Microsoft Surface Pro 7 Kickstand Replacement
  1. Microsoft Surface Pro 7 Kickstand Replacement, Open the kickstand: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Kickstand Replacement, Open the kickstand: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Kickstand Replacement, Open the kickstand: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the kickstand to expose the hinge screws.
  2. Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 2.7 mm T3 screws—two on each side of the kickstand.
  3. Microsoft Surface Pro 7 Kickstand Replacement, Close the kickstand: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Kickstand Replacement, Close the kickstand: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Kickstand Replacement, Close the kickstand: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move the kickstand back down to a flat position.
    • The hinges are stiff and you may need to use some force to get it down.
  4. Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the kickstand from the back cover.
    • There are two adhesive tabs in the middle of the kickstand that disengage most easily when the kickstand is pulled directly downward from the device.
    • Be sure to insert these tabs when reinstalling the new kickstand before replacing the screws.
    Heute selbst durchgeführt. Hilfreich wäre, die Beschreibung um folgende Info zu ergänzen: wie man die Scharniere nach Schritt 4 wieder aus den Einbuchtungen im Gehäuse hochgestellt bekommt, um das neue Kickstand zu montieren. Nach eigenen Überlegungen konnte ich die Schaniere durch Einführen des benutzten Torx-Schraubenziehers in die äußere Schraubenbohrung des Scharniers und ganz behutsamen Hochdrücken des Scharniers mit Hilfe des Schraubenziehers lösen.
    Oliver Bendig - crwdns2934203:0crwdne2934203:0
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
87 301 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
One of the hinges broke on my Surface Pro 6.
1. I removed the broken hinge, closed the kickstand and duct taped the seam.
2. I opened the kickstand wide and duct taped the seam.
The single hinge and duct tape seem to be working!
"Spare the duct tape, spoil the job." - Red Green
P Best - crwdns2934203:0crwdne2934203:0
What are the parts used for this fix?
Andrea Shaw - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 114
crwdns2942667:0crwdne2942667:0 8,781
