DualSense Joystick Replacement
  1. DualSense Joystick Replacement, Unclip the right end of the middle trim: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Joystick Replacement, Unclip the right end of the middle trim: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. DualSense Joystick Replacement, Unclip the lower-right edge of the middle trim: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualSense Joystick Replacement, Unclip the lower-right edge of the middle trim: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualSense Joystick Replacement, Unclip the lower-right edge of the middle trim: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. DualSense Joystick Replacement, Unclip the left end of the middle trim: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Joystick Replacement, Unclip the left end of the middle trim: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. DualSense Joystick Replacement, Unclip the lower-left edge of the middle trim: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualSense Joystick Replacement, Unclip the lower-left edge of the middle trim: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualSense Joystick Replacement, Unclip the lower-left edge of the middle trim: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. DualSense Joystick Replacement, Remove the middle trim: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualSense Joystick Replacement, Remove the middle trim: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualSense Joystick Replacement, Remove the middle trim: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
  6. DualSense Joystick Replacement, Remove the L1 button: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualSense Joystick Replacement, Remove the L1 button: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualSense Joystick Replacement, Remove the L1 button: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With one hand, grip the controller and use your thumb to hold down the left trigger.
    • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
    • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
  7. DualSense Joystick Replacement, Remove the R1 button: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualSense Joystick Replacement, Remove the R1 button: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualSense Joystick Replacement, Remove the R1 button: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step to remove the R1 button.
  8. DualSense Joystick Replacement, Remove the rear case screws: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Joystick Replacement, Remove the rear case screws: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
  9. DualSense Joystick Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Joystick Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
  10. DualSense Joystick Replacement, Separate the rear case: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualSense Joystick Replacement, Separate the rear case: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualSense Joystick Replacement, Separate the rear case: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be gentle when releasing the rear cover clips—they're delicate and can easily break.
    • Use the point of a spudger to release the two clips on either side of the headset jack.
  11. DualSense Joystick Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualSense Joystick Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualSense Joystick Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Tight plastic clips secure the left and right edges of the rear case.
    • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
    • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
  12. DualSense Joystick Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualSense Joystick Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualSense Joystick Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step on the right edge to release its clips.
  13. DualSense Joystick Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Joystick Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay your controller upside down so the joysticks are on your work surface.
    • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
  14. DualSense Joystick Replacement, Remove the rear case: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rear case.
  15. DualSense Joystick Replacement, Disconnect the battery: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Joystick Replacement, Disconnect the battery: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
    • Grip the connector, not the wires, when disconnecting.
  16. DualSense Joystick Replacement, Remove the battery: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Joystick Replacement, Remove the battery: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery straight out of the battery bracket.
  17. DualSense Joystick Replacement, Remove the lower microphone: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Joystick Replacement, Remove the lower microphone: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
  18. DualSense Joystick Replacement, Remove the battery bracket: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Joystick Replacement, Remove the battery bracket: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the 6.4 mm screw securing the battery bracket.
  19. DualSense Joystick Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Joystick Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery bracket out of the motherboard.
  20. DualSense Joystick Replacement, Disconnect the right trigger assembly: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Joystick Replacement, Disconnect the right trigger assembly: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
    • Do not completely remove the ribbon cable yet.
  21. DualSense Joystick Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Joystick Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
    • Remove the ribbon cable.
  22. DualSense Joystick Replacement, Disconnect the left trigger assembly: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Joystick Replacement, Disconnect the left trigger assembly: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
  23. DualSense Joystick Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Joystick Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
  24. DualSense Joystick Replacement, Disconnect the upper microphone: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Joystick Replacement, Disconnect the upper microphone: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers or your fingers to grip the upper microphone ribbon cable pull tab, and pull up to disconnect it from the motherboard.
  25. DualSense Joystick Replacement, Disconnect the touchpad: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Joystick Replacement, Disconnect the touchpad: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers or your fingers to grip the touchpad ribbon cable pull tab, and pull it straight out of the motherboard connector.
  26. DualSense Joystick Replacement, Lift out the motherboard: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualSense Joystick Replacement, Lift out the motherboard: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualSense Joystick Replacement, Lift out the motherboard: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully guide the joysticks through the front case and lift the motherboard out.
    • The motherboard is held down by two clips. One between the motherboard itself and the right trigger assembly, and one between the motherboard itself and the left trigger assembly. Gently push on either clip to release the motherboard from its restraints.
    • Do not completely remove the motherboard. There are four soldered wires tethering the motherboard to the vibrator motors.
  27. DualSense Joystick Replacement, Desolder the vibration motors: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualSense Joystick Replacement, Desolder the vibration motors: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualSense Joystick Replacement, Desolder the vibration motors: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The next few steps require desoldering and soldering connections. To learn how to solder, check out our soldering guide—if you've already soldered, you can still find some helpful tips and tricks in this guide!
    • Flip over the controller and motherboard.
    • Use a soldering iron to desolder the vibration motor wires from the motherboard:
    • Two red wires
    • Two black wires
    • During reassembly, remember to solder the wires back into the same position. The red wires belong closest to the edge and next to the Rs on the motherboard.
  28. DualSense Joystick Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the controller from the motherboard.
  29. DualSense Joystick Replacement, Remove the joystick covers: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualSense Joystick Replacement, Remove the joystick covers: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualSense Joystick Replacement, Remove the joystick covers: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the joystick covers straight off the joystick assemblies.
    • Only the motherboard remains.
  30. DualSense Joystick Replacement, Desolder the joysticks: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Joystick Replacement, Desolder the joysticks: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Desoldering Pump
    $3.99
  31. DualSense Joystick Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the joysticks from the motherboard.
crwdns2935229:067crwdne2935229:0
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
87,069 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
crwdns2947412:029crwdne2947412:0
can I use Dualshock 4 joystick in the Dualsense ?
Kia - crwdns2934203:0crwdne2934203:0
Yes, the joysticks are the same in both controllers.
Wes -
How do you differentiate a real joystick part from fake ones? Since in my situation i can't order straight from sony.
TryJak - crwdns2934203:0crwdne2934203:0
I would suggest getting a PS4 Dualshock controller from the classifieds since there's a pile of them available for cheap and take the analogue stick from there.
Philip Sedlmair -
Thanks for the tutorial! I wonder if anyone has a problem after replacing the joystick? The controller simply won't turn on. If I connect the controller to either ps5 or my pc via usb, it will blink 3 times in orange and turn off. If I press the PS button when connected with usb, it will also blink orange 3 times and nothing happens. I've tried hard reset by using the hole on the back but it didn't help. Any advice??
zirimark - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 346
crwdns2936753:07crwdne2936753:0 2,628
crwdns2936753:030crwdne2936753:0 12,521
crwdns2942667:0crwdne2942667:0 259,932
