Samsung Galaxy Note 3 Display Assembly Replacement
crwdns2869540:0crwdne2869540:0: 126K
4
46
161
125,676
crwdns2955950:0crwdne2955950:0: 22
crwdns2960004:012crwdne2960004:0, crwdns2960008:010crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 147
crwdns2959974:0147crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 86
crwdns2959982:086crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:045crwdne2931287:0 - crwdns2931289:01crwdne2931289:0
crwdns2955970:0crwdne2955970:0: crwdns2937803:0crwdne2937803:0
This guide shows how to remove everything from the display assembly.
    1. Samsung Galaxy Note 3 Display Assembly Replacement, Remove the rear case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
    2. Samsung Galaxy Note 3 Display Assembly Replacement, Remove Case from the Base: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note 3 Display Assembly Replacement, Remove Case from the Base: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide your fingernail or plastic opening tool along the edge of the rear case.
      • Lift the case gently from the base.
    1. Samsung Galaxy Note 3 Display Assembly Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note 3 Display Assembly Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
      • Lift the battery out of its recess.
    1. Samsung Galaxy Note 3 Display Assembly Replacement, S Pen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place your fingernail in the groove of the stylus pen.
      • Pull the stylus pen away from the phone.
    1. Samsung Galaxy Note 3 Display Assembly Replacement, Unscrew Back Chassis: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the twelve 4mm Phillips #00 screws from the back chassis.
    2. Samsung Galaxy Note 3 Display Assembly Replacement, Remove Back Chassis: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert the plastic opening tool into the Stylus Pen placement holder.
      • Lift the plastic opening tool so that the midframe separates from the base.
    1. Samsung Galaxy Note 3 Display Assembly Replacement, Screw Removal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note 3 Display Assembly Replacement, Screw Removal: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the single screw beside headphone jack.
    2. Samsung Galaxy Note 3 Display Assembly Replacement, Unfasten Clips and Cable Connectors: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note 3 Display Assembly Replacement, Unfasten Clips and Cable Connectors: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use tweezers to remove both antenna clips.
      • Use a spudger to disconnect six cable connectors.
    3. Samsung Galaxy Note 3 Display Assembly Replacement, Motherboard Removal: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull up on the motherboard with tweezers.
    1. Samsung Galaxy Note 3 Display Assembly Replacement, Spudger Tool Placement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert the spudger into the headphone jack.
    2. Samsung Galaxy Note 3 Display Assembly Replacement, Lift to Separate Headphone Jack: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the spudger to separate the jack assembly from the motherboard.
      • Pull to remove.
    1. Samsung Galaxy Note 3 Display Assembly Replacement, Metal Bracket Removal: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the metal bracket located in the top left hand corner.
    2. Samsung Galaxy Note 3 Display Assembly Replacement, Remove Vibrating Motor: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the vibrating motor by pulling up on it carefully with the tweezers.
    3. Samsung Galaxy Note 3 Display Assembly Replacement, USB Port Removal: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift USB port from the front assembly using the tweezers.
    4. Samsung Galaxy Note 3 Display Assembly Replacement, Display Assembly: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • You are now left with the display assembly.
crwdns2935229:0147crwdne2935229:0
Brittany Gail
crwdns2935283:009/23/14crwdne2935283:0
8,581 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-2, Blackwell Fall 2014 crwdns2935289:0USF Tampa, Team 2-2, Blackwell Fall 2014crwdne2935289:0
USFT-BLACKWELL-F14S2G2
crwdns2935297:084crwdne2935297:0
crwdns2947412:010crwdne2947412:0
είναι απόλυτα κατανοητό.
chandr - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Can you just replace the digitizer or is the digitizer glue down to good to the display where it might damage the LCD display when trying to replace the digitizer?
rob lang - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
to safely remove the LCD display from the front touch screen glass w/o damaging the LCD screen I advise you to invest in and familiarize yourself with an LCD Separator machine and all the accessories that go along with it. Also, search for the machine and watch the videos..
tkflenorl - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
sunil - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Can you just replace the digitizer or is the digitizer glue down to good to the display where it might damage the LCD display when trying to replace touch
crwdns2936753:07crwdne2936753:0 46
crwdns2936753:030crwdne2936753:0 161
crwdns2959996:0crwdne2959996:0 125,676
