crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Device Housing is damaged
The white casing on the device is cracked or otherwise damaged
Try super gluing the crack shut
Try filling the crack with super glue to keep it from spreading.
The housing is otherwise damaged
If the damage can be stopped with glue, apply it to the damage. If you do not want to use something so permanent, you can try using tape.
Housing Replacement
If glue is not a suitable solution, the housing may be replaced entirely. This can be completed by following this replacement guide.
Portable DVD Player won't turn on or stay on
Your player refuses to turn on or remain on
If the device won't power up, try charging it
Ensure the player is turned off, and is connected to the charger for at least 7 hours in order to make sure that the battery is FULLY charged. If after being fully charged, it still will not power on, you may need to replace the battery.
Battery Replacement
If player doesn't turn on after being fully charged, you may have a bad battery. Use this replacement guide to replace your battery.
Player's buttons are not responding
Buttons do not respond when pressed
Buttons may be jammed
Try clearing out dust or particles around buttons with wipes or compressed air. You could try using a toothpick or other small pointed object to clear any excess debris.
Button Replacement
If buttons are not jammed, you may have to replace them. Use this replacement guide.
Sound quality is poor or distorted
Your player will not produce quality sound
Try turning volume up/on
Ensure the volume wheel is rolled on and, if using headphones, make sure they are in working order.
If using headphones, ensure they are not broken
Try using headphones on a different device to make sure that the headphones are working properly. If the headphones are in working order your port may need to be replaced.
Speaker Replacement
If player still won't produce sound when not using headphones, you may need to replace the speakers. This can be done by using thisreplacement guide.
The device is not reading DVD's or CD's
The disk keeps spinning, but not playing
Make sure the disk is not dirty or scratched
Use a soft cleaning cloth to wipe any debris from the disk.
Make sure it is not a problem with the disk
Try playing another disk in the player, if it will not play, then you may need to replace the disk drive.
Drive replacement
If the drive needs to be replaced, you can do that by following this replacement guide.
Abigail Scarborough
crwdns2935283:009/28/15crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-3, Matresse Fall 2015 crwdns2935289:0Eastern Washington University, Team 1-3, Matresse Fall 2015crwdne2935289:0
EWU-MATRESSE-F15S1G3
crwdns2935297:048crwdne2935297:0
Video from cable is scrambled. Audio is worse.
wyvernhunterg - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 8,904
