Descaling of the upper brewing piston
    • Leave the plug in the socket and turn off the machine. The main switch – if available – must be turned on.
    • Empty the water tank and add about half a liter of descaling solution. Use only a good descaling agent based on sulfamic acid, as prescribed by the manufacturer. You can find more information about this here.
  1. Descaling of the upper brewing piston: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put your DeLonghi in test mode. We have lots of instructions for this. If your model is not included, then search for it in the internet.
    • Your machine must be in test mode. Select the appropriate option to move the brewing unit to the upper end position.
    • See here for ESAM models
    • See here for ECAM models with touch controls
    • See here for ECAM models with real buttons
    • Run the pump until the descaling agent comes out of the coffee spout.
    • Now the descaling agent can take effect in the upper flask. Wait for about two minutes.
    • Repeat this process several times.
    • Remain in test mode; the brewing unit is still in the upper end position.
    • Empty the water tank and refill with fresh water.
    • Run the pump again to flush out the remains of the descaling agent.
    • Move the brewing unit down a little again.
    • Unplug the machine to exit test mode.
    • Reconnect the plug and turn on the machine. It should automatically find the start position and be ready for use.
  2. Descaling of the upper brewing piston: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Descaling of the upper brewing piston: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The two pictures show a dirty/calcified upper brewing piston before and after repair.
    • Try to see if the machine works normally. If no coffee comes out, the seals in the upper piston may be damaged:
    • Remove the brew unit.
    • Put the machine to one side and use a flashlight to examine the upper brewing piston. A small mirror may also be helpful.
    • The upper piston is transparent. There must be no dirt or liquid inside it. If there is (as shown in the photo), you will need to have it serviced or replaced. You can find our instructions for ECAM, ETAM and ESAM here.
Follow the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
268,512 crwdns2915208:0crwdne2915208:0
crwdns2935297:0301crwdne2935297:0
Repair is War on Entropy crwdns2935289:0Repair is War on Entropycrwdne2935289:0
Community
crwdns2931471:030crwdne2931471:0
crwdns2935297:01,513crwdne2935297:0
Frage: Es kommt die Meldung
Wasserkreislauf leer
Wasserkreislauf füllen
Wasser ist im Behälter
Pumpe will aber geht nicht
Was nu?
Inca Jaeger - crwdns2934203:0crwdne2934203:0
Also: die Pumpe geht, stark und kräftig? Dann würde ich eine Verstopfung vermuten, oft ist es das Flowmeter. Dazu haben wir Anleitungen.
VauWeh -
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 55
crwdns2936753:030crwdne2936753:0 204
crwdns2942667:0crwdne2942667:0 2,023
