crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
1.) Distorted Sound
ST16S is not releasing sound or sound is distorted.
Faulty Speaker
The speaker itself may be faulty and will need to be replaced. For instructions on replacing a faulty speaker, visit this guide.
2.)  Non-Responsive Joystick
The joystick response is very slow and sluggish or completely non-responsive.
Oxidation Buildup
The bases of the joysticks build up oxidation and will need to be cleaned every once in a while. You can do this by spraying the base with an Electrical Contact Cleaner and moving the joysticks around a little bit.
Faulty Joystick
The joysticks themselves may be faulty and will need to be replaced. For instructions on replacing a faulty joystick, visit this guide.
3. Weak Battery
The controller takes too long or loses charge.
Battery is not charging properly
Make sure that the USB cord is working. If not, look to get a new USB cord. If that doesn’t work try taking out the battery for about a minute and plug it back in. You may also try taking the battery out of the controller and charging it itself.
Faulty battery
If you’ve tried the options above and the battery still isn’t functioning properly, it may need to be replaced. For instructions on replacing a faulty battery, visit this guide.
4. Broken Handle
Carrying handle is cracked or broken.
Broken Handle
The handle might have been dropped causing the handle to crack or break. For instructions on how to replace the handle, visit this guide.
5. Connection Problems
The drone does not move with joystick input.
Faulty Antenna
The ST16S uses two antennas, mounted on the top of the controller, to connect to the drone. Broken or missing antennas can be easily replaced using this guide.
Broken Drone
If you believe the problem is with the drone itself and not the controller, search for a guide on the drone model you are using.
6. Overheating
ST16S overheats after use
Faulty Cooling Fan
The internal cooling fan may be broken and needs to be replaced. For instructions on replacing a faulty cooling fan, visit this guide.
Randy Jean
crwdns2935283:010/28/21crwdne2935283:0
147 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-2, Gulbrandsen Fall 2021 crwdns2935289:0UMass Dartmouth, Team 4-2, Gulbrandsen Fall 2021crwdne2935289:0
UMASSD-GULBRANDSEN-F21S4G2
crwdns2942667:0crwdne2942667:0 516
