DualShock 4 CHU-ZCT2U Battery Replacement
  1. DualShock 4 CHU-ZCT2U Battery Replacement, Remove the rear panel screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 4 CHU-ZCT2U Battery Replacement, Remove the rear panel screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
    A driver size recommendation would be nice. I tried several and found that a size 2.5 Phillips worked nicely
    Justin Vander Ziel - crwdns2934203:0crwdne2934203:0
  2. DualShock 4 CHU-ZCT2U Battery Replacement, Separate the rear panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 4 CHU-ZCT2U Battery Replacement, Separate the rear panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Four fragile plastic clips hold the panels together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
    • Gently pry the rear panel off of the front panel until they become partially separated.
    easy, but quite brute way of opening the rear panel without the opening tool: https://www.youtube.com/watch?v=wYybiBBL...
    watch the opening from the back part only, then return here.
    christianviali - crwdns2934203:0crwdne2934203:0
    That worked but a couple clips broke in the process. Beware for people trying this method.
    Bryan Remely -
    There are 4 tab clips total, 2 at the top corners (very easy to break) and 2 at the bottom near the ports. The screws will keep it together even if they do break but be careful if you don’t want to break them.
    Fungi -
    I've written a guide to help others find the clips and unlatch them.
    Important Step For Opening the DualShock 4 CUH-ZCT2U
    Richard - crwdns2934203:0crwdne2934203:0
    Hi Richard,
    Thanks for writing this up! I'm going to link your guide into the step.
    Arthur Shi -
  3. DualShock 4 CHU-ZCT2U Battery Replacement, Release the plastic clips: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualShock 4 CHU-ZCT2U Battery Replacement, Release the plastic clips: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualShock 4 CHU-ZCT2U Battery Replacement, Release the plastic clips: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
    I've written a guide to help others find and unlatch these clips
  4. DualShock 4 CHU-ZCT2U Battery Replacement, Remove the rear panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 4 CHU-ZCT2U Battery Replacement, Remove the rear panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the rear panel directly away from the controller.
    • Do not completely remove the rear panel. It is still attached to the controller by a ribbon cable.
  5. DualShock 4 CHU-ZCT2U Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 4 CHU-ZCT2U Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
    • Since this cable's pull tab is too small to grab with fingers or tweezers, grab the cable itself. Otherwise utilize pull tabs whenever possible.
    • During reassembly, grab the ribbon cable by the blue tab and gently press the cable straight into the connector. Push the blue tab rather than the ribbon cable itself.
    I'm struggling getting the ribbon to connect back in. Why might that be?
    David Clair II - crwdns2934203:0crwdne2934203:0
  6. DualShock 4 CHU-ZCT2U Battery Replacement, Remove the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 4 CHU-ZCT2U Battery Replacement, Remove the battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to pull the battery's power connector straight up from the motherboard.
  7. DualShock 4 CHU-ZCT2U Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualShock 4 CHU-ZCT2U Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery.
crwdns2935229:045crwdne2935229:0
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
87.927 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
For this DualShock 4 CHU-ZCT2U Battery Replacement, shouldn’t the battery model be JDM-040 and not JDM-030 for this controller. I ordered the battery listed but the connector was too large. So I believe this needs to be edited to match accordingly to avoid confusion and incorrect orders. Thanks!
Tom Nguyen - crwdns2934203:0crwdne2934203:0
Good catch! I just pulled apart the ZCT1U and ZCT2U models and you are right. I will fix this in the guide. Thank you!
Sam Omiotek -
Can perhaps someone tell me what exact connector does the original battery use ?
MCQ - crwdns2934203:0crwdne2934203:0
Just bought and the connector does not fit for the newer gen controllers. Dissapointing
Bukayo Saka - crwdns2934203:0crwdne2934203:0
Is there a conclusion to this? I force charged two batteries from two controllers (which died within the same day) in a known good controller (which has the larger battery connector which can accommodate the smaller ones) each for about three hours (~470mA/h) until they each showed a measured 4ish volts dry test. Once plugged back in neither worked either with the ps button or usb physical connect but funny each will “share” by holding the PS+Share button for a while, idk how to have it actually pair with my station any more. Even after using the reset button on the back. Haaaalp :). I’ll likely figure it out before someone responds to this but for the sake of anyone who can’t troubleshoot please post any answer if you have one, kThanksXO
Apple AT - crwdns2934203:0crwdne2934203:0
I purchased the recommended JDM-040 replacement battery for my CUH-ZCT2U controller (before reading these comments) and it does NOT work as a replacement. The connector is wrong, and the pin holes are too small.
Regarding those asking if the JDM-030 battery works, the connector is also wrong. I can confirm, though, that the JDM-030 is the correct replacement battery for the CUH-ZCT1U controller.
CTri - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 38
crwdns2936753:07crwdne2936753:0 290
crwdns2936753:030crwdne2936753:0 1,051
crwdns2942667:0crwdne2942667:0 41,112
