When ice makers leak, water ends up everywhere except the neat cubes you're expecting. Let's step through troubleshooting your device.
Ice-Maker Repair Toolkit
Fill Valve or Ice Fill Cup Misaligned
The water supply enters the rear of the ice maker through the fill valve and releases water through a tube into the cup that funnels water into the ice mold. If the fill valve or fill tube and fill cup appear misaligned, water is going to spill out and miss the ice cube mold. Realign and verify alignment by initiating the water-filling process. In some cases, your cup may need replacing.
Clogged Condensation or Defrost Drain
The condensation drain allows excess water in the freezer to exit. Your machine may run a defrost cycle which will create more water in your system. If the drain freezes, this water will freeze in your system.
  • Open the freezer and verify the defrost drain isn't blocked by items.
    • Move objects in the freezer to allow for more airflow, and wait a few days to see if the issue is resolved.
  • Check the drain for blockages from crumbs or ice. Remove the plastic cover over the drain hole.
    • Use air to blow the lines clear, if possible.
    • Melt any built-up ice with a hairdryer on low, or use a turkey baster and funnel for flushing warm water down the defrost drain.
Ice Maker Overfilling
The ice maker will typically fill with water for about 8 seconds per tray. Try resetting the ice maker and watch if this is the case. In some cases, you can adjust the level.
Faulty Water Inlet Valve
Your water supply line joins the water inlet valve before being dosed into the ice cube trays. If the water inlet valve is stuck in an open position, even just barely, it will continuously fill. It is time to test the valve.
This is also an appropriate time to check the supply line water pressure. The valve needs at least 20 psi so that it'll close properly after opening.
  • Pull your fridge away from the wall. Turn your supply water off.
  • Throw a towel down, and then disconnect the water inlet valve.
  • Put the supply hose in a bucket or nearby sink, and open the supply valve. Water should come out with a decent pressure — we're talking 20+ psi.
  • Now, use a multimeter and test the water inlet valve for continuity.
    • Resistance should read between 500-1.5KΩ.
Crooked Alignment or Out of Level
If water doesn't find the condensation drain, then it will either freeze or drain in undesirable locations. Check the level of your machine and adjust the feet and shim if necessary.
Old Water Filter
A filter that hasn't been changed in 6 or more months may be causing machine faults.
  • Replace the filter and run another cycle.
  • If water is leaking from the water filter housing, verify the filter is inserted entirely. Next, check that the hoses are inserted entirely and aren't cracking.
Loose Or Leaking Plumbing Connections
Interruption in the flow of water through the water line leading to the ice maker can account for leaking water. This usually means disconnection of lines or failing connections. Inspect the valves, water lines, and connectors for leaks. Replace and tighten as you go.
How to Reset Ice Maker
Ice Maker Not Making Ice
Ice Maker Only Crushing Ice
Ice Maker Not Dispensing Ice
Ice Maker Won't Stop Making Ice
Additional Resources
Refrigerator Icemakers
Answers Forum: Leaking Ice Maker
nicO
crwdns2935283:004/14/15crwdne2935283:0
15,990 crwdns2915208:0crwdne2915208:0
crwdns2935297:088crwdne2935297:0
Global Fixers crwdns2935289:0Global Fixerscrwdne2935289:0
Community
crwdns2931471:070crwdne2931471:0
crwdns2935297:03,048crwdne2935297:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 96
crwdns2942667:0crwdne2942667:0 9,865
