Microsoft Surface Pro 7 Screen Replacement
Sam Omiotek
crwdns2944107:0crwdnd2944107:0Sam Omiotekcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:06crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Kho 9, 2025crwdne2944111:0
1 - 2 crwdns2931253:0crwdne2931253:0
crwdns2937803:0crwdne2937803:0
crwdns2862627:0crwdne2862627:0
crwdns2942287:0crwdne2942287:0
Follow this guide to replace the screen on a Microsoft Surface Pro 7.
There is a significant chance that you may break the unreinforced and fragile display panel during this procedure. Be sure to apply adequate heat and be extremely careful while slicing through the adhesive. Wear safety glasses in case the glass shatters.
crwdns2942269:0crwdne2942269:0
crwdns2942337:0crwdne2942337:0
crwdns2944105:0crwdne2944105:0
  1. Microsoft Surface Pro 7 Screen Replacement, Tape the screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement, Tape the screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement, Tape the screen: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    • Lay overlapping strips of clear packing tape over the Surface’s display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
  2. Microsoft Surface Pro 7 Screen Replacement, Heat the right edge of the screen: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Completely power off the Surface before you begin disassembly.
    • Heat an iOpener and apply it to the right edge of the Surface's screen for two minutes.
    • You may need to reheat and reapply the iOpener several times to get the tablet warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer or heat gun may also be used for more heat, but be careful not to overheat the Surface—the screen and internal battery are susceptible to heat damage.
  3. Microsoft Surface Pro 7 Screen Replacement, Take note of the adhesive layout: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take note of the screen adhesive layout before continuing:
    • These areas only contain adhesive and are safe to cut.
    • The display board and flex cables sit here close to the edge. Cut carefully and do not insert the pick more than 1/8 inch (3 mm).
    • Fragile antenna cables lie under this part of the screen. Carefully follow the procedure in step 13 to avoid damaging them. The adhesive is also the thickest here.
    Be prepared; the bluetooth/wifi antennas are adhered to the glass with this very strong tape. You WILL 98% of the time damage them; have another module available that includes the antennas before you attempt this repair as you will damage them if you've never done this repair before. Ive done dozens of these and damage most of them.
    Gregg Stanley - crwdns2934203:0crwdne2934203:0
    For tablets without swollen batteries you can use one of these: https://www.amazon.com/gp/product/B019PX...
    For tablets with swollen batteries, you can use one of these: https://www.amazon.com/220V-300W-Tool-Bl...
    Just be careful that you don't damage the touchscreen by heating one spot too much. Also, the trick is to get the pick against the back of the display above the adhesive.
    David S. -
    I managed to remove the screen successfully without breaking the glass, but I found out I completely sliced through cables underneath the lower portion of the display as I used a razor blade, so be careful!
    Muhammad BahaaElDin - crwdns2934203:0crwdne2934203:0
    Muhammad, if you are still looking at this, what do the antennas connect to> I can't find the antennas on my glass, nor where they would connect to the frame?
    Thomas Hayes -
  4. Microsoft Surface Pro 7 Screen Replacement, Insert an opening pick into the speaker opening: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement, Insert an opening pick into the speaker opening: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick into the speaker opening on the screen and slide the pick between the glass and speaker grille.
    • Don't insert the opening pick any deeper than the black bezel on the edge of the screen. Inserting the pick too far may damage the LCD.
    Note carefully where they start. It is the only place with any sort of access. Razor blade is best. Use picks to hold the top open. Do NOT insert more than a quarter inch ever.
    Thomas Hayes - crwdns2934203:0crwdne2934203:0
  5. Microsoft Surface Pro 7 Screen Replacement, Slide the opening pick under the screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement, Slide the opening pick under the screen: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the pick toward the bottom of the Surface to slide it underneath the lower edge of the speaker cutout.
  6. Microsoft Surface Pro 7 Screen Replacement, Cut through the screen adhesive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement, Cut through the screen adhesive: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the pick down the right edge of the Surface to slice through the adhesive under the screen.
    • Throughout the rest of the procedure, if you encounter significant resistance while sliding the pick, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass.
    • Leave this opening pick in the right edge to prevent the adhesive from resealing.
  7. Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reheat your iOpener and apply it to the bottom edge of the Surface's screen for two minutes.
  8. Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a new opening pick into the bottom right corner and slide it around the corner toward the bottom edge.
    • Don't insert the opening pick any deeper than the black bezel on the side of the screen. Inserting the pick too far may damage the LCD.
    • Slide the pick along the bottom edge of the Surface to cut through the screen adhesive.
    • Leave this pick in the bottom edge to prevent the adhesive from resealing.
  9. Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reheat your iOpener and apply it to the left edge of the Surface's screen for two minutes.
  10. Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a new opening pick into the bottom left corner and slide it around the corner toward the left edge.
    • Be careful cutting under the lower 2.5 inches (65 mm) of the left edge. Do not insert the opening pick more than 1/8 inch (3 mm) here. The display cables sit near this part of the bezel and are easily damaged. Once past the display cable area, do not insert the pick past the bezel.
    • Slide the pick along the left edge of the Surface to cut through the screen adhesive.
    • Leave this pick in the left edge to prevent the adhesive from resealing.
  11. Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The adhesive is thickest along this edge, and you may need to reheat and reapply the iOpener several times to get the tablet warm enough. Follow the iOpener instructions to avoid overheating.
  12. Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Round the left corner with the opening pick and slide it along the top edge of the Surface. Stop when the pick is 2.75 inches (70 mm) away from the left edge.
    • The next 6 inches (15 cm) of the top edge of the case is covered by the left and right antennas, which sit between the case and the screen bezel. Follow the next steps carefully to avoid damaging the antennas.
  13. Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Fragile antenna cables lie under the top edge of the screen. Carefully follow the procedure to avoid damaging them.
    • Insert the point of a pick under the display where you just stopped cutting. Do not insert the pick deeper than the edge of the bezel.
    • Carefully roll the pick to the right, pressing the long edge of the pick into the screen adhesive underneath the bezel, cutting the adhesive as you go. Do not slide the pick along the edge of the Surface.
    • Repeat this motion of inserting the point of the pick where you just cut, and rolling to the right all along the top edge of the Surface, until the pick is 2.5 inches (64 mm) from the right edge of the Surface.
    Die WLAN-Antennen sind durch eine Plastikabdeckung geschützt und können nur durch wirklich rohe Gewalt beschädigt werden.
    sdufter - crwdns2934203:0crwdne2934203:0
  14. Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once you cut the adhesive over the antennas (8.5 inches, or 22 cm, from the left edge), slide the pick the rest of the way along the top edge of the surface and round the top right corner to slice through any remaining adhesive.
  15. Microsoft Surface Pro 7 Screen Replacement, Open the Surface: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement, Open the Surface: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Very slowly lift the screen assembly away from the Surface case. If you encounter any resistance, stop and check that all the adhesive is separated.
    • Do not remove the screen yet. It is still connected to the motherboard by two cables.
    • Use an opening pick to cut through any remaining adhesive.
    • The flash lens may fall out of the Surface case. Keep track of the lens and return it to its cutout in the case during reassembly.
    Be sure to lift the top first ( camera side) as the ribbon cable have more give that way. I tore one of the cables trying to open from the bottom
    Joel Mills - crwdns2934203:0crwdne2934203:0
  16. Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure you have your tweezers and spudger within reach.
    • Lift the top of the screen assembly away from the case while sliding the bottom of the screen closer to the motherboard display connectors.
    • Do not put any tension on the display ribbon cables.
    • Use one hand to hold the screen still.
  17. Microsoft Surface Pro 7 Screen Replacement, Disconnect the battery: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement, Disconnect the battery: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement, Disconnect the battery: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed tip of a spudger to carefully push on each side of the battery connector.
    • Alternating from one side to the other, gently “walk” the connector out of its socket.
  18. Microsoft Surface Pro 7 Screen Replacement, Disconnect the display cables: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement, Disconnect the display cables: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement, Disconnect the display cables: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to peel back the silver tape covering the left display cable connector.
    • Do not remove the tape from the ribbon cable.
    • Insert the flat end of a spudger underneath the tape and pry up on the connector to disconnect it from the motherboard.
    I found that the replacement screen cable does not run the same way as the previous screen and it actually doubles over. Is there a reason for this? Can I get a cable that matches the new screen anywhere?
    Greg Child - crwdns2934203:0crwdne2934203:0
  19. Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to peel back the silver tape securing the right display cable to the motherboard.
    • Use the flat end of a spudger to lift the right display cable straight up and disconnect it from the motherboard.
  20. Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  21. Microsoft Surface Pro 7 Screen Replacement, Remove the display cables: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an opening pick to pry up one edge of the EMI shield covering the display board.
    • Try not to deform the shield too much—you will need to reinstall it during reassembly.
    • During reassembly, make sure the EMI shield "teeth" touch the conductive strips on the top of the ribbon cables.
  22. Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the EMI shield away from the display board and remove it.
  23. Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry the display interconnect cable straight up and out of its socket on the board.
  24. Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening tool to pry up one end of the EMI shield covering the second display cable.
    • Remove the EMI shield.
    • During reassembly, make sure the "teeth" touch the gold conductive strip on the top of the ribbon cable.
  25. Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to pry the digitizer connector straight up and out of its socket on the screen.
  26. Microsoft Surface Pro 7 Screen Replacement, Disconnect the display board: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement, Disconnect the display board: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement, Disconnect the display board: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to flip up the small locking flaps on the display cable ZIF connectors.
  27. Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to slide the display cables straight out of their sockets on the display board.
    • During reassembly, if you're installing a new screen, remove any liners on the bottom of the display cables to expose their conductive strips.
  28. Microsoft Surface Pro 7 Screen Replacement, Remove the display board: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement, Remove the display board: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Replacement, Remove the display board: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide an opening pick under the display board to separate the adhesive holding it onto the back of the screen.
    • If the adhesive is stubborn, it may help to heat the display board using an iOpener, hair dryer, or heat gun. Take care not to overheat the screen.
  29. Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the display board.
    • During reassembly, remove the adhesive from under the display board with isopropyl alcohol (≥90%) and a lint-free cloth or coffee filter. Then, apply new conductive adhesive, like double-sided copper tape, and secure it to the new screen.
    Que tipo de adesivo se recomienda? Se necesita que conduzca la electricidad?
    Iván Daniel Plasencia González - crwdns2934203:0crwdne2934203:0
  30. Microsoft Surface Pro 7 Screen Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Only the screen remains.
    Handig om te weten is dat er voor de Surface Pro 4 twee verschillende schermen zijn...een Samsung en een LG. Dus voordat je een scherm aanschaft moet je eerst weten welke er in je Surface Pro 4 zit.
    Eric B - crwdns2934203:0crwdne2934203:0
    Hallo das Display auf der Rückseite hat ca. 4 kreisförmige schwarze runde matten/gumipolster und vier große.
    rund herum ist auf der kanne ebenfalls ein Klebestreifen angebracht. wo bekomme ich diese teile oder Klebestreifen?
    Welche auswirkungen kann es haben wenn das Display hinten dies nicht aufweist?
    Ein Link wäre sehr hilfreich.
    Danke
    Panagiotis - crwdns2934203:0crwdne2934203:0
crwdns2935229:037crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
87,611 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
crwdns2947412:028crwdne2947412:0
Can you recommend a specific seller for the display, I’ll need to replace my screen before long. Thanks!
Eric Fike - crwdns2934203:0crwdne2934203:0
What type of glue for reassembly? What temperature of heat setting do you recommend?
Anthony Finch - crwdns2934203:0crwdne2934203:0
I managed to remove the old screen, clean off the old adhesive, apply new adhesive but not remove the backing yet. I connected the new screen and cables back the original way. I then uninstalled the touch drivers and restarted the surface. The touch function on the screen is still not working, any furthur suggestions?
Bryce Stevenson - crwdns2934203:0crwdne2934203:0
Probably you have issues with board.
Matjaž -
@bryce Stevenson tries connections also the ribbon cable connecting digitizer and LCD. I would assume the screen is faulty defective if that doesn’t work!
Mark D Schlossman - crwdns2934203:0crwdne2934203:0
Note that pictures here do not include a portion of the "Antenna Wireless WiFi Cover Trim Flex Cable" at the top on either side of the Surface's cameras underneath the screen. There are two thin soft layers that can be pulled away from that assembly during screen removal.
There are warnings about this, but it is difficult to do well. Especially without good reference photos to know what to expect.
Also, the iOpener method doesn't personally seem feasible having attempted it. Would suggest heating pad. (Or heat gun as recommended, but beware as edges of case are easily tarnished by prolonged or high heat.)
Phillip Procyk - crwdns2934203:0crwdne2934203:0
Just a heads up, this is so much more difficult when the entire screen is cracked. Instead of being able to just separate the screen by sliding the opening pick, you will have to scrape off each small piece of glass from the adhesive along the edge. The one section of my screen that wasn't cracked was super easy to separate from the adhesive with a heat gun. That being said, I have installed the new screen, and everything does seem to be in good working order.
One more tip, if you broke your screen with a drop, inspect the frame and make sure it isn't bent in and would otherwise not allow the new screen to sit inside flush. My top right corner that had damage from impact has the frame bent in so that the screen corner sits on top of the frame instead of within it. No good way to bend the metal out with the screen stuck to the new adhesive. Just double check and fix it before installing the new screen!
Ron Ron Cheng - crwdns2934203:0crwdne2934203:0
I removed the old screen and cleaned off the adhesive. Plugged in the new screen's ribbon cables and attempted to power it back on. I get the Windows logo to appear and it quickly returns to black screen. However the system continues to boot and I am even able to log in when I plug it into an external monitor. Do you have any suggestions for how to troubleshoot it further?
Kyle Lawson - crwdns2934203:0crwdne2934203:0
I had to re-seat the ZIF connectors (step 26) 3 times before it worked
Ben -
What device is used for this tutorial?
I ask because of a couple of factors;
1) the screen in the tutorial has a silver block to the left (looking at back of LCD) of the LCD ribbon connector; however the original LCD for the Surface Pro 7 (and the photos of the replacement you sell) does not have that.
-- This causes the LCD flex cable to be too short to replace the screen--
Looking at the tutorial it appeared that I had the correct replacement screen, but in fact, I did not. not your fault, but it does make it difficult to rely on your guide to be accurate if it is not of the actual device you say it is for.
Thomas Niegisch - crwdns2934203:0crwdne2934203:0
I did a lot of digging into this; it appears Microsoft made two versions of their LCD (LP123WQ1 & LP123WQ2) the one in this Guide is version 1 (Q1 of the two options) but Version 2 uses a smaller Cable and has the connector farther to the left than Version 1
Just saying to let people know that you need to be aware of this going into it; unfortunately, there is no way to know which version you have unless you open it up and remove the old one before you order the new one.
Thomas Niegisch -
I bought wrong model of display too (LP123WQ2 from iFixit)
But after that I ordered cable for this display (LCD Flex Cable for Microsoft Surface Pro 7 1866 ) - and could attach display.
So, not it works good!
Виктор Ганелес -
Does this include lcd and digitizer??
donavan - crwdns2934203:0crwdne2934203:0
Is it possible to replace surface pro 7 plus screen with surface pro 7
KABYLION - crwdns2934203:0crwdne2934203:0
Bonjour, j'ai fait le changement de l'écran mais je n'ai pas gardé l'adhésif comme indiqué (je n'ai pas bien lu). Savez-vous ou je peux me procurer un adhésif similaire?
Avec mes meilleures salutations.
Nicolas Vauthey - crwdns2934203:0crwdne2934203:0
Hello, I changed the screen but I didn't keep the adhesive as indicated (I didn't read it correctly). Do you know where I can get a similar adhesive?
With my best regards.
Hello I have a working machine after doing this repair but its very dark even with adaptive brightness off and brightness up full. please does anyone have any suggestions? Thanks
Ben - crwdns2934203:0crwdne2934203:0
ive replaced surace pro 7 screens in the past using i fix it procedures. im in the process of fixing another screen and was browsing screens and found screens that stated "no frame". ive never seen the term beforeand wanted clarification. is the frame the metal board that supports the lcd/digitizer?
dubby - crwdns2934203:0crwdne2934203:0
Hi! The version for sale on iFixit (https://www.ifixit.com/products/surface-...) is not specified.
There are two versions of this screen. Version 1 and Version 2. They are incompatible based on their connectors. Completely indistinguishable from the outside (because Microsoft has to make it even harder to repair it by making sure you can't order the screen before disassembly). Physically the connector is the same, but it is in a different place, so the screen will not align properly if you get the wrong version replacement.
What version is it for sale on the iFixit page?
Justin Castle - crwdns2934203:0crwdne2934203:0
Comments did not load when I originally made this comment, but was answered by Thomas Niegisch and Виктор Ганелес above; iFixit sells the V2 of the screen only, so if you need V1 you should find somewhere else to purchase.
Justin Castle -
What can you do if the screen is shattered?
Nicole Willis - crwdns2934203:0crwdne2934203:0
I just ordered a screen on eBay. It came with a board, so changed it including that board. Reassembled, but it would not work (touch screen). I reopened to put the old board in and it kind of worked. There is a blind area vertical right in the middle of the screen top to bottom. I assumed it’s the screen. Ordered another screen… same thing. Exchanged the board again: no touch screen. Ordered new ribbon cable and another board: no success (screen works, touch does not). Put in original board: screen and touch work, but touch is with blind spot and at the edges not responsive with finger….
What am I missing? Any ideas?
Christoph Wesselburg - crwdns2934203:0crwdne2934203:0
I went through the process of removing the screen to repair a broken hinge, and now my screen is showing broken lines up/down and left/right. The larger ribbon cable had torn during removal and I replaced it. There are no visible cracks when the screen is off but there is a clear line in the screen like a break when it is on. Is this most likely a broken screen or a bad cable? If anyone can help I'd appreciate it.
Hi! I managed to break both display cables when removing the screen. Does your kit come with cables as well? If not, is it possible to order them along with the screen?
Syvert Fossdal - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 44
crwdns2936753:07crwdne2936753:0 217
crwdns2936753:030crwdne2936753:0 1,037
crwdns2942667:0crwdne2942667:0 89,022
