Battery
crwdns2933315:02crwdne2933315:0 crwdns2934263:03crwdne2934263:0 |
Are the Verizon and AT&T iPhone 4 Batteries the Same? |
crwdns2933315:04crwdne2933315:0 crwdns2934263:07crwdne2934263:0 |
Removing oil from inside my iPhone. |
crwdns2933315:04crwdne2933315:0 crwdns2934263:03crwdne2934263:0 |
Logic Board Rubber Bumper Location? |
crwdns2933315:05crwdne2933315:0 crwdns2934263:03crwdne2934263:0 |
Inverted Screen (negative and bright colors) after Replacing Glass |
A1349 CDMA/16GB, A1349 CDMA/32GB, A1349 CDMA/8GB
Background
Seven months after introducing the iPhone 4, Apple announced a CDMA version—the first Apple device capable of running on Verizon's cellular network.
Apart from the differences in wireless technology, the Verizon version of the iPhone 4 is essentially identical to the existing (GSM-spec) iPhone 4, the fourth iteration of Apple's cellphone line. It is differentiated from earlier generations by having a squarish physical appearance, glass for both front and back panels, and a steel frame that doubles as reception antennas.
Repair is straightforward, but the front glass and LCD must be replaced as a unit. Difficulty with repairing the iPhone 4 depends on which part of the phone fails. The front panel glass is fused to the LCD and digitizer, which means that the glass can no longer be repaired or replaced individually. Users who accidentally shatter the iPhone 4's front panel will have to replace all three (as a single unit) in order to successfully repair their iPhone 4. The back panel, however, is replaceable by unscrewing two screws and sliding up the panel.
Replacing the battery, on the other hand, will be easily accomplished -- even though Apple ascertains that no parts within the iPhone 4 are user-serviceable. To replace the battery, the user can follow iFixit's battery replacement guide to remove the back panel and disconnect the battery.
Identification
You can identify the iPhone 4 by one of the following model numbers etched into the back case:
- A1332
- A1349
The iPhone 4 features a flat glass front and back with flat stainless steel edges. Circular volume buttons and a ring/silent toggle switch are situated on the left side. This model has no SIM tray. The power button and aux port are on the top side.
The iPhone 4 has a black or white front and back with silver edges.
Specifications
Announced On: January 11, 2011
Model: A1349
Developer: http://www.apple.com
Operating System: iOS 4.0 through iOS 7.1.1
Display (Retina Display):
- 3.5 in (89 mm)
- 3:2 aspect ratio
- 960 x 640 px at 326 ppi
- 800:1 contrast ratio
- Scratch-Resistant, glossy, glass-covered IPS LCD screen
- Oleophobic coating
Camera: Contains both front and rear facing cameras.
- Front Camera
- .3 MP
- SD Video (480p) at 30fps
- Rear Camera
- 5MP
- HD Video (720p) at 30fps
- LED Flash
Processor: Apple A4 system-on-a-chip
RAM: 512 MB eDRAM
Storage: 8, 16, or 32 GB Flash Memory
Wireless Connectivity:
- Integrated 802.11n (2.4 GHz only)
- Bluetooth 2.1 + EDR
- CDMA (EV-DO Rev. A, 800 MHz, 1900 MHz)
Battery: 3.7V 1,420 mAh
Dimensions: 4.5 × 2.31 × 0.37 in (115.2 × 58.6 × 9.3 mm)
Weight: 137 g (4.8 oz)
Colors: Black or White
Troubleshooting
- Diagnose your hardware issues with our iPhone 4 Troubleshooting Guide.
- Diagnose and repair screen backlight issues with our iDevice Backlight Troubleshooting Page.
Additional Information
- Thanks to Nathan Henderson for this great screw mat for the display repair: iphone4cdmascrewtemp.pdf
- Wikipedia: iPhone
- EveryMac: iPhone Specs
- Apple: iPhone Products
- iFixit Blog: iPhone 4 Wallpapers Gyros and Internals
- iFixit Blog: Verizon iPhone 4 Teardown
- iFixit Blog: iPhone 4G Processor Revealed
