All-In-One Cable
crwdns2933307:0crwdne2933307:0 crwdns2934263:01crwdne2934263:0 |
Scratch in the screen. |
crwdns2933307:0crwdne2933307:0 crwdns2934263:02crwdne2934263:0 |
replacement light shield (nose Rest - Flap |
crwdns2933307:0crwdne2933307:0 crwdns2934263:00crwdne2934263:0 |
Right eye flickering and RGB Lines |
red lines on one side |
Background
The HTC Vive Pro 2 is a VR headset that improves on the 2018 Vive Pro. The most notable improvements over the previous generation include a 5K display, LCD screens, 120° field of view, and 120Hz refresh rate. The Vive Pro 2 headset costs $799 USD.
Like previous models, this headset has adjustable headphones, integrated dual microphones, as well as Bluetooth and USB-C connections. This headset is also backwards-compatible with Vive Base Station 1.0, SteamVR Base Station 2.0, and the original Vive controllers.
The Vive Pro 2 is also sold as a kit containing the headset, left and right controllers, and two Base Station 2.0 units, for $1,399 USD.
Identification
Like the Vive Pro and the Vive Pro Eye, the Pro 2 has dual front-facing cameras, indentations around the edges of the headset, and the word VIVE printed between the cameras and on the plastic arms. However, the Pro 2 is the only Vive Pro headset that is primarily black with blue accents, whereas the others are mostly blue.
Technical Specifications
Screen: Dual RGB low persistence LCD
Resolution: 2448 × 2448 pixels per eye (4896 x 2448 pixels combined)
Refresh Rate: 90/120 Hz (only 90Hz supported via VIVE Wireless Adapter)
Field of view: Up to 120 degrees (horizontal)
Audio
- Hi-Res certified headset (via USB-C analog signal)
- Hi-Res certified headphones (removable)
- High impedance headphones support (via USB-C analog signal)
Inputs: Integrated dual microphones
Connections: Bluetooth, USB-C port for peripherals
Sensors: G-sensor, gyroscope, proximity, IPD sensor, SteamVR Tracking 2.0 (compatible with SteamVR 1.0 and 2.0 base stations)
Minimum Computer Specs
Processor: Intel Core i5-4590 or AMD Ryzen 1500 equivalent or greater
Graphics: NVIDIA GeForce GTX 1060 or AMD Radeon RX 480 equivalent or greater. GeForce RTX 20 Series (Turing) or AMD Radeon 5000 (Navi) generations or newer required for Full Resolution mode.
Memory: 8 GB RAM or more
Video out: DisplayPort 1.2 or higher. DisplayPort 1.4 or higher with DSC is required for Full Resolution mode.
USB ports: 1x USB 3.0 or newer
Operating system: Windows 11 / Windows 10
