How to Open Your Logitech G305
  1. How to Open Your Logitech G305, Turn off your mouse: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Open Your Logitech G305, Turn off your mouse: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide your mouse's power switch to the left so it's in the OFF position.
    • A red indicator should be visible beneath the switch.
    • Throughout your repair, it may be helpful to lay your mouse on a soft cloth to stabilize it and prevent damage while you work.
  2. How to Open Your Logitech G305, Remove the mouse feet: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Open Your Logitech G305, Remove the mouse feet: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The feet are secured to the bottom of the mouse with adhesive. In order to cleanly remove them, the adhesive needs to be thoroughly heated.
    • Heat an iOpener and lay it on the mouse feet for one minute to heat the adhesive.
    • Alternatively, you can use a hair dryer on the Low heat setting to soften the adhesive.
    • If you're using a hair dryer, only heat the feet a few seconds at a time or you may warp the plastic shell.
  3. How to Open Your Logitech G305: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech G305: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech G305: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The feet have two layers—a rubberized one and an adhesive pad underneath.
    • If you're reusing the feet, be very careful not to separate the two layers or damage the feet.
    • Carefully slide the point of a spudger under one of the feet, making sure it goes under both the foot and its adhesive pad.
    • If you're just removing the feet to open the mouse, you don't need to remove the circular one below the power switch.
    • Gently slide the spudger farther under the foot and lift to remove it.
    • If the rubber layer separates from its adhesive pad, use the same process to remove the pad.
  4. How to Open Your Logitech G305: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech G305: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech G305: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step to remove the remaining feet.
  5. How to Open Your Logitech G305, Reassembly information: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech G305, Reassembly information: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech G305, Reassembly information: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To install a new foot:
    • If any of the feet got damaged during removal or separated from their adhesive pads, replace them.
    • Use a spudger to carefully scrape up and remove any remaining adhesive bits.
    • If there's any adhesive residue left, use isopropyl alcohol and a microfiber cloth to remove it. Allow the surface to completely dry.
    • Remove the feet from their backing and firmly press them into place.
  6. How to Open Your Logitech G305, Remove the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech G305, Remove the battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech G305, Remove the battery: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press down on the top cover just above the Logitech logo and slide it back to remove it.
    • When reinstalling the cover, you should feel and hear a "click" as it slides into place.
  7. How to Open Your Logitech G305: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech G305: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech G305: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the end of the AA battery near the back of the mouse and remove it.
    • To install a new battery, slide the negative (-) end into the recess so it's near the front of the mouse and push the battery into place.
  8. How to Open Your Logitech G305, Open your mouse: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Open Your Logitech G305, Open your mouse: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the four 5.3 mm‑long screws securing the bottom shell.
  9. How to Open Your Logitech G305: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Open Your Logitech G305: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With one hand, firmly hold the bottom shell in place.
    • With your free hand, lift the front of the top shell to partially separate it.
    • Don't try to fully separate the top shell, as the back is still clipped in.
  10. How to Open Your Logitech G305: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech G305: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech G305: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With one hand, firmly grip the top shell.
    • With your free hand, insert the flat end of a spudger between the top and bottom shells near the rear of the mouse.
    • Slide the spudger towards the rear of the mouse while pulling the top shell up and toward the front to separate the shells.
    • If the shells don't separate, repeat the process on the other side of the mouse.
  11. How to Open Your Logitech G305: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech G305: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech G305: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't try to fully remove the top shell yet, as two cables still connect it.
    • Lift the top shell up and flip it over the right edge of the mouse, being careful not to strain the cables.
    • The top shell should stay slightly propped up.
  12. How to Open Your Logitech G305: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech G305: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech G305: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to firmly grip the short edges of the battery cable connector on the bottom right corner of the board.
    • Pull the connector straight up and out of its socket.
    • If you're having trouble, rock the connector side-to-side to help loosen it.
    • During reassembly, push down on the edges of the connector with the flat end of a spudger until it's fully seated in the socket.
  13. How to Open Your Logitech G305: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Open Your Logitech G305: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay the top shell flat on your workspace to the right of the mouse.
  14. How to Open Your Logitech G305: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech G305: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech G305: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to firmly grip the short edges of the top buttons connector on the right edge of the board.
    • During reassembly, push down on the short edges of the connector with the flat end of a spudger until it's fully seated in the socket.
  15. How to Open Your Logitech G305: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The top and bottom shells are now fully separated.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
119,118 crwdns2915208:0crwdne2915208:0
crwdns2935297:0838crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,725crwdne2935297:0
Muito bom, consegui consertar o problema do botão esquerdo e ficou novinho, fiz uma limpeza e Show .
HighTechGG - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 41
crwdns2936753:07crwdne2936753:0 228
crwdns2936753:030crwdne2936753:0 934
crwdns2942667:0crwdne2942667:0 4,916
