Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
crwdns2934591:01233crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Screen or Logic Board fault?
I have an iPhone 5c that was water damaged. The phone boots to home screen, however the screen does not respond to touch. There is a bit of corrosion on the screen connector. After I clean the corrosion, if the problem persists, is there a way to know if it is just the screen or a board level problem?
Thanks!
Clean the connector. If that doesn’t work, try a different display. If that doesn’t work, then try the original display with a different phone. If that doesn’t work, try factory reset (if you’re willing to)
If all fail, then it’s board-level.
Good luck!
crwdns2942205:01crwdne2942205:0:
Thanks for the help!
Caleb Topper crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 35
