be sure to apply five drops of super glue to the corners you don't want it coming loose.
Be careful don't stick your fingers together or your girlfriend will be disappointed after all most like two or three but not four or five
Use your tweezers to grab and peel the graphite film off the display cable's press connector.
Use the pointed end of your spudger to pry and disconnect the display cable's press connector.
Heat an iOpener and apply it to the display cable for two minutes.
Grab the display's ribbon cable near the connector.
Peel the cable toward the bottom of the phone until it's completely separated from the frame.
Place the back cover over the frame of the phone
Press around the perimeter to re-engage the clips securing the cover.
Heat an iOpener and apply it to the top of the screen for two minutes.
Apply a suction cup to the screen, as close to the center of the top edge as possible.
Insert an opening pick vertically into the shallow cutout in the top of the glass, as far right as possible.
Pull up on the suction cup with a strong, steady force.
Angle the opening pick to about 30 degrees, firmly slide it toward the right corner of the display, and separate the adhesive.
Slide the opening pick toward the bottom right corner to separate the right edge's adhesive.
Slide the opening pick toward the bottom left corner to separate the bottom edge's adhesive.
Slide the pick along the left edge to completely separate the display panel from the frame.
Grab and pull the bottom of the display panel down and away from the frame, making sure to thread the display cable through its slot.
Once the display cable is free, remove the panel from the frame.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
crwdns2935229:05crwdne2935229:0
How do I replace the edge of my phone just need some help trying to do that
Hi Johnny,
If you're looking to replace the border around the perimeter of your phone, then this would be a back cover replacement. The back cover includes the edge of the case, right up to the screen bezel.
Hi
I have a Motorola Moto G 5G Plus and now the front screen has cracked, how do I replace it?
