crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Camera Will Not Turn On
Pressing the power button does not turn camera on.
Battery Is Dead
If your camcorder will not turn on, a good place to start is to make sure the battery is charged. Plug your camcorder charger into an active outlet and plug the USB connector into the camera. If the display does not turn on and no charging lights activate, you will need to replace the battery. Detailed instructions for removing a damaged battery can be found here.
Power Button Is Stuck
Try to press the power button to turn on camera. If the button has very high resistance to finger pressure or does not click, your power button may not be properly seated in the housing. Try to wiggle the button to release it from its jammed position.
Damaged Motherboard
This issue is often the hardest to diagnose and an expensive repair. It is recommended that you first explore other possible causes first before attempting to replace the motherboard. Common symptoms of motherboard failure are the device locking up on startup and the device shutting down before startup is complete. If the camcorder begins to start up and freezes or shuts off, the motherboard is most likely damaged. If the motherboard is the issue, a replacement guide can be found here.
Screen Will Not Turn On or is Cracked
Camera is powered on, but the display is black.
Display is Disconnected
If you are experiencing a blank screen when the camcorder is turned on, the display may not be damaged, but just disconnected. Check your display's connections to ensure that they are not damaged or disconnected.
Display is Cracked or Damaged
If your display is cracked, damaged, or will not turn on, you may need to replace it. Follow the replacement guide here for step by step instructions.
Camera Does Not Recognize SD Card
Your SD card is not recognized by the camera, and the screen flashes "No SD" when attempting to capture a video or photo.
SD Card is Not Fully Inserted
Check to see if the card is fully inserted into the camcorder's case. If the card sticks out of the case, you may have the card in upside down or backwards. If the orientation of the card is correct, check to make sure nothing is trapped inside the SD card's slot, inhibiting it from insertion.
Damaged SD Port
If the SD port is damaged, the card will not be read. To fix this issue, the SD port must be replaced.
Motherboard Issues
You SD card may not be read because the connection between the SD port and the motherboard is severed. A non-operational motherboard can be replaced using the guide here.
Camera Is Out of Focus
The fixed focus on the camera is misaligned and the focus is either too close or too far away.
Lens Focus Length is Misaligned
A small bead of glue holds the lens at the proper focal length. If this glue breaks, your focus may be out of alignment. Check to see if the glue is still holding the lens, and if it is gone, the focus must be manually adjusted and re-glued.
Lens is Chipped or Cracked
If the lens is damaged, chipped, or will not adjust, you may need to replace it.
Waterproof Case Will Not Close
The waterproof case provided with the camera will not close around the camera to create a waterproof apparatus.
Case is Obstructed
Most likely, the reason for this issue is that there is something blocking the case from closing. Make sure the camera is not upside down in the case. Also, ensure that there is nothing else inside the case besides the camera.
Clasp Will Not Close
If the black clasp on the side of the waterproof case will not close, the case will not seal properly to ensure waterproof conditions. If the plastic clasp is broken, it must be replaced.
Jordan Baum
crwdns2935283:002/13/16crwdne2935283:0
355 crwdns2915208:0crwdne2915208:0
IUPUI, Team 54-6, Wilson Spring 2016 crwdns2935289:0IUPUI, Team 54-6, Wilson Spring 2016crwdne2935289:0
IUPUI-WILSON-S16S54G6
crwdns2944067:033crwdne2944067:0
what about if when i plug it into my computer and it wont reconize it
WolfNation - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
How do u turn off the LED Busy Light Indicator
patsymoneyas - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I had the same problem…..Take the card out of the camera….slide it into one of those giveaway MicroSD card adapters…..slot it into a reader….and Voila!
Wait a few seconds…Click on the removable disk that shows something is there…Click DCIM…Click 100MEDIA and there are your videos!
Don’t forget to format the card in the camera first before you shoot your action videos.
Yes…we both seem to have a faulty camera…but this method works fine, especially when you have more than one card…enjoy!
Peter Bayes - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
When I try to take a picture it freezes up and I have to wait for it to die until I can make it move again but the ad card has nothing on it
BrysonN Roblox - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 45
crwdns2959996:0crwdne2959996:0 25,275
