This explains how to gain access to components behind the motherboard.
Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
Slide your fingernail or plastic opening tool along the edge of the rear case.
Lift the case gently from the base.
Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
Lift the battery out of its recess.
Place your fingernail in the groove of the stylus pen.
Pull the stylus pen away from the phone.
Remove the twelve 4mm Phillips #00 screws from the back chassis.
Insert the plastic opening tool into the Stylus Pen placement holder.
Lift the plastic opening tool so that the midframe separates from the base.
Remove the single screw beside headphone jack.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to remove both antenna clips.
Use a spudger to disconnect six cable connectors.
Pull up on the motherboard with tweezers.
crwdns2935229:075crwdne2935229:0
I'm looking for the screws for this phone, but all the search hits I've come across are for the screwdriver. Any leads on where I can find the screws?
Jared Lunt - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I can replace motherboard sm-n9005 with motherboard sm-n900
yacine - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I want to replace motherboard of galaxy note 3 SM-N900 with SM-N9005. Is it possible and can it convert 3g to 4G. Because my phone doesn't support 4G .it is 3g and I want to make it 4G .what should I do help me
Nippy Preet - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I am also looking for the same question
Jalil Ahmad - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
