MacBook Pro 13" Function Keys Late 2016 Battery Replacement
Jeff Suovanen
crwdns2944107:0crwdnd2944107:0Jeff Suovanencrwdnd2944107:0crwdnd2944107:0crwdnd2944107:09crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Kul 5, 2025crwdne2944111:0
1 - 2 crwdns2931253:0crwdne2931253:0
crwdns2937801:0crwdne2937801:0
crwdns2862627:0crwdne2862627:0
crwdns2942287:0crwdne2942287:0
Use this guide to safely remove the glued-in battery from your MacBook Pro with the help of an iFixit kit with adhesive remover. The adhesive remover will dissolve the adhesive securing the battery, allowing you to remove it with ease.
iFixit adhesive remover is flammable. Perform this procedure in a well-ventilated area. Do not smoke or work near an open flame during this procedure.
To minimize risk of damage, turn on your MacBook and allow the battery to fully discharge before starting this procedure. A charged lithium-ion battery can create a dangerous and uncontrollable fire if accidentally punctured. If your battery is swollen, take extra precautions.
Note: The solvent used to dissolve the battery adhesive can damage certain plastics. Follow all instructions and take care where you apply the adhesive remover.
crwdns2942269:0crwdne2942269:0
crwdns2942337:0crwdne2942337:0
crwdns2944105:0crwdne2944105:0
  1. MacBook Pro 13" Function Keys Late 2016 Battery Replacement, Disable Auto Boot: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement, Disable Auto Boot: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement, Disable Auto Boot: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
  2. MacBook Pro 13" Function Keys Late 2016 Battery Replacement, Lower Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
    • Two 6.2 mm screws
    • Two 5.3 mm screws
    • Two 3.4 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    Before any repair is carried out that involves removing the bottom case, the machines auto-boot function has be disabled. This can be disabled via the terminal command “sudo nvram AutoBoot=%00” once the repair has been completed the auto-boot function can be re-enabled via the vermin command “sudo nvram AutoBoot=%03”.
    Aaron Dalziel - crwdns2934203:0crwdne2934203:0
    I recommend that you have an organizer tray for all the small parts, and label it in advance with the numbered “step” associated with each removal of screws and other parts. It really helped me when I needed to put everything back in reverse order, after the new battery is glued in place.
    tommy404 - crwdns2934203:0crwdne2934203:0
    Finished the repair last week. Some key comments that helped me:
    - Step 12, Robert
    - Step 13, MikeG1
    - Step 13, Rick Jaffe (take a photo when disassembling)
    Also added some own comments on Steps 15, 18, 22
    Per Haglund - crwdns2934203:0crwdne2934203:0
  3. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
    • Lift the suction handle to create a slight separation between the lower case and the chassis.
    To replace the bottom just line it up just like it came from the factory. Make sure it clears the display connectors. And press firmly down until the clips connect to the bottom again.
    olivia drinkwine - crwdns2934203:0crwdne2934203:0
  4. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert one corner of an opening pick into the space between the lower case and the chassis.
    • Slide the opening pick around the nearest corner and halfway up the side of the case.
    • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
  5. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
  6. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
    • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
    • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
    My 3rd and 4th clips released simultaneously with clip 1 and 2.
    Therefore I was looking to do something which had already been accomplished.
    David Hutzler - crwdns2934203:0crwdne2934203:0
    yeah be sure not to bend those clips by the display bottom. You pull towards yourself to get it off
    Grant Tyler - crwdns2934203:0crwdne2934203:0
  7. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • It may help to pull first at one corner, then the other.
    • This may require a lot of force.
    Difficult to explain clearly, but worked easily for me by gripping the adjacent bottom and top corners then pulling in opposite directions, rather than trying to grip the hinge corner which is too narrow to afford a strong grip.
    Andrew Gordon - crwdns2934203:0crwdne2934203:0
    This helped me. It needed more force than what I expected. Basically grab the corner with 6.2mm screw with one hand and the cover of that same corner with the other. Then pull the cover and push the laptop. Careful, it pops off with force!
    Javier De la Garza -
    I initially tried shifting the whole panel off the front after using the separating tool to make some space at the back where the hinges are. I only had luck when I pushed the panel back to it’s normal state and using the separating tool again to open the front, then getting my fingers underneath the slide it off the front was easy. I guess the lesson is to not use the separating tool to “push from the back“.
    Josh Brown - crwdns2934203:0crwdne2934203:0
    This step really through me through a loop. My last two MBP were a 2011 and 2013 and on those the bottom just lifted off when you removed the screws. The clips and this sliding lock design added in the 2017 model was frustrating the first time. I was following a youtube video first and he did not explain the sliding part at all. I should have come here first, this guide explains it pretty well. The second time I opened my 2017, I kept an “opening pick” between the bottom panel and the body on each side, and used my two smallest screwdrivers as levers in both “front” corner screw holes. Used the same method without the picks to put it back together at the end. Wayyy easier that trying to grip the panel or laptop body. Just make sure the screwdrivers/pins that you’re using as levers are small enough to be loose in the screw holes and have room to move
    Jambu Atchison - crwdns2934203:0crwdne2934203:0
    I used a pick underneath one of the back corners and nudge it (push down and towards the front - to get it off the hinge). This will make it easier to do the same for the other corner. The lower case will move off the middle plastic L-clips (which you will see after you inspect it.) Cheers! =)
    LSD - crwdns2934203:0crwdne2934203:0
    I have found that your iFixit blue pry tool is excellent at giving me leverage to slide the bottom case forward to release it from the internal clips.
    themacdoctor - crwdns2934203:0crwdne2934203:0
    the panel is sharp on the edges, sharp enough for you to cut yourself when pulling on it. i learned the hard way, just make sure your fingers are in a good spot before pulling
    Micah P - crwdns2934203:0crwdne2934203:0
    This step was the most difficult for me. Nothing worked when trying to slide the cover away from the hinges. I could gain a few mm of separation but I was stuck there. Finally I resorted to brute force and pulled up from the front till the cover snapped open. It's a bit scary but nothing bad happened. In retrospect, perhaps the central clips had not separated, and a strong pull at the center of the case with the suction cup would have been enough to free the cover for sliding.
    Andrea Viceré - crwdns2934203:0crwdne2934203:0
    Same here, I cut 6 of my finger nails before I eventually figured it out. Just like you, I decided to pull the cover from the bottom a little upper than what I had done before, and then I heard the central clips go and my fingers were free at last.
    Daniel Lafargue -
  8. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the lower case.
    I used the green prying tool in the air gap at the rear to nudge the bottom forward.
    That is far easier and more reliable.
    David. I agree. I've found the blue iFixit prying tool most helpful. I place it with the curve of the tool around the hinge and move the bottom case towards the front to release it from the slide-in clips. I consider myself to have pretty good grip strength but I have had some bottom cases that just wouldn't budge until I used this method. Scott The Mac Doctor 
    Like Dave and "themacdoctor" said, this job is MUCH easier if you use a spudger or similar tool to gently push the cover away from the air gap, at the rear of the laptop. Once you do this, you've loosened clips that are on the inside of the bottom case. This is much easier than tugging on the case itself.
    ECJohansen - crwdns2934203:0crwdne2934203:0
  9. MacBook Pro 13" Function Keys Late 2016 Battery Replacement, Battery Connector: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement, Battery Connector: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
    • Remove the tape.
    once the tape's back in place, it doesn't look tightly attached. not sure, did I do something wrong here or it should be so.
    Anton Monakhov - crwdns2934203:0crwdne2934203:0
    The tape will likely not adhere as well as when it came out of the factory. This isnt an issue! As long as the tape is in place when the lower cover is put back on the device you should be good to go.
    Tarun Thiruma - crwdns2934203:0crwdne2934203:0
    The underside of the tape is not uniform. Therefore, pay attention to which direction it is placed by looking at the underside when you remove it. Possibly mark one edge so that you can replace in the same direction during reassembly.
    Rick Jaffe - crwdns2934203:0crwdne2934203:0
    Be very careful to ensure you're pulling the large rectangular patch of tape and NOT the little black tab on the data cable that is below. At first glance they look like they're all one piece. I made this mistake and think that I ruined that cable.
    Brendan C - crwdns2934203:0crwdne2934203:0
    Mark one of the tape’s edges and, upon removal, stick it down with the same orientation. The first time I was inside the MacBook Pro (to upgrade the SSD) I failed to do this, and spent almost 30 minutes trying to get it back like it had been. Making a photo also helps.
    anasazi4st - crwdns2934203:0crwdne2934203:0
    In case you have already taken this out and not looked at how it was in: there’s an end with a round nub sticking out and one with two parallel lines. I was able to get it back in with the round nub over the screw (would be the left side of this picture) and the parallel lines straddling the battery board data cable close to where it connects.
    caryndi - crwdns2934203:0crwdne2934203:0
  10. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently peel back the small piece of tape covering the battery board data cable connector.
    • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector.
    There is no replacement for this cable in the new battery, is this normal?
    Marin dcv - crwdns2934203:0crwdne2934203:0
    the replacement battery doesn't supply the small cable. It needs only be disconnected fro one end as in the pictures.
    robert - crwdns2934203:0crwdne2934203:0
    Well the tape may not supposed to be able to separate but with gentle force, my tape just pulled right off leaving the connector still attached.
    John M - crwdns2934203:0crwdne2934203:0
  11. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to flip up the small black locking tab securing the cable in its connector.
    If this ribbon comes off on both ends, how do you re-attach
    Gord Alder - crwdns2934203:0crwdne2934203:0
  12. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery board data cable by sliding it out from its socket.
    • Slide parallel to the logic board, in the direction of the cable.
    the cable connector (where the twizzer tip is) should be cleaned with alcohol or acetone before insertion because the cover (where the tip is holding it back) will have glue deposit smeared on top of the connector circuit traces. Glue will prevent a good connection with the BMS.
    tarex7 - crwdns2934203:0crwdne2934203:0
    The little tab that you pull back on, at least in my cable, was simple glued onto the rest of the cable. I tried to carefully remove the cable, and the tab came off. I did not have flat tweezers in the ifixit replacement kit and did not want to pinch the cable with sharp instruments. Therefore, be extremely careful when removing the tab as it is difficult to reattach the cable without it.
    Same problem with the tape coming loose and the cable not coming out. Go further back along the cable and pull gently on the cable with your fingers and the connector will come out easily.
    Robert - crwdns2934203:0crwdne2934203:0
    Putting it back was not easy for me. Lots of patience is needed to slid the connectors in place. They should enter without much effort.
    Once secured with the locking tab, it should stay secured even if you try to pull it out with just a bit if force. I'd recommend this check that the connection is secured before moving on.
  13. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fold the battery board data cable back and out of the way.
    • If you're replacing your battery, you may need to completely remove and transfer this cable to your new battery. Disconnect both ends and carefully remove the cable. During installation, be careful not to install it upside-down or backwards—note the orientation in the photos.
    The new battery I received did not come with the battery board data cable, so I had to remove the existing one and transfer it. The lock at the smaller end is the same mechanism as the one at the end shown in steps 11 and 12, but smaller (and harder to see. It helps to gently straighten the left end of the cable before trying to insert it in the end of the replacement circuit board.
    MikeG1 - crwdns2934203:0crwdne2934203:0
    I can corroborate MikeG1’s comment. My battery came without the long data cable as well. I had to remove it from the fried battery. Plastic lock tab mechanism on the ZIF connector is smaller. My inspection microscope helped to transfer the cable to the new battery board. Thanks Mike!
    Macrepair SF - crwdns2934203:0crwdne2934203:0
    Likewise - the new battery came without a data cable. The cable was successfully removed from the old battery assembly and installed on the new battery, but it was tricky and nerve-racking (the cable is delicate and the connectors are very small) without instruction provided! The instructions should be updated to highlight the missing cable possibility, and provide information/illustration on transferring the cable.
    Marc - crwdns2934203:0crwdne2934203:0
    In step 13, notice the amount of the data cable that sticks out of the connector. When moving this cable to the new battery, it is difficult to tell how far to push the cable into the connector or when it is fully inserted because the cable is so bendable.
    AMEN!! This was the hardest part of the ENTIRE process! Hard to know when the small end of the cable was “fully” inserted. Cable is SOOOOO delicate!
    Kevin McAda -
    If your laptop is showing the x where the battery icon is, this cable is at fault. This cable is referred to as the BMU (Battery Management Unit) flex cable. If it’s damaged, replacing it should solve your issue.
    Josh M - crwdns2934203:0crwdne2934203:0
    my old battery was working but could not hold a charge very long so I replaced the battery and now my mac does not recognize the new battery. Thought it was a bad battery at first but I purchased a new batter and still the same problem, My mac will work off power outlet but does not register it has a battery at all now. I tried putting my old battery back on but i damaged the very small clip when i slid out the flex cable so its gone now. Could this cable be at fault? I don/t know what else it could be, i only messed with the battery.
    Leo Ruiz - crwdns2934203:0crwdne2934203:0
    I have this same problem! Did you figure out what the issue was? Do I need a new flex cable?
    Jessica Mouland -
    I am having the same issue as Leo. After install. Is there a way to identify the fault?
    Nathan Jelinek - crwdns2934203:0crwdne2934203:0
    Although the rest of fixit manual on this is excellent, this step is woefully lacking and the fact that the replace “kit” doesn’t have the Battery Board Data cable included makes the replacement kit significantly lacking (especially compared to other kits and instructions I’ve used before from them)
    zandar10 - crwdns2934203:0crwdne2934203:0
  14. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
    When the battery management “BMS” circuit board is re-installed, loosely install the two 3.7 mm screws, put a spudger on the left side of the BMS board to wedge theBMS board to the right then tighten the two 3.7 mm screws. The reason for doing this is that the two power traces on the board may not make physical contact with the battery connector (connector at where the spudger is on step 15). One clue that you didn’t have physical contact is if you reinstalled everything but there is no power unless the AC supply is plugged in (with battery meter on the top at 0%). This was what happened to me. The reason is that when you bend the battery connector in step 15, it’s no longer in alignment with the traces on the BMS board and hence, you have to shift the BMS board to the right to compensate. Once I did this, voila 64% power.
  15. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
    On disassembly note the position of the connector before you lift. It has two gold-plated connections on the underside. On reassembly these need to make contact with the matching battery board connectors. Bending the connector out of the way deformed it a bit, and on reassembly I could see that the connectors didn't align well with the board's connectors. I needed to adjust the battery board position to the left a bit by loosening the 3.1 mm screws in step 23. Possibly this could be the reason why some people report that new battery is not detected.
    This comment was very useful for me. Indeed it is not very easy to place the new battery precisely since the glue blocks it immediately.
    I ended up having the battery slightly misplaced so also the battery board natural position was slightly off.
    I adjusted the board as suggested counting on the elasticity of the cables and using spacers to ensure that the board stays aligned while tightening the screws.
    In retrospect it might make sense to first connect the board, then peel the plastic cover from the battery so that this alignment issue does not occur. But I'm not totally sure it would be simpler.
    Andrea Viceré -
    This comment was a life saver, After all that work the computer did not detect the battery but I realized that the connector was not aligned with the battery board. Ifixit please include this tip on the main directions! Thank you to the author of this comment, I was at the end of my patience!!
    Carly Jobson -
  16. MacBook Pro 13" Function Keys Late 2016 Battery Replacement, Trackpad Prereq: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx driver to remove the two 2.1 mm screws securing the trackpad cable connector bracket.
  17. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the trackpad cable connector bracket.
  18. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the trackpad ribbon cable by gently prying its connector straight up from the logic board.
  19. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Prepare an iOpener and lay it on top of the trackpad ribbon cable for about a minute, in order to soften the adhesive securing the trackpad ribbon cable to the top of the battery.
    • If you don't have an iOpener, use a hair dryer to warm up the cable instead. The cable should be warm, but not too hot to touch. Be careful not to overheat the battery.
  20. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully peel the trackpad ribbon cable up off the battery, and push it out of the way.
    • Do not fold or tear the cable.
  21. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx driver to remove the ten screws securing the trackpad assembly:
    • Two 4.3 mm screws
    • Eight 5.8 mm screws
  22. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the trackpad assembly.
    • You'll need to swing the display open slightly to remove the trackpad.
    • Take care to feed the trackpad ribbon cable through the MacBook Pro's frame without snagging.
    • Be sure not to lose the six small washers (two circular and four rectangular) resting on the underside of the trackpad.
  23. MacBook Pro 13" Function Keys Late 2016 Battery Replacement, Battery: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx driver to remove the two 3.1 mm screws securing the battery board.
    • These screws lie under the battery board data cable. You may need to gently maneuver the cable from side to side to access each screw.
    • Either screw may have a water damage indicator sticker on the top. If so, remove it with a pair of tweezers and set it aside before removing the screw.
    I tried (“Operation”!) to remove this water damage indicator sticker elegantly. Ended up hacking it apart. I think I’ll live.
    weebeast - crwdns2934203:0crwdne2934203:0
  24. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery board is permanently attached to the battery. Check to make sure it has adequate clearance to come out together with the battery, without snagging on other components.
    • Insert the flat edge of a spudger under the battery board on the side nearest the logic board.
    • Lift the battery board to an angle of about 45 degrees. If necessary, lift the battery power connector out of the way to give the battery board extra clearance.
    A ce moment là, il faudrait déconnecter la nappe de données de la carte de la batterie et la mettre de côté
    Giovanni Gervasio - crwdns2934203:0crwdne2934203:0
    At this point I Jump to step 30 . I do not use the liquid adhesive remover method. I use a silicone rubber kitchen food scooper. The scoop end is a soft, silicone rubber material with a beveled edge. The handle is a hard plastic. This tool I’ve used in about 50 retina battery swaps. No floss, credit cards or metal spatulas for me.. The angle of the ends and the rubber pliability combined with the hard plastic handle is ideal. After a few repairs you will get better at it. Be careful when applying pressure or leveraging to get between battery and base. You don’t want to slip & “overshoot” the scoop end into the logic board. EASY DOES IT…Save yourself the mess of applying the liquid. I can remove a battery in 10 minutes. Here’s the link to this tool that I found in my GF’s kitchen:
    https://www.amazon.com/Tovolo-Silicone-S...
    This and the dental floss are great ides that I wish I'd seen before following the method in this guide even though it worked, I think there are better ways.
    Kyle M Brown -
    Amazon says these are no longer available, no idea if or when they will be again.
    You can order a single scooper from amazon.
    google: Tovolo Mini Scoop and Spread Tool
    etcremer -
  25. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The liquid adhesive remover provided in your kit can affect the antireflective coating on your MacBook Pro's display.
    • To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
    • Additionally, layer an absorbent towel directly underneath the trackpad area to soak up any excess adhesive remover.
    help what do i do if i got the adhesive remover jn the screen
    User: Failure - crwdns2934203:0crwdne2934203:0
  26. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now that your MacBook Pro is fully prepped, it's time to prep yourself.
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
    Wenn das Trackpad ausgebaut ist, kann man den alten Akku auch ohne Klebstoffentferner relativ gut auslösen.
    Christian Düll - crwdns2934203:0crwdne2934203:0
  27. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull off the black rubber stopper from your bottle of adhesive remover.
    • Twist to loosen or remove the bottle cap before you cut the applicator tip.
    • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Use scissors to cut off the sealed tip of the applicator.
    • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
    • Twist and close the bottle cap securely before you proceed further.
    Au moment de ma commande le kit complet avec le dissolvant ifixit n’était pas disponible, mais seulement la batterie sans accéssoires, j’ai utilisé quelques gouttes d’acétone à la place. la battéerie originale s’est décollée sans difficulté à l’aide d’une carte de credit
    Can I use isopropyl or ethanol instead?
    Johhnsy Jr. - crwdns2934203:0crwdne2934203:0
    Petite astuce après une réparation fructueuse : pour simplifier cette étape, munissez vous d’un dissolvant fourni ou non, prenez les élastiques de masques chirurgicaux et imbibez le avec le dissolvant. À l’aide de cures-dents, l’insérer entre le châssis et la batterie puis faire un mouvement d’aller et retour tout en avançant au fur et à mesure que la batterie se décolle. Cette astuce m’a fait gagné beaucoup de temps et elle permet de ne pas endommager la batterie lorsque de son extraction. Plus sur, plus rapide et plus facile !
    A little tip after a successful repair: to simplify this step, take the surgical mask elastic bands and soak them with solvent. Using toothpicks, insert it between the frame and the battery then move back and forth while moving forward as the battery comes off. This trick saved me a lot of time and avoids damaging the battery when removing it. Safer, quicker and easier.
    Matthieu - crwdns2934203:0crwdne2934203:0
    The glue remover is a mix of Acetone and Isopropyl alcohol I believe.
    Luke Lanza - crwdns2934203:0crwdne2934203:0
    The adhesive remover they are currently selling does not need to be cut open, it is black and already has a small hole. Check yours before you cut off something you don't need to.
    arichard2401 - crwdns2934203:0crwdne2934203:0
    A little warning for those of us who don't know a lot about acetone. DO NOT spill any on any finished wood. It will take the finish off of a wood surface faster than you can wipe it off. It won't harm clothes surprisingly, but your hardwood floor or wood table are not going to look great if you spill this on them.
    I ordered just the battery, and successfully used "Goo Gone" to loosen the adhesive. I found it useful to place the plastic card along the edge of the battery, then dribble the Goo Gone on the card (when runs down the card to the edge of the battery). In my computer the adhesive is in three strips running across the length of the cell, each strip is about 1/4" wide
    Phil Evans - crwdns2934203:0crwdne2934203:0
  28. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a few drops of adhesive remover underneath the front edge of the battery cell that lies nearest the fan.
    • You don't need to use very much. The small bottle contains more than twice the amount of solvent needed to remove all the battery cells.
  29. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tip the front edge of your MacBook Pro up at a slight angle so that the liquid adhesive remover flows underneath the battery cell.
    • Wait 2-3 minutes before you proceed to the next step, in order to give the adhesive remover time to work.
  30. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Plastic Cards
    $2.99
    • After 2-3 minutes have passed, slide a plastic card under the edge of the battery cell where you applied the adhesive remover.
    • It may help to gently twist the card to open up a slight gap between the battery cell and the MacBook Pro's case.
    • An excess of adhesive remover may damage your plastic card.
    This was the hardest step for me. You just have to keep at it and add a little more adhesive remover if needed, it will eventually come up.
    Avi Ramu - crwdns2934203:0crwdne2934203:0
    Agreed, hardest step. “Several drop” was not enough, I had to add more twice, so take your time.
    Just like on the picture, the corner close to the track pad seem to be a weak point, strat pushing the corner of the plastic card there.
    Adrien Bernede - crwdns2934203:0crwdne2934203:0
    I used a thin plastic kitchen spatula which was easier to slide in under the battery, and cover a wider area than the plastic card.
    There is a metal lip that blocks you from pushing it in. I recommend you start from the corner with the lifted metal part. (top left corner of battery in picture)
    Javier De la Garza - crwdns2934203:0crwdne2934203:0
    the adhesive is in three 'bands' running parallel to the front of the computer. my method was to insert the card part way, then drip the adhesive onto the card and let it slide down to where the card met the adhesive. this seemed to work best. it seems unlikely that the adhesive will run all the way to the rear adhesive when you apply it from the front.
    Noal Balint - crwdns2934203:0crwdne2934203:0
  31. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently work the card deeper under the battery cell to break up the adhesive securing it in place.
    • This should not require much force—the adhesive remover does most of the work. If you aren't able to get your card under the battery cell, apply a bit more adhesive remover as instructed above and wait 2-3 minutes before trying again.
    They are RIGHT, let the acetone do the work. It did need more than a few drops, but not much more. Wait 3 min, apply again. Wait 3 min again. Then take the card and aim the point of the card toward the middle of the adhesive. Wiggle wiggle wiggle moderate pressure. It will penetrate the first strip and then work it left and right. Repeat for the next two strips.
    Richard Ness - crwdns2934203:0crwdne2934203:0
  32. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Twist the card to raise the battery cell until it fully separates from the aluminum case.
    • Don't try to remove the battery cell completely just yet—it's still attached to the remaining cells.
  33. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Leave the plastic card temporarily in place underneath the battery cell.
    • This prevents the cell from re-adhering to the case while you work on separating the remaining cells.
  34. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous six steps to separate the other outer battery cell, on the opposite side.
  35. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:035crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:035crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To separate the center battery cell, first raise the back edge of the MacBook Pro and prop it up on a foam block or book, so that the adhesive remover will flow away from the logic board.
    • Apply a few drops of adhesive remover along the back edge of the battery cell.
  36. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:036crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:036crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Cutouts in the aluminum case between the center battery cell and trackpad may prevent the adhesive remover from flowing all the way underneath the battery.
    • To compensate, apply a few more drops of adhesive remover along each side of the center battery cell.
    • Wait 2-3 minutes before proceeding to the next step.
  37. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide a plastic card under one of the side edges of the center battery cell.
    • Try to keep your card well clear of the logic board.
    I don't see how starting from the side is even possible, it's too steep and the card is not flexible enough.
    I started from the top. To do so, I had to lift the battery control card (step 24) enough to be able to put the power connector (step 15) back below it. That way I could slide the card all the way.
    Because of the way the tutorial describe it, I was conservative on the quantity of remover. That may be why this step was not easy.
  38. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the card to lift the battery cell until it fully separates from the aluminum case.
  39. MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:039crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" Function Keys Late 2016 Battery Replacement: crwdns2935265:039crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the battery.
    • Before installing your new battery, remove all the old adhesive from the MacBook Pro's case.
    • With a little luck, you can slowly pull out each strip of adhesive with your fingers.
    • Otherwise, soak each strip of adhesive with a bit of adhesive remover for 2-3 minutes, and then scrape it out with a plastic tool. This can take quite a bit of work, so be patient.
    • Mop up any remaining adhesive remover and give your MacBook Pro a few minutes to air dry.
    • The replacement battery included in your iFixit kit comes with adhesive pre-installed. Test the battery's fit and alignment carefully before peeling off the film covering the adhesive, and then press each cell firmly into place. If any additional films/liners are present that weren't on your original battery, remove them now.
    • Calibrate your newly installed battery: charge it to 100%, and keep charging it for at least 2 more hours. Unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook Pro's SMC.
    Hi Jeff,
    Thank you for the great instructions! With a piece of dental floss it goes even better. Also it’s good to explain to shift the back cover out after removing the bolts. At the moment to put in the new batteries it’s the best to tighten the batteryprint first and at last to fix the batteries. Put three pieces of plastic under the batteries to prevent fixing too early to the bottom.
    Frans.
    Frans Beentjes - crwdns2934203:0crwdne2934203:0
    Thanks for your comment! It was really essential since dropping the battery in the case without its control card being attached could have resulted in the impossibility to connect it.
    Adrien Bernede -
    I had a non-ifixit battery replacement fail due to battery wiring (flat coated copper) touching the sharp edge of the case aluminum. Eventually vibration caused the insulation to wear off and short the middle cell to the case. Failure after a couple weeks.
    Jeremy Hale - crwdns2934203:0crwdne2934203:0
    Tuto au top.
    J’ai remplacé la batterie de mon MacBook Pro en suivant à la lettre ce Tuto.
    Un grand merci.
    Stephane RUE - crwdns2934203:0crwdne2934203:0
    Overall good guide. The battery removal was by far the most difficult and time consuming.
    It's important to understand stand that the battery is separate from the mother board so you can get somewhat aggressive when removing the old battery without worrying about damaging it.
    Kyle M Brown - crwdns2934203:0crwdne2934203:0
    As a general rule do not be rough with a lithium battery unless you like out of control lithium fires. It is best to use plenty of solvent and be as careful as possible while removing the old cells.
    London Kassner -
    Also a good idea to discharge the battery fully before working on it.
    maccentric -
    I'm also one of those that just can't stand the idea of using solvent to do the job. FYI, I used a bent and 'sharpened' plastic card, much like a credit card, to carefully separate the battery from its adhesive. I was even able to get the center section out by working the card in from the sides (mostly from the right side, as I'm right-handed), so I didn't have to remove the trackpad assembly. I figured there are huge risks in however we do these complicated jobs, so I'm more comfortable with the risks associated with my technique than the ones associated with the solvent technique. And the bonus is that I finished in less than an hour!
    I've done enough of these battery replacements now that I'm confident about dealing with the fussy little ribbon cables and their connectors, which is an added bonus when tackling a newer model like this.
    Good luck to all who are taking this on for the first time! Take your time, read all the way through before starting, and be sure to read all the comments throughout!
    jiclark - crwdns2934203:0crwdne2934203:0
    Can someone clarify the statement "Wait at least 5 hours, then charge your laptop uninterrupted to 100%." in this last step"? It does not state this in the directions I received on a small card with the battery replacement, nor does it in the Conclusion below.
    Khalid Krackn - crwdns2934203:0crwdne2934203:0
    I followed this guide to replace the battery in a Mid 2017 MBP. The original was stuck at 0% even after 3 hours on charge even though the cycle count was 2 digits only.
    I dry tested the replacement battery first. It had 38% charge. I left it plugged in and it reached 100% fine. The next day, I stuck the new battery down and low and behold now the machine won't power up.
    I reconnected the old battery and the machine powers up ok. I tried reseating the connections 3 times with the new battery and it still won't power up. I've tried an SMC reset too. So I'm guessing it's a faulty new battery. Either that, or the rumours that Apple are deliberately locking out non-genuine Apple parts is true.
    Trouble is, this seems to be quite a common scenario with this model.
    Cool_Breeze - crwdns2934203:0crwdne2934203:0
    I just did a battery replacement and after 3-4, SMC resets, checking all connections inside, etc. I cannot get my laptop to show a battery is even installed. I doubt it is a bad battery but as Cool_Breeze suggests, can anyone confirm this may be an Apple "block"? So frustrating!
    Karen Boutwell - crwdns2934203:0crwdne2934203:0
    Bonjour, ils indiquent que je n’ai pas de batterie, quoi faire ?
    Merci
    Andrea Zanetti -
    Referring to the messages from Cool_Breeze and Karen.
    Does this battery replacement technique still work or have Apple somehow 'blocked' it?
    Thanks
    we eatbricks - crwdns2934203:0crwdne2934203:0
    I don't recommend to calibrate the battery at the end and even Apple do not recommend to calibrate since a decade. It seems the battery is already calibrated with 2 cycles already. I followed your calibration tutorial and my new battery lost 6% health statut... Probably because of letting cels at 0% during 5 hours.... It's totally a non sense!!!
    Ben Gd - crwdns2934203:0crwdne2934203:0
    That was hard. Particularly replacing the BMC cable, and getting the b****y batteries out. But it's sitting charging just now, and I think (for think read hope) it's all ok. Phew.
    Leslie Smith - crwdns2934203:0crwdne2934203:0
    I have and recommend cleaning the case before placing it back on as it can collect a lot of dust especially around the fan.
    Adam Quinn - crwdns2934203:0crwdne2934203:0
    Really good instructions! However I needed more than 2 hours ... I guess the problem was between laptop and chair :-D Anyway, many thanks folks!
    Hans Multhaup - crwdns2934203:0crwdne2934203:0
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted back to 100%.
crwdns2935229:090crwdne2935229:0
Jeff Suovanen
crwdns2935283:008/06/13crwdne2935283:0
442.600 crwdns2915208:0crwdne2915208:0
crwdns2935297:0259crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.282crwdne2935297:0
crwdns2947412:031crwdne2947412:0
Does the replacement battery comes with the same strong adhesive as the original battery?
Surgie - crwdns2934203:0crwdne2934203:0
I ordered my battery for the 2017 version of the Macbook Pro with function keys from ebay and it didn’t came with a adhesive strip. I am sure you can use your own adhesive strips or double sided tape, as long as you mind the gabs on the aluminum frame,
Serj Nko -
Thanks for the great guide! Can you copy the guide to the Macbook Pro 2017 thread, as it’s exactly the same procedure for the function key version? It might be obvious for some “Pros” but I realized it after some trial and error odyssey.
Serj Nko - crwdns2934203:0crwdne2934203:0
Hi Jeff,
Thank you for this great work to beat Apple greediness. I followed the exact steps and everything went well, but my battery is not charging nor the status is shown on the bar! I tried restarting and resetting and even restoring and it did not work would that be something you can help me with?
Bashar Khiatah - crwdns2934203:0crwdne2934203:0
If the old battery still works, try putting it back in, and see if that clears up the problem. If it does, the new battery is defective.
Jeff Suovanen -
i did this one today with just 1 bankcard in 30min time no adhesive loosener needed no head needed…. you don’t even have to remove the mousepad…
i might have to start making my own repair guide….
demeyermike - crwdns2934203:0crwdne2934203:0
Glad yours was easy! The strength of the adhesive can vary a lot depending on age, heat cycles, how much was applied at the factory, etc. I’ve seen a few that were easy and quite a few that were absolute monsters to remove. Most fall somewhere in between. This guide should have you covered in all cases, but it probably doesn’t hurt to poke and pry a little before you start, in case you lucked out and got an easy one. Just be very careful not to puncture the battery. Thanks for your comment!
Jeff Suovanen -
I can confirm that this guide also works word for word for a 2017 MacBook Pro with function keys. All I would add is that Step 7 requires considerable force!
Jon Worth - crwdns2934203:0crwdne2934203:0
I did not remove the trackpad or use adhesive remover (Macbook Pro late 2017). Just need to get underneath the battery cells and push through the factory adhesive/tape. The entire process took around 30 min doing it this way; I’m handy, though no pro.
renob - crwdns2934203:0crwdne2934203:0
Thank you! This excellent guide gave me a lot of confidence in the replacement of the battery. All went precisely according to plan.
Excellent instructions. I did it slowly as it’s my first time with a Macbook Pro. Took me 90 minutes. I added some comments in steps 13-15 because the battery wasn’t connected properly on the first time.
I just completed the swap… awesome guide and really easy.
The only Problem i had was the missing data cable from the battery board to the logic board which was not included with the new battery. Thanks to some comments from other users I used the cable from the old battery.
Everything Else worked as described.
Mirko Bjelic - crwdns2934203:0crwdne2934203:0
Great guide, thank you. I am replacing my battery and have a question about Step 13. Would it be possible to show how to disconnect this end of the cable (the hook end). I am having a hard time getting it out.
Thank you in advance for any help/advice.
r8w8 - crwdns2934203:0crwdne2934203:0
Vielen Dank für die gute Anleitung. Der Akkutausch hat ohne Probleme sehr einfach in ca. einer Stunde geklappt.
Thank you Jeff for the detailed and accurate guide.
Mario W - crwdns2934203:0crwdne2934203:0
Worked just perfectly, thank you iFIXIT for doing what you do. Truly appreciated. Perfect instructions- just perfect!!
tgsavel - crwdns2934203:0crwdne2934203:0
Thank you for the great guide! I did not want to ship my Mac to official Apple service centre - as I was advised I would need to wait one week for battery replacement and I needed laptop for my daily work. Decided to replace battery on my own. Thanks to this comprehensive guide I made it in 2 hours. I do appreciate clear and comprehensive way author has explained the procedure. Again big thank you! Also useful comments of users are appreciated. Thanks. Andrew
Andrew Pernisch - crwdns2934203:0crwdne2934203:0
good guide, but that adhesive did not come off easy. Used a Bank card and adhesive remover. everything else was smooth ad though ;)
Tommy HARDT - crwdns2934203:0crwdne2934203:0
I suggest examining the two connection points of the skinny battery data cable. Possibly you failed to either, fully insert the cable or forgot to press the clamp down. Also, I believe Fixit fails to tell you to lift the clamp before removal and it is impossible to insert without lifting the clamp. You might need extra strong reading glasses to see it properly. Good luck.
I need to buy one, but you guys don't ship to India, is there any way you guys can help ? i needed urgently/
Rohan Singh - crwdns2934203:0crwdne2934203:0
Great guide,
got the spare battery from your store and followed the guide. But now I have the issue that my macBook sometimes needs to be plugged in to wake/start even tough the battery got enough charge. could this be a battery related issue?
Terrific guide, thank you very much!
Got a replacement battery from eBay (UK supplier) and didn't need any battery calibration or the like afterwards.
This was only my second replacement, and it's actually not that complicated. But the tiny screws and clamps and the sh%$&§y glue...
Speaking of glue: I can handle solvent (isopropanol etc.) but I wanted to minimize damage to the screen. So I took the butcher/surgeon approach and cut the battery out with the "plastic cards". Took a while but worked. Total time for first replacement 2 hours, second one 1 hour.
The adhesive strips of the replacement battery were not as strong as those of the original battery, but that may actually reflect aging and effect or repeated heating of the glue. In any case, the replacement battery sits tightly enough to not require any correction.
Cheers
Jochen Bergmann - crwdns2934203:0crwdne2934203:0
I just did this and it worked a treat. Bought a replacement item from Amazon that had plenty of positive feedback and went to work. I used a plastic scraper and some solvent to get the batteries out and it was definitely the hardest part of the job - took at least an hour - that plus cleaning and prepping the surfaces for the new battery.
But it was really therapeutic and when the computer booted up and Coconut showed me a healthy 100% functional battery the feeling was GREAT!
I made the mistake of removing the trackpad and had to realign it a couple of times but with this operation, I don't think it is necessary to remove it. I'd definitely be able to do it in half the time if I ever needed to again. :D
Adam - crwdns2934203:0crwdne2934203:0
Hi, I have just done this and all seemed to go well, but just plugged my mac into the mains and it is not charging or switching on at all. Unsure if it could be that the battery data cable isn't connected in well enough as it was quite fiddly to put back in?
izzy_turnbull - crwdns2934203:0crwdne2934203:0
I support wholeheartedly the goals of iFixit -- sustainability, support for true ownership of the products we purchase, and elimination of the domination of corporate entities. The guide provided here for replacing the battery in a Macbook Pro was spot-on and even a fraidy-cat like myself had no problems in accomplishing the task. Hooray! Unfortunately, I have found the battery itself to be of low quality, i.e., just six months later a fully-charged battery is completely spent within two hours, even with the screen dimmed to 50% and when doing nothing more demanding than word processing. It is unfortunate that the good intentions of iFixit are not supported by quality products.
Mark Decker - crwdns2934203:0crwdne2934203:0
Hi there, thanks for this very detailed manual. I followed every step. Everything looks like it work except for one thing : since then my spacebar is not working anymore :/ I'm not sure what happened. If you have any clue to help me I'd be very grateful. A computer without a spacebar is worst than without a battery I'm afraid.. :(
Martin dupon - crwdns2934203:0crwdne2934203:0
While I do not intend to criticize the writer of this guide, I believe that the directions provided are incomplete without being reversed step-by-step. As a first-time hardware worker, I found several steps to be more complicated than the instruction "follow the above steps in reverse order" suggested. Specifically, installing the new battery required precise alignment of the battery board, which I only discovered after I had already placed the new battery. I had to lift it back out, which was difficult as it was already adhered, to adjust the location properly. Furthermore, connecting the battery board data cable connector to the new battery was challenging, and I was unsure of how much force to apply or how far it needed to go in. After completing the installation, I was concerned that I had made a mistake and potentially damaged the device. If that had been the case, I would have been disappointed that I had spent $119 on a replacement kit.
Mal - crwdns2934203:0crwdne2934203:0
I followed this guide to replace a battery because my partner's mother's MacBook was only functioning when plugged into the wall. After successful install, I tried booting the computer, but it would not boot unless it was plugged into the wall. It came to life, with the fan running at full. I checked in SysPref to check the battery, and it wasn't listed; therefore, when I unplugged the power cable, the device died. It refused to turn on again unless I re-seated the battery logic cable. I feared the logic cable had been damaged during the repair, as without that cable, the system won't recognize the battery.
If this happens to you, understand it is very important that you turn back on the Auto Boot feature!
With Auto Boot enabled, I was able to perform an SMC reset by:
1. Plugging in the laptop to the charger, with the lid closed
2. Opening the lid and quickly holding Shift+Control+Option+Power for 10 seconds
3. Pressing the power button again
This calmed the fans and the battery now charges and is displayed.
Brian - crwdns2934203:0crwdne2934203:0
Thank you! I have no previous experiance, this took me almost 2 hours but fully sucessful
Plam - crwdns2934203:0crwdne2934203:0
Hey, somehow i leaked/spilled some Adhesive remover on the display. Now its botched and brighter in some places. How can I fix that? Any suggestions?
Regards, Chris.
C G - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 21
crwdns2936753:07crwdne2936753:0 171
crwdns2936753:030crwdne2936753:0 868
crwdns2942667:0crwdne2942667:0 108,869
