IMPORTANT: CRT MONITORS CAN HOLD ANYWHERE BETWEEN 15K VOLTS (small B&W)-25k VOLTS (small-medium color), UP TO 50K (TVs, studio monitors, high-end desktop monitors like the GDM-FW900). DUE TO THE WIDE VARIATIONS OF WHAT EACH TYPE CAN HOLD, IT IS CRITICAL THAT THESE GET DISCHARGED CORRECTLY!
Sources used:
This Wiki aims to bridge the information from this 2018 answer and expand on the topic further, making the format better suited for use in the field. This post was made as the age of the answer, most of this information is aging to a point where it is becoming hard to locate: Disassembling an old Apple monitor. In addition to this answer and post, refer to this Apple documents: CRT Safety Apple CRT Safety (Classic Macs)
How to discharge a CRT
The first rule for safely discharging a CRT monitor is to ensure the monitor or computer is unplugged to prevent further charge from being restored. In addition, IF possible, flip the power switch on for 30 seconds, up to 1 minute (or hold the power button) to discharge the monitor. On modern "bleeder-based" CRTs, this is usually enough to discharge it, but beware: These resistors are typically burned out or abused to the point they are ineffective or weak! It is a silent process that pushes the resistor harder than other applications, so they only last a few years before weakening or failing. It is also a "silent" discharge (except for static sounds on some, but do not rely on this) and will not provide a visual indication. Due to these factors, a manual discharge is still required.
IMPORTANT: DO NOT WEAR ANY GROUNDING STRAPS; ELECTRICITY CHOOSES THE PATH OF LEAST RESISTANCE, AND YOUR ESD PROTECTION WILL BECOME THE GROUND. As such, you must remove all jewelry (and items like necklaces or chokers with a metal clasp; yes, that clasp is enough to cause harm) to mitigate the risks associated with jewelry completely.
CRT discharge tool
After making sure you do not become the new "ground," it is time to discharge the CRT. You can do this with an official discharge tool (these were designed for companies like Apple for service purposes) or an open-market tool, which was available and sold to the public (or at least, only to third-party repair shops).
If possible, it is also advisable to insulate part of the screwdriver handle with heat-shrink tubing, as this provides an additional cushion in case you accidentally touch the metal on the screwdriver. Caution is still required. Refer to this guide for a visual aid on the discharge process: Macintosh Classic II Power Board Removal. If you can locate the tool, this is generally what they look like (this tool is an example of the Apple-made version before they stopped working on CRT-based Macs). However, other versions were also made by different companies that serve the same purpose:
IMPORTANT: WHEN DISCHARGING THE CRT ITSELF, DO NOT HAVE BOTH HANDS IN THE WORKSPACE! IF BOTH HANDS ARE IN THE SPACE, THIS CAN CREATE A DIRECT SHOCK TO YOUR HEART, WHICH CAN KILL YOU. Place your nondominant hand behind your back or in a pocket to make sure you do not create a complete circuit and use your preferred dominant hand.
Creating an ongoing ground
If you have followed these safety rules to a T, you have successfully discharged a CRT and did not injure or shock yourself while discharging your CRT display.
Nick
crwdns2935283:011/10/09crwdne2935283:0
105 983 crwdns2915208:0crwdne2915208:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0335crwdne2931471:0
crwdns2935297:08 260crwdne2935297:0
Important Safety Reminder – Read Before Proceeding
Before attempting to discharge a CRT, make sure you’re not alone. Always have another person in the room while performing this procedure in case something goes wrong. CRT discharges involve lethal voltages, and although injuries are rare when done properly, accidents can happen—especially if you’re startled or working in an unfamiliar environment.
Also:
• Remove all jewelry (rings, bracelets, watches, necklaces). Metal conducts electricity and can cause severe burns or even arc in the presence of high voltage.
• Avoid clothing that builds static (like synthetic fleece, wool, or polyester). Stick to 100% cotton if possible.
• Work on a non-conductive surface, in a dry, well-lit environment.
Respect the danger, work carefully, and you’ll be fine—but having a second person nearby is not just smart, it’s potentially life-saving.
nirv - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 46
crwdns2936753:07crwdne2936753:0 250
crwdns2936753:030crwdne2936753:0 1,061
crwdns2942667:0crwdne2942667:0 20,476
