crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
The laser does not produce light
You press the Laser Trigger but the laser doesn't emit any light? We have plenty of tips and fixes for that problem.
The batteries are dead
There is a good chance that you just need to replace the batteries. To do this, unscrew and remove the screw holding the battery cover located on the bottom of the handle. Remove cover and ensure that they are inserted correctly. Then reinstall the battery cover. Check out our Battery replacement guide for more help.
The wire is severed
There is a chance that the wire connections have come apart. Reference our Wire replacement guide to see how to fix it.
The LED has failed
There is a chance that the LED has gone bad. Reference our LED replacement guide to see how to fix it.
Dirt and gunk is jammed under the laser trigger
Reference our Laser Trigger Replacement guide, but rather than replacing the trigger, use soap and water along with a cleaning cloth to clean out the dirt that is stuck under the trigger. In addition, clean the actual trigger for even better performance.
The triggers are either stuck or loose
Are either of the triggers stuck or broken? Don't worry they are easy enough to fix or replace.
Dirt and gunk is jammed under the firing trigger
Reference our Firing Trigger replacement guide, but instead of replacing the trigger, use soap and water along with a cleaning cloth to scrub out the dirt that is stuck under the trigger. Also, clean the actual trigger for even better results.
The firing trigger is cracked
If the firing trigger has cracked or broken off, reference our Laser Trigger replacement guide.
The blaster doesn't cock
You can't seem to load your gun? Here are some possible issues and how to fix them.
The plunger or O-ring is cracked
If the plunger or O-ring is cracked or broken, refer to our Plunger and O-Ring replacement guide.
The bullets fire weakly or slowly
The darts don't fly very far? Here are some typical causes and solutions.
The barrel is dirty
The lack of power in the gun may be due to a dirty barrel. Solve this problem by using a q-tip or cotton swab to scrub the inside of the barrel. This will work better if you use water.
Hayes Kimball
crwdns2935283:004/19/15crwdne2935283:0
742 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-6, Amido Spring 2015 crwdns2935289:0Cal Poly, Team 15-6, Amido Spring 2015crwdne2935289:0
CPSU-AMIDO-S15S15G6
crwdns2935297:096crwdne2935297:0
crwdns2944067:05crwdne2944067:0
i have a firestrike and it doenst $!^& propperly, the plunger shoots back but the Oring and the plunger seem to be fine any idea as to why it doesnt $!^&?
corwin schmitz - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
the issue was that the backside of the blaster(the screw holding the housing near the entry of the plunger) didnt have a good socket to fit in
i fixed this and the blaster seems to be working fine
Hi, I have a problem that when I shoot with nerf laser ops, I always hit. When the weapon is hidden and the opponent too, so that the laser receiver is not visible, it will light up the indicator that I hit him.
Luky HD - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My nerf darts keep on bouncing out of the blaster
Chukwuma Anaele - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 48
crwdns2959996:0crwdne2959996:0 7,208
