crwdns2933307:0crwdne2933307:0
Background
The Razer Wolverine V2 Chroma RZ06-0401, released in September 2021, is a wired gaming controller used primarily for the Xbox and can also be used on PC. Currently (as of April 2024), this device is still being manufactured and produced. The device is not exclusive to certain regions of the world. The intended demographic for the Razer Wolverine V2 Chroma are people that play video games, specifically on Xbox consoles or PC. The controller allows for use of the Xbox app to customize the controller to match the playstyle of the player who is using the controller. At this time, the Razer Wolverine V2 Chroma is selling for $150 USD. The Razer Wolverine V2 Chroma made it onto an article where it was identified to be “The Best Competitive Xbox Controller”, making the controller a great option for users who play games competitively. Certain components on the controller have a stronger tendency to fail or malfunction; specifically the joysticks starting to drift, along with the buttons and triggers on the controller getting stuck or becoming unresponsive. There’s both widespread praise as well as complaints for this device. The Razer Wolverine V2 Chroma has been praised for its ergonomic design and the responsiveness of its buttons. Common complaints for the device include how it may not be worth it for its price due to how quick the buttons wear out. The Razer Wolverine V2 Chroma compares well to the other controller’s in its family. Feedback for it compared to other controllers comes out to be overall positive. This controller replaced its predecessors, particularly the Xbox Elite Series 2 Controller. The Razer Wolverine V2 Chroma appears to overall be a better controller compared to the one before it, due to the overall quality of the controller being better and allowing for it to last longer.
Identification
The Razer Wolverine V2 Chroma RZ06-0401 looks similar to a standard xbox one controller, except for the four additional back triggers and the Razer logo under the Xbox home button. The device has an (approximate) length of 161.5 mm / 6.35 in, width of 105.8 mm / 4.16 in, height of 65 mm / 2.55 in, and weight of 270 g / 0.595 lbs. This device comes in two different colors, black and white. If you want to guarantee that you have this model you can locate the model number on the back of the controller above the back triggers.
Technical Specifications
Compatibility: Xbox Series X|S, Xbox One, PC (Windows 10 or higher)
Connectivity: Wired / Detachable USB-C Cable (9.8 ft / 3m wired cable with strain relief)
Razer™ Mecha-Tactile Buttons : Yes
Multi-Function Buttons: 2 Top + 4 Back Buttons
Trigger Stops / Locks: Yes
Razer Chroma™ RGB: Yes
Customizable Thumbsticks: Yes
Circular D-Pad: Yes
Quick Control Panel: None
Interchangeable D-Pad: None
Trigger Stops: Hair Trigger Mode with trigger stops
Microphone Input: 3.5 mm analog audio port compatible for Xbox and PC
Audio Output: 3.5 mm analog audio port compatible for Xbox and PC
Configuration App: Yes
Artwork Customization: None
Carry Case: None
Mechanical Action Buttons: Razer™ Mecha-Tactile Action Buttons and Razer™ Mecha-Tactile D-Pad
Multifunction Buttons: 6 remappable multi-function buttons
Dimensions (approximate):
Length: 161.5 mm / 6.35 in
Width: 105.8 mm / 4.16 in
Height: 65 mm / 2.55 in
Weight: 270 g / 0.595 lbs
Source: RAZER WOLVERINE V2 CHROMA
Additional Information
Manufacturer’s Device Page
IGN's Review
Product Page
Kaylin
crwdns2935283:003/22/24crwdne2935283:0
434 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 6-3, Botvin Spring 2024 crwdns2935289:0UMass Dartmouth, Team 6-3, Botvin Spring 2024crwdne2935289:0
UMASSD-BOTVIN-S24S6G3
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 52
crwdns2936753:030crwdne2936753:0 209
crwdns2959996:0crwdne2959996:0 6,145
