This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to replace a dead or worn‑out battery in your Google Pixel 10.
All smartphone batteries have limited lifespans. If your phone doesn't hold a charge or dies unexpectedly, it might be time to replace the battery.
If your battery is swollen, take appropriate precautions.
Note: Any repair can compromise the water resistance of your phone. Retaining water resistance after the repair depends on how accurately the new adhesives are applied and how clean the surfaces are.
Unplug all cables from your phone.
Apply strips of packing tape to the cracked glass until it's completely covered—this will help keep the glass contained and allow the suction cup to stick.
Make sure there's a single strip (not overlapping) of tape across the bottom edge, big enough for a suction cup to fit on.
Heat an iOpener and lay it on the bottom edge of the back glass for two minutes.
Apply a suction handle to the center of the back glass's bottom edge, as close to the edge as possible.
Pull up on the suction handle with strong, steady force until a gap forms between the back glass and frame.
Insert the tip of an opening pick into the gap.
The back glass is secured with adhesive around the perimeter of the frame. Use this picture as a reference while you separate the adhesive.
Slide the opening pick along the bottom edge to separate the adhesive.
Leave the pick inserted under the bottom left corner to prevent the adhesive from re‑sealing.
Insert a second pick under the bottom left corner and slide it up the left edge, stopping at the power button.
Leave the pick inserted to prevent the adhesive from re‑sealing.
Insert a third pick under the bottom right corner of the back glass and slide it up the right edge.
Leave the pick inserted under the top right corner.
Insert a fourth pick under the top right corner.
Slide the pick along the top edge and slightly around the top left corner, stopping at the bottom of the camera bump.
Flip the back glass over the left side of the phone and use the suction handle (or a sturdy object) to prop it up.
Use a Torx Plus 3IP screwdriver to remove the two 5.0 mm‑long screws securing the back glass connector bracket.
Use tweezers or your fingers to remove the bracket.
Use the point of a spudger to pry up and disconnect the back glass press connector.
Remove the back glass.
Use a Torx Plus 3IP screwdriver to remove the two 5.0 mm‑long screws securing the motherboard cover.
Use a spudger to lift the motherboard cover, then grip the cover and slowly peel the graphite sheet off the battery.
Use the point of a spudger to pry up and disconnect the battery press connector.
Use the point of a spudger to pry up and disconnect the interconnect cable press connector from the bottom right of the motherboard.
Use a Torx Plus 3IP screwdriver to remove the two 5.0 mm‑long screws securing the USB‑C board cover.
Use the point of a spudger to pry up and disconnect the interconnect cable press connector from the USB‑C board.
Remove the interconnect cable.
Use your fingers to peel up the entire battery tab on the left side of the battery, including the skinny strip running along the side.
crwdns2935267:0crwdne2935267:0Finger Stalls$8.99
Wear finger stalls to help get a solid grip on the battery pull tabs and frame in the next step.
Secure the right side of your phone with one hand, and use your free hand to grip the battery pull tab.
Pull straight up on the tab and apply constant, steady force until the adhesive separates.
Grip the battery and slowly pull it away from your phone to peel the plastic sleeve out of the recess.
Remove the battery.
Before installing a new battery, check the recess for leftover bits of plastic, as well as adhesive residue from the battery sleeve.
Remove any bits of plastic from the old battery sleeve.
Use one or two drops high‑concentration (>90%) isopropyl alcohol and a microfiber or lint‑free cloth to clean up any adhesive residue.
Allow the alcohol to dry completely before continuing.
Remove the large, colored liner from the battery to expose the adhesive.
Hold the battery above its recess and use your finger to push down and reconnect the battery press connector.
Lay the battery into its recess and press down firmly to secure it.
Use your fingers to remove any remaining stickers or liners from the battery.
Lay the interconnect cable back in place, making sure the connectors line up with their sockets.
Use your finger to press down and reconnect the interconnect cable press connector to its socket on the motherboard.
Use your finger to press down and reconnect the interconnect cable press connector to its socket on the USB‑C board.
Put the USB‑C board cover back into place, sliding the tabs on the top corners under their hooks.
Use a Torx Plus 3IP screwdriver to install the two 5.0 mm‑long screws securing the USB‑C board cover.
Check the condition of the motherboard thermal pad—it'll either be on the bottom edge of the board or on the underside of the cover.
Use the flat end of a spudger to gently scrape up and remove all the old thermal pad from the board and cover.
Use high‑concentration (>90%) isopropyl alcohol and a coffee filter (or lint‑free cloth) to clean up any thermal pad residue from the board and cover.
Remove the larger liner (without cutouts) from the thermal pad.
Lay the thermal pad in its square cutout on the underside of the motherboard cover.
Press down firmly on the entire surface of the pad with your finger or the flat end of a spudger.
Slowly peel up the remaining liner.
Use your finger to press down and reconnect the battery press connector.
Check the condition of the graphite sheet attached to the motherboard cover.
If the sheet is torn or damaged in any way, peel it up and remove it from the cover—you'll apply a new one in a few steps.
Put the motherboard cover back in place.
Use a Torx Plus 3IP screwdriver to install the two 5.0 mm‑long screws securing the motherboard cover.
Remove the large clear liner from the graphite sheet, exposing the adhesive.
Lay the graphite sheet into place, so the circular portion is over the battery, and the cutouts on the top edge go into the grooves on the motherboard cover.
Use your fingers to press down firmly on the entire surface of the sheet to secure it.
Slowly peel up and remove the remaining liner.
Before installing new adhesive, all the old adhesive and its residue must be completely removed from the frame.
Use the point of a spudger to remove all the old screen adhesive from the frame. Try to "roll" the adhesive onto itself so it balls up, making it easier to remove.
If you're having trouble removing smaller chunks, apply a single drop of high‑concentration (>90%) isopropyl alcohol and scrape them up with your spudger.
Wrap a microfiber or lint‑free cloth around a spudger and apply a single drop of high‑concentration (>90%) isopropyl alcohol to the end.
Use the spudger to clean up all the remaining adhesive residue from the frame, applying more drops of alcohol as necessary.
If you're reinstalling your original back glass, repeat the procedures in the previous two steps on the back glass to clean it.
Hold the adhesive above the frame to find its orientation. Use the rear camera cutout in the liner to help visualize how it will lay in the frame.
Peel down the top half of the large, clear liner to expose the adhesive—don't fully remove the liner yet.
With the larger, clear liner folded towards the bottom of the phone, lay the exposed top edge of the adhesive onto the frame.
Once the top edge is properly aligned, gently press down on the top corners to secure the adhesive.
Slowly lay the rest of the adhesive onto the frame, pressing it into place and peeling away the larger liner as you go.
Use a spudger to press down firmly on the adhesive to secure it to the frame.
Slowly peel up and remove the large colored liner, gripping it from the cutout near the top edge.
Remove all liners from the underside of the back glass, paying special attention to the front camera cutouts and bottom edge.
Apply a suction handle to the back glass and prop it up on the left side of your phone, so the cable is near its connector.
Use the flat end of a spudger to connect the back glass press connector to its socket.
Put the cable's bracket back in place, making sure the tab on the right edge goes under its groove.
Use a Torx Plus 3IP screwdriver to install the two 5.0 mm‑long screws securing the bracket.
Remove the remaining liners from the back glass adhesive.
Flip the back glass onto the frame and press it firmly into place.
Hold your phone up and squeeze firmly around the perimeter to strengthen the bond.
Congratulations on completing your repair!
For optimal performance, calibrate your newly installed battery after completing this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.e instructions in reverse order.
