Apple Watch Series 5 Battery Replacement
  1. Apple Watch Series 5 Battery Replacement, Display Opening: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 5 Battery Replacement, Display Opening: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  2. Apple Watch Series 5 Battery Replacement, Safety Requirements: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch Series 5 Battery Replacement, Safety Requirements: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch Series 5 Battery Replacement, Safety Requirements: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Safety Glasses
    $3.19
    • Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
    • Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
    • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
    • Wear eye protection. The knife or glass may break, sending pieces flying.
    • Attach or remove the watch band as needed to provide more control as you make repairs.
  3. Apple Watch Series 5 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the display adhesive.
    • Leave the iOpener on the watch for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
    • You may need to reheat the iOpener and repeat this procedure several times until the display adhesive softens.
    How long should it take for applied heat to melt the adhesive? I feel like I've been heating and reheating this iOpener for days.
    Samuel Kurnit - crwdns2934203:0crwdne2934203:0
    @samuelkurnit The heat doesn't melt the adhesive, but helps loosen the adhesive and hopefully makes it more pliable for the next step. Just mentioning this to dissuade any thought of a person solely relying on heat to open up the watch. It took me 3-4 continuous hours of heating and prying with a knife to open up my watch.
    Booster Boards - crwdns2934203:0crwdne2934203:0
    I used both the iOpener and a heat gun at a distance. I probably did around 5-6 rounds of the iOpener. It came open PERFECTLY. Patience is a must. I use a very flexible broad flexing knife for the open. It took the fear out of cutting my hands and also avoided scratching the watch.
    Just take your time and go slow. You will get there with time and patience. I probably did the open in about 20 minutes.
    Jeremy - crwdns2934203:0crwdne2934203:0
  4. Apple Watch Series 5 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch Series 5 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch Series 5 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, closest to the digital crown.
    • Press firmly straight down into the gap.
    • Once inserted, tilt the blade to pry the display open slightly.
    • Do not insert the knife more than 1/16th of an inch (~2 mm) to avoid damaging the force touch sensor.
    I just could not break the seal without using some gentle heat!
    dieseldougie - crwdns2934203:0crwdne2934203:0
  5. Apple Watch Series 5 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 5 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you've opened a small gap with the curved blade, remove the blade and insert the thinner edge of an opening tool into the gap.
    • Push the opening tool into the gap, using your thumb as a pivot to lift the display open a bit farther.
    • Don't try to fully open or detach the display yet.
  6. Apple Watch Series 5 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch Series 5 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch Series 5 Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • It's likely that the force touch sensor will stick to the display frame instead to the watch's body. In this case, insert an opening pick under the display and carefully separate the Force Touch gasket from the display.
    • To preserve the Force Touch gasket, pry carefully under the edge of the display. If the Force Touch gasket splits when lifting the display, or if you separate the gasket layers, you'll also need to replace the Force Touch gasket itself.
    • Slide the pick around the display to separate the adhesive between the Force Touch gasket and the display.
    • Don't insert the opening pick deeper than 1/16th of an inch (~2 mm) to avoid damaging other components.
    What happens if the Force Touch Gasket is intact, but simply has come loose from the frame in spots?
    Michael Czeiszperger - crwdns2934203:0crwdne2934203:0
    I have the same Issue: I will clue the Force Touch sensor back to the frame with T-7000 Clue. So i hope it works.
    joachimschreiter -
  7. Apple Watch Series 5 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 5 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Avoid tensioning the display cables when folding the screen to the back.
    • Carefully lift the display open like a book.
  8. Apple Watch Series 5 Battery Replacement, Battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 5 Battery Replacement, Battery: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the screen until there's enough space to access the battery.
    • Insert an opening pick between the battery and the Taptic Engine.
    • A regular opening pick works fine with the 44 mm version of the Apple Watch Series 5. However if you own the 40 mm version and don't have enough space you can customize your opening pick with scissors.
  9. Apple Watch Series 5 Battery Replacement, Pry up the Battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch Series 5 Battery Replacement, Pry up the Battery: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch Series 5 Battery Replacement, Pry up the Battery: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick along the edge of the battery to loosen the adhesive.
    • The battery adhesive is soft. However, if you're struggling to pry out the battery you can place a heated iOpener on the rear side of the watch to loosen the adhesive. Apply the iOpener for at least two minutes.
    • Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the mainboard.
    • Avoid damaging the display cables, and especially the force touch cable, which covers the battery in one corner during the prying procedure.
    • Make sure you don't puncture or deform the battery, as it can catch fire and/or explode if damaged.
    • Don't try to remove the battery all the way yet. It is still connected to the watch assembly.
  10. Apple Watch Series 5 Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the battery to a 75-degree angle.
    • Remove the 1.1 mm-long Y000 screw.
    Ma il cacciavite Tri Point Y000 è quello da 0,6mm? grazie
    ellycelli - crwdns2934203:0crwdne2934203:0
    @ellycelli 1,1 mm indica la lunghezza del gambo della vita e non ha niente da fare con il diametro della testa della vita.
    Claire Miesch -
  11. Apple Watch Series 5 Battery Replacement, Remove The Metal Plate: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 5 Battery Replacement, Remove The Metal Plate: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the metal plate covering the battery connector.
  12. Apple Watch Series 5 Battery Replacement, Disconnect the battery: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 5 Battery Replacement, Disconnect the battery: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the battery flex cable.
  13. Apple Watch Series 5 Battery Replacement, Remove the Battery: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 5 Battery Replacement, Remove the Battery: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Tesa 61395 Tape
    $5.99
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • If you are reusing your old battery during reassembly, you can reuse the existing adhesive to secure the battery during reassembly. Alternatively, remove the old adhesive with high isopropyl alcohol and a lint free cloth and use a small piece of double-sided tape such as Tesa 61395, or a dab of liquid adhesive such as E6000.
    • Follow the resealing guide to reseal your watch after reassembly.
    I did use Tesa tape to restick the screen but I think the E6000 would be easier to apply and provide a full all round watertight seal.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery after completing this guide.
crwdns2935229:039crwdne2935229:0
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
232,833 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020,030crwdne2935297:0
crwdns2947412:08crwdne2947412:0
Since WatchOS 7 removed 3D Touch functionality on all Force Touch enabled watches, will damaging or disconnecting the Force Touch gasket affect the functionality of the watch or will the software brick it?
AStupidMidge - crwdns2934203:0crwdne2934203:0
Any tips for applying the adhesive strip without removing the screen? Is removing the screen recommended to seat it properly?
David Mifsud - crwdns2934203:0crwdne2934203:0
Does the resealing adhesive strip go in between the screen and force touch gasket, or the force touch gasket and the case?
Hi David,
here is a general resealing guide that might help you. Depending on your force touch replacement part you‘ll need one two or no adhesive strips.
If your force touch was never removed you need to place new adhesive on top of it the adhere the screen. If your force touch has adhesive on the bottom side it is the same. Adhere the force touch into the watch frame and place adhesive on top of it to adhere the screen. If there is adhesive on the top of the force touch you need to place the adhesive strip beneath.
If your force touch didn‘t come with any adhesive preinstalled you need adhesive tape below to secure it to the watch frame and on top to secure the screen.
Dominik Schnabelrauch -
Hi @schnabel , thank you for you reply. I am in the middle of replacing the battery. I managed to save the force touch sensor from getting damaged, but I need to be re-adhere it to both surfaces. Can I use 2 of these adhesive strips on either side?
Apple Watch (44 mm Series 4/5) Screen Adhesive
David Mifsud -
Hey David, I guess this should work for your repair! But make sure to remove all the adhesive leftovers from your old force touch, screen and watch housing before reinstalling the force touch (for example with a Q-tip and high concentration isopropyl alcohol >90%). Otherwise the new double adhesive and force touch sandwich might become too thick and you won‘t be able to close the watch seamlessly.
Just finished sealing mine up and am now weighing it down with some books. I'm new to repairs so this one took many, many hours for me. I used ifixit manufactured or recommended products for everything from the tools to the battery to the seals. What I've learned or experienced:
1. It took me an an embarrassing three hours to cut/pry open the display from the outer case. I almost always have a wrap-around case on my watch so I wonder if that may have added difficulty by constantly pressing the display and the outer case together.
2. In the frenzy to open up the watch, my blade accidentally went deeper into the watch than recommended by this guide. I did destroy the gasket, and needed to remove it completely after opening up the watch. However, I noted that the most up-to-date watchOS obviate the need for the force touch gasket so I did not install a replacement when putting back my watch together.
3. I received two defective ifixit replacement batteries. Customer service was helpful and the 3rd battery worked.
Does replacing an Apple Watch battery with a third party component automatically restore battery health to 100 % in the watchOS settings app or will there also be a warning message about non genuine parts like in iOS with battery health not showing anymore after replacement? Thanks for answering.
Xuefeng Bai - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 107
crwdns2936753:07crwdne2936753:0 667
crwdns2936753:030crwdne2936753:0 2,782
crwdns2942667:0crwdne2942667:0 115,303
