This guide will help users to replace the inner battery of the Philips PD9000/37 DVD Player.
Lay the player flat so the bottom outside is showing. Using the Phillips #0 screwdriver, unscrew all the housing screws on the bottom of the player.
Have the player sitting upright, remove the rubber stoppers in order to get to the screw. Unscrew the inside screws by the screen using the Philips #0 screwdriver.
Remove the rubber stoppers for the bottom two screws as well. Unscrew the middle two screws.
Open the disc flap and remove the screws inside with the Phillips #0 screwdriver. There will be three screws.
Start removing the inside black face plate of the player by using a prying method between the white outer housing and the black face plate with a metal spudger.
Pull the black face plate off once you have pried it from the white housing. The bottom inside layer should pop off.
Using the same prying method with the metal spudger, start prying off the screens white outer housing.
The light panel on the front can just pop right off.
To remove the metal bar against the battery, unscrew the screws with the phillips #0 screwdriver.
After unscrewing you can just lift the metal bar off.
Take the metal rounded rectangle spudger and place under battery edge.
press down hard on held end of spudger, you will hear the battery un-stick.
Use a soldering iron to melt the metal connecting the battery wires to the mother board.
Quickly remove each wire after melting the metal
Properly dispose of battery as soon as possible
crwdns2935229:05crwdne2935229:0
Where can this battery be bought? After a year using, playing time is down to 3 hours
L.Johnson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Yeah. Where can I get the battery?
Bryan Allen - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This tutorial is completely worthless if one doesn't have a battery to replace the one removed. Now two people have asked where to get a replacement yet you have not responded. Undoubtedly countless others have come by looking for a suitable replacement and saw that there was no response and no solution. Congratulations on helping no one. It would seem you're nothing more than a blowhard, a big show off, “Oh look at me I am fixing my bad battery. Aren't you impressed?” I'm not.
kurt - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
