crwdns2934263:01crwdne2934263:0
Background
Device Name: UP! Plus 2
Release Date: June 1st, 2013
This particular 3D printer was the first to offer automatic bed leveling and automatic height adjustments, making it one of the easiest 3D printers to use on the market to date.
The earliest revisions of the printer came with optical height detection switches for the auto-leveling process, which were later replaced by the more precise mechanical switches. However, the version with the height detection switch will not affect your repairs, as the switch is an external part that is only used during the auto-leveling process.
Identification
You can identify your UP! Plus 2 by the model, 3DP-14-4D, and serial numbers printed on a label located on the back of the 3D printer. This model has an off-white, metal body with a black printing platform in the front and the spool holder on the side of the device. The web address PP3DP.com is stamped on the side of the print head cover.
Specifications
Model Number: 3DP-14-4D
Printer Size: 245mm Wide x 260mm Deep x 350mm High (9.5 x 10.5 x 14 inch)
Weight: 5 Kg (11 lbs)
Supported Operating Systems: Windows XP, Windows Vista, Windows 7, Mac
Build Size: 140mm Wide x 140mm Deep x 135mm High (5.5 x 5.5 x 5.3 inch)
Build Material: ABS and PLA Plastic
Layer Thickness: Variable between 0.15/0.20 /0.25 /0.30 /0.35 /0.40 mm
Additional Information
Buy Used on Amazon
Community Support Forum for UP Brand Printers
UP! Plus 2 User Manual
Up! Plus 2 Product information
UP! Plus 2 Review and Features
UP Plus 2 クイックスタートガイド
Spencer Jefferson
crwdns2935283:010/12/14crwdne2935283:0
106 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Cal Poly, Team 14-31, Maness Fall 2014 crwdns2935289:0Cal Poly, Team 14-31, Maness Fall 2014crwdne2935289:0
CPSU-MANESS-F14S14G31
crwdns2936753:030crwdne2936753:0 48
crwdns2959996:0crwdne2959996:0 4,365
