Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
No battery data after battery change
Hello,
I swapped my Mac‘s battery. When I turn on my Mac (with the original cable) it turns the fan on full speed and there is an X on the battery icon. Coconut battery shows no information. I installed another data cable for the Mac and it’s still the same behavior.
Is the data cable this weak? I was very careful while disabling it.
Then the BNC battery ribbon cable is not connected (check the latches) or is damaged. Review Steps 9 ~ 11 in this guide MacBook Pro 13" Two Thunderbolt Ports Late 2020 Battery Replacement
Here’s the needed cable MacBook Pro 13" Retina (A1708, A2159, A2338) Battery Daughter Board Cable
crwdns2886500:0Replace the small flex cable that connects the battery daughter board to the logic board.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$19.99
Thank you very much Dan.
Do I need a little bit of force to put the cable into the connector or is it fine to move it in softly?
I just moved it in slightly (where you can only see a little bit of the connectors yellow end) and closed the lid / ZIF connector. I can’t imagine to destroy or have two defective battery data cables. I hope the connector in the logic boards isn’t defective.
@ak2025 - If the latched you don’t want to force the cable in, if the latch is in the released condition you don’t need any force.
Think of a letter fitting into an envelope sliding it in squarely, that’s about all the force you would need at most.
These cables are easy to damage, even I’ve killed one.
AK2025 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 45
