crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Unresponsive power button
No matter how many times I try to turn on my Learning Tunes Karaoke it won’t power on.
Dead Battery
Your batteries are easy to change. Unscrew the back panel, it can be done with a coin. Take out the old AA batteries and replace with 3 new ones.
Button is physically broken
Your power button might be broken physically and thus not making contact with the motherboard. If this is the case, please follow our Button Replacement Guide to begin the replacement procedure.
Electric switch is defective
The Learning Tunes Karaoke is a relatively simple device in that it does not contain many components. If the Learning Tunes Karaoke does not turn on after the previous steps, it is likely that the motherboard needs to be replaced.
Jammed light-up music note button
One or more of my music buttons will not budge.
Dirt/debris between buttons
Your music note button might be sticky from minor dirt build up or from sugary snacks. If this is the case, please follow ourButton Replacement Guide so you can clean or replace them.
The button might be broken physically and thus not putting pressure on contact. If this is the case, please follow our Button Replacement Guide to begin.
Internal obstruction
There might be something on the inside preventing the button from putting pressure on contact.
Difficult to move mode selector
The mode selector will not move and you cannot switch between songs.
Dirt/debris in track
Your mode selector might be sticky from minor dirt build up or from sugary snacks. If this is the case, please follow our Mode Selector Replacement Guide to start the process of replacement.
Misaligned slider
Your mode selector might have moved off the track. If this is the case, please follow our Mode Selector Replacement Guideto start the process.
There might be something inside preventing the mode selector from sliding.
Low volume with audio output
The Learning Tunes Karaoke does not play sounds and/or sounds are distorted.
Volume switch set to low
Check the position of the volume switch to see if it set on the low volume setting. If it is, then simply move the switch.
Low battery
Damaged speaker
If the sound is not what it used to be it might have a blown out the speaker. If the sound is muffled then check out ourSpeaker Replacement Guideto address the problem.
Display does not turn on
The display screen is not showing anything.
Dead batteries
Faulty display
If your screen isn’t turning on with some fresh batteries your display is faulty. Check out our Display Replacement guide to address the problem.
Adam Chaberek
crwdns2935283:002/09/16crwdne2935283:0
137 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 7-2, Cheng Spring 2016 crwdns2935289:0USF Tampa, Team 7-2, Cheng Spring 2016crwdne2935289:0
USFT-CHENG-S16S7G2
Hey,
Animation services are a big market nowadays. It is now a big business. It will return a big turnover of millions. Expertise knowledge is required in every step of animation making. It also includes film and design sector.
http://sparkworksmedia.com/
Michael Lee - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Some of the major decisions for moving day include whether or not to rent a moving truck, hire movers, or ask your friends and family to help. While the answers to each of those questions will be different for everyone, there are certain packing tips that are universal.
http://onthegomoving.co
Howard Sanders - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Most kids love to jump on a trampoline and many parents like them because they can provide a lot of exercise via a small amount of yard or floor space.
http://www.best-trampolinereviews.com/
Nichole Noto - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2959996:0crwdne2959996:0 1,629
