So, you got that notification yet again—a Software Update is ready. Against your better judgment, you clicked install. But now your phone has transformed itself into a digital picture frame with only one image - that pesky Apple logo. Maybe you didn't do anything out of the ordinary. Maybe you simply picked up your phone to check a text, only to be taunted instead by that perpetual glowing fruit. Even if it seems that way, all is not lost. Just because your iPhone is stuck, doesn't mean you need to be too.
First Steps
Before undertaking any of the more time-consuming solutions below, there are a few fundamentals to give a go.
  • Be patient. If the iPhone has a progress bar under the Apple logo, chances are it's still trying to process something. Software updates can take a long time, an hour or more even, especially on aging hardware or for large version jumps. Take a breath, set down the phone, and come back in half an hour or so.
  • If there is no progress bar or the progress bar has not moved for at least half an hour, perform a force restart. This will begin the boot process again, clearing anything the phone may be hung up on.
    • Note: This may break the operating system if the phone is mid-update, causing it to boot to recovery mode after the restart. That's okay! Now you won't have to do it manually during later steps.
Software Corruption or Conflict
During the course of using your phone, something in the ones and zeroes that makes it run might have been lost or changed in a way that renders your device unusable. This is commonly a result of a botched update, an app that conflicts with functionality, or even a malicious piece of software.
To attempt to correct this, perform a reinstall of the operating system. You'll need to get it into recovery mode to initiate this process.
  1. Connect to a Mac or PC with iTunes install using a USB cable.
  2. Press the button combination that corresponds to the model of your iPhone.
    • For iPhone 8 and newer: Press and release the volume up button, then volume down, then press and hold the power button until the screen goes black. Continue holding this button until the recovery mode screen appears
    • For iPhone 7 and 7 Plus: Press and hold the volume down and power buttons until the display goes black. Release the volume button and continue holding power until the recovery mode screen appears.
    • For iPhone 6S and older: Press and hold the home and power buttons until the display goes black. Release the power button and continue holding home until the recovery mode screen appears.
  3. The connected computer should pop up with the message “There is a problem with the iPhone that requires it to be updated or restored.” To start, try an update.
    • If the update is unsuccessful, it's time to assess the state of your backups. If you're certain you have a recent backup or are willing to sacrifice your data to regain the use of your phone, proceed to restore. This will erase any data presently on your phone.
    • If the update or restore fails with an error message, document it. Now might be a good time to visit the Answers forum, where you can get more personalized help. Be sure to mention the error message in your question!
Storage Is Full
Have you been getting warnings that your device is running low on storage? It’s easy to ignore, but computerized devices also need some free space to operate properly. Think of it like your sock drawer. You can squish any number of additional pairs of socks in, but eventually, your drawer will stop closing. It’s possible your phone is in this “can no longer function as intended,” state.
  • Try the force restart steps outlined at the beginning of this page again. A few times even. If you’re lucky, this may allow you the one successful boot you need to get in and clear out some of the five hundred blurry pictures of your puppy chasing a paper bag around the yard.
  • If this doesn’t work, ultimately you’re going to need to reset your device—especially if you've been getting recent low storage warnings prior to the issue popping up. If it’s not already in recovery mode, you’ll need to get it there and restore your device by connecting it to a Mac or PC with iTunes.
    • This may be the underlying fault if you have received errors 14, 78, or 1110 when processing a recovery mode update.
Logic Board
The logic board is the hub for the vast majority of an iPhone's functionality. Any number of the small components on the board may have failed or become damaged, resulting in this sort of issue.
  • Board damage can be caused by liquid contact, electric insult, a significant drop, or even flexion from being repeatedly shoved into your pocket. Check to see if your board looks bent, has signs of liquid, burn or loose components.
    • You can inspect your logic board by following the appropriate logic board guide for your model iPhone.
  • Replacing the logic board is often the most practical solution for a DIYer in this position.
  • If you’re feeling especially curious, the tiny bits and chips on the board can be repaired by microsoldering. It is an art unto itself, but a worthy endeavor for those who are adventurous. Interested? Check out this intro! Jessa’s YouTube channel is also fantastic and has loads of real-time repairs. If you can't do this sort of repair yourself, you may be able to find a local shop that can!
Alisha C
crwdns2935283:012/04/20crwdne2935283:0
43,587 crwdns2915208:0crwdne2915208:0
LGBTQ Technicians crwdns2935289:0LGBTQ Technicianscrwdne2935289:0
Community
crwdns2931471:071crwdne2931471:0
crwdns2935297:0852crwdne2935297:0
crwdns2944067:06crwdne2944067:0
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 157
crwdns2936753:030crwdne2936753:0 785
crwdns2959996:0crwdne2959996:0 38,620
