How to Use a Desoldering Pump
    1. How to Use a Desoldering Pump, Prime the pump: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use a Desoldering Pump, Prime the pump: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      Desoldering Pump
      $3.99
      • If this is your first time using a desoldering pump, try priming and activating the pump a few times before you use it for desoldering purposes.
      • Firmly grasp the desoldering pump with your hand.
      • Depress the plunger until it locks in place.
      • This primes the spring-loaded piston for suction.
    2. How to Use a Desoldering Pump, Activate the pump: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use a Desoldering Pump, Activate the pump: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • To activate the pump, press the black side button.
      • This releases the spring-loaded piston, which creates a burst of suction at the nozzle.
      • The piston release creates a substantial kickback. Brace your hand when you use the pump to keep the nozzle steady.
    3. How to Use a Desoldering Pump, Desolder a joint: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Use a Desoldering Pump, Desolder a joint: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Use a Desoldering Pump, Desolder a joint: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      FixHub Smart Soldering Iron
      $79.95
      • Do not use the desoldering pump to desolder joints near small surface-mounted (SMT) components. The heat spillover and suction may dislodge the SMT components.
      • Prime the desoldering pump by depressing the plunger.
      • Heat the solder joint until the solder is liquified. To help with heat transfer, add some solder onto the soldering iron's tip.
      • Position the pump's nozzle as close to the molten solder as possible.
      • The nozzle is made of heat-resistant plastic, so don't worry if you occasionally brush the tip with it.
      • Press the side button to activate the pump.
      • Repeat the process until the joint is clean. You can also use solder wick to help soak up any remnant solder.
    4. How to Use a Desoldering Pump, Clean the desoldering pump: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Use a Desoldering Pump, Clean the desoldering pump: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Use a Desoldering Pump, Clean the desoldering pump: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • To clean the pump, prime and activate the pump a few times. This pushes a rod through the nozzle and ensures that solder doesn't block it.
      • On the rare occasion when the pump needs a more thorough cleaning, you can disassemble the pump to clean it out:
      • Grasp the nozzle by its knurled edge.
      • Twist the nozzle counter-clockwise to unscrew it. This may be difficult due to a tight-fitting O-ring.
      • Remove the nozzle and clean out the pump interior.
For soldering instructions and tips, follow this guide.
crwdns2935229:096crwdne2935229:0
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
350.781 crwdns2915208:0crwdne2915208:0
crwdns2935297:0938crwdne2935297:0
Staff
crwdns2935297:072.401crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Good review, but I’ve found that these small solder suckers don’t do a very good job. The much larger “Soldapult” (https://www.edsyn.com/product/DS017.html) provides much more suction and can often completely clear a joint in one use.
shamino - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Apply higher temperature on your soldering iron, above 380°C.
Use bigger tip, bigger heating surface provides more effecitive heat transfer.
SchwarzeKatz - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
If you are asking about why the tip of the solder sucker doesn't melt, it is made of a heat resitant material. Notice the word resistant.
Budda Belly - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Realmente me estoy interesando en este rubro y espero çontinuar aprendiendo para que me sirva como terapia
Jaime Rivera - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 53
crwdns2936753:07crwdne2936753:0 413
crwdns2936753:030crwdne2936753:0 1,797
crwdns2942667:0crwdne2942667:0 123,235
