The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
How to install apps on iso 9.3.5
apps not installing on iso 9.3.5 what is its solution
I think (and I'm sure a Mac expert will correct me if not!) that this iPad is only 32 bit compatible, and most apps on the app store now are 64 bit. So you may well be stuck I'm afraid.
iPadOS 9.xx is quite old and Apple has removed the older Apps within the iOS Apps Store with releases from iOS 15.xx on back. I don't even think you can even upgrade your iPad's iOS at this point to even the last version it could support which is iOS 9.3.6
Here's the EveryMac (iPad) link for one of the iPad 2 systems which is the same iOS EveryMac - iPad 2 hardware & OS information
So while remote if you have a backup of your stuff within iCloud you could still restore from it. You might find some web based Apps which will run under iOS Safari but that's about it.
VIKY JUTT crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 12
crwdns2942667:0crwdne2942667:0 12
