crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Phone will not turn on
No matter what you do, you can't get your Samsung Galaxy Note 3 to turn on.
Hold switch to turn on
Before delving into the guts of your iPod, make sure the hold switch.... read on.
Bad battery
It is possible that nothing is happening because the battery is bad. The battery must be replaced.
Bad display
It is possible that it appears nothing is happening because the display is bad. If the display is bad, it must be replaced.
Bad picture quality
Are your pictures coming out blurry? Is there visible crack appearing when you take a picture? Are you experiencing better photo quality on devices other than your phone
Cracked camera lens
If you notice that your camera lens has a visible crack... To fix this issue, the camera must be replaced.
Pictures have better quality on other devices
When taking pictures with your Samsung Galaxy Note 3, you notice there is a visible difference when viewing the image on your phone and viewing the image on another device. It is possible the display assembly is bad. If it is possibly that the display is bad then the display needs to be replaced.
Phone case is damaged
There's no denying that the back of your phone is damaged.
Damaged back cover
If your Samsung Galaxy Note 3 has a damaged back cover, the back cover must be replaced.
No audio output from headphone jack
When your headphones are placed in the jack, no sound is coming through the headphones.
Headphone jack will not connect to headphones and play sound
If there is no audio output from the headphones, when in doubt try restarting your phone. If after restarting the phone and there is still no audio output, a replacement of the headphone jack is necessary.
Possible water damage
Is there any chance that your phone had recent exposure to water and your headphone jack is no longer working? Try restarting the phone and try listening through your headphones again. If this does not work, a replacement of the jack may be necessary.
Display assembly is not working
No matter how much you press on it, the screen is not responding to your touch.
Screen does not respond to your touch
If the screen does not respond to your touch and you have a screen protector, try removing the screen protector. Sometimes the screen protector's thickness interferes with the performance of the touch screen.
Soft reset
If the touch screen is not working or freezes, try soft resetting your phone.
Screen not functioning
If the phone is still not functioning, it is possible you will need to replace the display assembly.
Rear Case Replacement
Battery Replacement
Disassembling Back Chassis
Disassembling the Motherboard
Camera Replacement
Headphone Jack Replacement
Display Assembly Replacement
Brittany Gail
crwdns2935283:009/23/14crwdne2935283:0
8.581 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-2, Blackwell Fall 2014 crwdns2935289:0USF Tampa, Team 2-2, Blackwell Fall 2014crwdne2935289:0
USFT-BLACKWELL-F14S2G2
crwdns2935297:084crwdne2935297:0
crwdns2944067:013crwdne2944067:0
sir my note 3 all sensor have stoped working please help thanks
raunaq - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
my phone often gets restarts itself
sisupriya - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
هاتفي غالبا ما يحصل إعادة تشغيل نفسه
bakaar0002 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My battery will charge in phone exactly like mine but when put in my phone battery will not charge
justnoob gaming - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My earphone stays on. When phone is not connected to earphone, I can talk with speaker on.
PA
Prentis Adams - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 43
crwdns2959996:0crwdne2959996:0 7,867
