MacBook Air 13" Early 2020 Logic Board Replacement
  1. MacBook Air 13" Early 2020 Logic Board Replacement, Remove the screws securing the lower case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
    P5 is also a PL4 (so confusing) - i like the wiha 26764 thanks to @mayer for this post. P5 pentalobe and 1.2 pentalobe screwdriver
    greg - crwdns2934203:0crwdne2934203:0
  2. MacBook Air 13" Early 2020 Logic Board Replacement, Remove the lower case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Early 2020 Logic Board Replacement, Remove the lower case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Early 2020 Logic Board Replacement, Remove the lower case: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
    When reassembling, the “snaps” are in the middle of the laptop (from top to bottom), and just to the left and right of center. I assumed it was near the hinge so it took a bit for me to hear the snaps.
    Laurie McCall - crwdns2934203:0crwdne2934203:0
    Laurie, the two clips are outlined in the third photo of step two. Hope this helps—happy fixing!
    Carsten Frauenheim -
    What tool kit should I use for this?
    Lucas Lee - crwdns2934203:0crwdne2934203:0
    the second picture is m1 air right?
    the antenna cable position does not match later picture
    Paul - crwdns2934203:0crwdne2934203:0
  3. MacBook Air 13" Early 2020 Logic Board Replacement, Disconnect the battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
    This image is incorrect correct for the A2179 EMC 3302 model, also doesn’t match the next image in this guide
    Steven Friar - crwdns2934203:0crwdne2934203:0
    There is other guide for the model you reffer to, I was using that one until i realize it was different, this is the one you are looking for: MacBook Air 13" Retina Late 2020 (M1)
    Marco Rojas -
    I initially thought the image was incorrect, but I was just looking for the connector in the wrong place. This picture IS correct for the A2179 EMC 3302. Note that the connector is on the left side of the heat sink (the black thing with parallel ridges in the picture and on the computer), and the connector wires gather together towards the left the side of the computer, not the back. Note that "left side" assumes the Air is upside-down, with the hinge on the side farthest away from you (I'm not doing the "right speaker is on the left side because it's upside-down" thing that iFixit does in step 5).
    Bryan Gillson -
    How do you find out if you have a Retina Late or Retina Early model?
    Inji E - crwdns2934203:0crwdne2934203:0
  4. MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
    Me too. It’s really stuck in there. Not sure if I should attempt the usb c port replacement if I can’t disconnect the battery.
    Steve - crwdns2934203:0crwdne2934203:0
    Einfach abwechselnd links und rechts den Stecker langsam rausschieben. So wie abgebildet ist es tatsächlich schwierig.
    Jörg Oehme - crwdns2934203:0crwdne2934203:0
  5. MacBook Air 13" Early 2020 Logic Board Replacement, Disconnect the logic board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13" Early 2020 Logic Board Replacement, Disconnect the logic board: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T4 Torx driver to remove the two 1.4 mm screws securing the trackpad cable cover.
    • Remove the trackpad cable cover.
    Actually, a T3 will be needed for this step
    John Thompson - crwdns2934203:0crwdne2934203:0
  6. MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry the trackpad cable connector up and out of its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  7. MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The left speaker will be on your righthand side when working on the MacBook, as it's laying upside down.
    • Slide the pointed end of a spudger underneath the left speaker cable and pry straight up to disconnect it from the logic board.
    • With the connector disconnected, slide the flat end of a spudger under the cable to separate the adhesive securing the cable to the logic board.
  8. MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to peel back any tape covering the microphone cable connector.
    • Use the pointed end of a spudger to lift up the small locking flap on the microphone cable's ZIF connector.
    • Slide the microphone cable out of its connector.
    • If possible, grip the cable by the tape, not by the cable itself.
  9. MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T4 Torx driver to remove the two 1.4 mm screws securing the USB-C connector cover.
    • Remove the USB-C connector cover.
  10. MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry the USB-C cable connector up and out of its socket on the logic board.
  11. MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to lift up the small locking flap on the sound board cable's ZIF connector.
    • Slide the sound board cable out of the ZIF connector.
  12. MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel back the black tape covering the fan cable connector.
  13. MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of a spudger to lift up the locking flap on the fan cable's ZIF connector.
    • Slide the fan cable out of the ZIF connector.
  14. MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T4 Torx driver to remove the 1.4 mm screw securing the antenna cable cover.
    • Remove the antenna cable cover.
  15. MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to grip the antenna connector close to its base.
    • Pull straight up to disconnect the cable.
    • Repeat for the second antenna cable.
  16. MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T4 Torx driver to remove the two 1.5 mm screws securing the display cable connector cover.
    • Remove the display cable connector cover.
  17. MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13" Early 2020 Logic Board Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry the display cable connector straight off of the antenna board to disconnect it.
  18. MacBook Air 13" Early 2020 Logic Board Replacement, Remove the logic board screws: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx driver to remove the six screws securing the logic board to the upper case:
    • Three 3.5 mm screws
    • One 5.8 mm cushioned screw
    • Two 2.0 mm screws
    Hint: when reassembling, replace these 6 screws only about halfway so that the logic board can move about a bit. This will make aligning the logic board with the connector cables somewhat easier. Once all connector cables are in place, then tighten these screws starting from the innermost to the outermost.
    Jerry May - crwdns2934203:0crwdne2934203:0
  19. MacBook Air 13" Early 2020 Logic Board Replacement, Remove the logic board: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the logic board.
  20. MacBook Air 13" Early 2020 Logic Board Replacement, Check cables during reassembly: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When you reinstall the logic board assembly, verify that no cables get trapped under the board as you lower it into place. Check each of the seven locations carefully:
    • Battery cable
    • Fan cable
    • Audio board cable
    • USB-C board cable
    • Antenna bar cables
    • Trackpad cable
    • Left speaker and microphone cables
crwdns2935229:015crwdne2935229:0
Carsten Frauenheim
144 508 crwdns2915208:0crwdne2915208:0
crwdns2935297:0422crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021 025crwdne2935297:0
donde se ubica disco duro , ya que ledi opcion borrar mac y maraca error desde recovery
daniel ortiz salazar - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 109
crwdns2936753:030crwdne2936753:0 468
crwdns2942667:0crwdne2942667:0 31,766
