Repair guides and support for Lenovo's line of consumer-oriented laptops, the IdeaPad series, first announced January 2008.
Démarrage de PC Lenovo IdeaPad 510 miix 12KB
الحاسوب لا يقلع بعد أن فتحته و تظهر في صورة your device ran into a problem and need to restart.
Stop code NTFS file system (0*24)
Translation Arabic - English
The computer does not boot after I opened it and it appears in the image:
@kamal97s this could be caused by corrupted system files, a bad HDDe, driver issues, or even malware. Start of by running chkdsk /f /r command. Use the sfc /scannow command to check for corrupted system files, and check your hard drive and memory for hardware issues. Let's see if our Windows guru @nick has a better solution for this issue.
Translation
@kamal97s قد يكون السبب تلف ملفات النظام، أو تلف القرص الصلب، أو مشاكل في برامج التشغيل، أو حتى وجود برامج ضارة. ابدأ بتشغيل الأمر chkdsk /f /r. استخدم الأمر sfc /scannow للتحقق من تلف ملفات النظام، وافحص القرص الصلب والذاكرة بحثًا عن مشاكل في الأجهزة. لنرَ إن كان خبير ويندوز @nick لديه حل أفضل لهذه المشكلة.
First thing I check for is the SMART data and make sure the drive itself isn't developing an issue. Use a tool like Parted Magic or a Linux distro like Ubuntu to get the data. This guide shows you how to do it: Diagnosing and Erasing Hard Drives
Beyond that, run Chkdsk from WinRE - make a bootable drive with this: Windows 10/11 - USB Installation Media Creation (Rufus) -- you want to go into Repair your computer>Advanced>Command line. Run the following command after switching it to the main drive (enter c:/ and then tun the command): chkdsk /f -- do not do /r right away as it takes a very long time. especially on spinning hard drives - but if need be, swap /f for /r and it will run the same, but /r checks for bad sectors which is the reason it takes so long -- and if the drive is failing, the load can "finish off" that drive. Yep, /r needs a healthy drive and is used as a last resort due to that potential risk. Reboot the PC and see if it boots again.
If that is not enough to fix it, boot back into the same drive, run the same steps but type SFC /SCANNOW. This will fix it while it runs. This probably is not the cause of failure, but give it a try. If it still has an issue, you may need to use the system restore tool to bring it back to a known good state, especially if a bad driver caused it or you forced Win11 on this machine and the machine was not a good candidate for the force upgrade :-(.
بالتأكيد، إليك ترجمة النص إلى اللغة العربية:
أول شيء أتحقق منه هو بيانات SMART والتأكد من أن القرص الصلب نفسه لا يعاني من مشكلة. استخدم أداة مثل Parted Magic أو توزيعة لينكس مثل Ubuntu للحصول على البيانات. يوضح لك هذا الدليل كيفية القيام بذلك: Diagnosing and Erasing Hard Drives
بعد ذلك، قم بتشغيل Chkdsk من بيئة WinRE - قم بإنشاء قرص قابل للتمهيد باستخدام هذا: Windows 10/11 - USB Installation Media Creation (Rufus) -- تريد الذهاب إلى إصلاح جهاز الكمبيوتر الخاص بك (Repair your computer) > خيارات متقدمة (Advanced) > سطر الأوامر (Command line). قم بتشغيل الأمر التالي بعد التبديل إلى محرك الأقراص الرئيسي (أدخل c:/ ثم قم بتشغيل الأمر): chkdsk /f -- لا تقم بتشغيل /r على الفور لأنه يستغرق وقتًا طويلاً جدًا، خاصة على الأقراص الصلبة الدوارة (spinning hard drives) - ولكن إذا لزم الأمر، استبدل /f بـ /r وسيتم تشغيله بنفس الطريقة، لكن /r يتحقق من القطاعات التالفة (bad sectors) وهذا هو سبب استغراقه وقتًا طويلاً - وإذا كان محرك الأقراص فاشلاً، فإن هذا الضغط يمكن أن "يجهز" على محرك الأقراص. نعم، يتطلب /r محرك أقراص سليمًا ويستخدم كـ ملاذ أخير بسبب هذا الخطر المحتمل. أعد تشغيل الكمبيوتر وشاهد ما إذا كان يعمل مرة أخرى.
crwdns2886500:0Linuxcrwdne2886500:0
crwdns2930805:0crwdne2930805:0
crwdns2934079:0crwdne2934079:0
crwdns2937801:0crwdne2937801:0
6 hours - 1 week
crwdns2886500:0Windows 11crwdne2886500:0
crwdns2937799:0crwdne2937799:0
30 minutes - 1 hour
Kamal 97 s crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 52
