The Basics
Before undertaking any of the more time-consuming solutions below, here are a few fundamentals to get you started.
  • Verify your sound functions. If you're turning up the volume, but not getting sound, see the iPhone No Sound page instead.
  • Restart your iPhone. Note that iPhone X and newer models require one functional volume buttons to power off, or force restart.
  • Process all updates.
  • Remove your case, or ensure any button cutouts are aligned properly.
  • Use of assistive touch can be a reasonable work around. This can be enabled under Settings > Accessibility > Touch > Assistive Touch. This enables a configurable menu to appear on screen. Pressing Customize Top Menu in these settings will allow you to add or remove functions, volume up and down buttons included.
Sound Settings
Although “sound” on an iPhone seems simple, it is actually a conglomeration of several different settings. Each audio related function in the phone has its own correlated setting (ie. phone call, media, ringer, etc…).
  • Ensure that changing volume settings with buttons is enabled. Under Settings > Sound the “Change With Buttons” setting is hiding. Toggle it on to permit ringer volume to be modified with buttons.
  • Verify that the Silent/Ringer toggle switch is set to ring (hint: silent is orange). The position of this switch overrides all other ringer settings.
  • Is Do Not Disturb on? This would also override volume settings for incoming communications. On newer versions of iOS, Do Not Disturb has been replaced by Focus.
  • Check that the volume level for the sound setting you're missing is set to the expected level. Volume controls are context sensitive and adjust the volume for the current function. For a quick look at the current volume level, use Control Center.
  • Reset all settings to revert any settings which may have been enabled. The prompt to do this is located at Settings > General > Reset > Reset All Settings. Note: Be ''''mindful not to click Erase All Content and Settings, that will also delete your personal data, not just changes made to configuration.
Buggy Software
Any software which contains errors can cause an iPhone to act as though a button is not responsive.
  1. Use the buttons in another context. Try to turn up or down volume in a different app, or function.
  2. If the buttons work in other functions, open the App Switcher and close the problematic app.
  3. Reopen the affected app and try to recreate the issue. If it reoccurs, check the App Store for updates and install them. Uninstall and reinstall the app if no updates are present.
If your buttons are also unresponsive in other functions, this is more likely a hardware issue.
  1. To rule out software entirely, be sure you have a current backup, and restore your phone via a computer to ensure a fresh copy of the Operating System is used. This will delete all data on the phone. Try without restoring your back up at first to keep testing limited to a bare OS.
Volume Buttons Stuck
Buttons are magnets for debris. Eventually enough may collect to interfere with the buttons depressing properly.
  • Check the button’s movement, is it depressing, or clicking when you press it?
  • If it is not clicking when pushed, make sure the buttons are not deformed in any way. A dent in the wrong place can cause a button to stick in one position. This calls for a replacement of the buttons covers.
  • In the absence of damage, turn it off and clean any debris around the buttons with a toothpick. A cotton swab and ispropyl alcohol can assist in persistent crud and help loosen any that may have worked its way under the button.
  • If they still seem stuck, internal cleaning or inspection is necessary, The buttons are visible mounted into the housing. Physical debris may also be lodged here, preventing proper function.
Damaged Cables
An unfortunate part of the design for most models is the volume buttons are a part of a cable assembly which carries the signal for all the iPhone buttons. This means the cables are often long, thin and follow inconvenient paths along the phone’s interior. They can be damaged by liquid contact, or torn by shattered glass or attempted repairs.
  • Perform a visual inspection of the cables. Most of these issues arise from underlying damage visible to the naked eye. Tears, creases or signs of liquid should send up red flags.
  • Verify connectors are intact and free of damage or corrosion.
  • Even in the absence of visual damage, replacing the cables for these buttons is a reasonable step.
Logic Board
The logic board is the hub for the vast majority of an iPhone's functionality. Any number of the small components on the board may have failed or become damaged, and is a safe assumption of cause if nothing else on this page has worked.
  • Check for obvious signs of a board issue - burned or cracked components, liquid residue, corrosion or bend. If there are signs of liquid the iPhone Liquid Damage Guide might help.
  • Replacing the logic board is often the most practical solution for a DIYer in this position. But due to Touch ID pairing, replacing the board will break fingerprint reading functionality in all cases and home button function as well in the iPhone 7 and newer.
  • Contrary to popular belief, the board itself can be repaired. However, it requires specialized tools and microsoldering know-how. This is not something most people can do themselves, but many independent repair shops can do it for you! Ask around to find a board level repair specialists near you.
Alisha C
crwdns2935283:012/04/20crwdne2935283:0
43,599 crwdns2915208:0crwdne2915208:0
LGBTQ Technicians crwdns2935289:0LGBTQ Technicianscrwdne2935289:0
Community
crwdns2931471:071crwdne2931471:0
crwdns2935297:0852crwdne2935297:0
crwdns2936751:024crwdne2936751:0 53
crwdns2936753:07crwdne2936753:0 319
crwdns2936753:030crwdne2936753:0 1,469
crwdns2959996:0crwdne2959996:0 77,083
