Camera Won't Turn On
No matter what you do, you can't get your camera to turn on.
Drained/Dead batteries
The most likely problem is that your batteries are dead and need to be replaced. Replace with two AA batteries.
Removing Olympus FE-210 Batteries
Battery Connections
It is possible that the traces connecting the battery have become disconnected. Connections have to be checked and repaired.
Power Button Connection
It is possible that the wires connecting the power button are disconnected. Connections need to be checked and repaired.
Motherboard Failure
It is rare, but possible, that the motherboard has failed. The motherboard will have to be replaced.
Removing Olympus FE-210 Motherboard
Lens Won't Open/Close
When turning the camera on, the lens does not extend, or when turning the camera off, the lens does not retract.
Low Battery
The lens may not work properly with low batteries. Replace with two AA batteries and check again.
Lens Casing is Stuck
If the lens will not extend or contract fully, the lens may need to be adjusted. Remove and re-seat lens.
Olympus FE-210 Lens Assembly Replacement
Broken Lens Assembly
The motor controlling the lens may be damaged. Replace lens assembly.
Motherboard Failure
The worst case scenario is the motherboard is malfunctioning and needs to be replaced. Replace the motherboard and check again.
Screen Won't turn on
The camera turns on, but the screen stays dark.
Low Battery
If the screen stays dark, the batteries could be low. Replace with two AA batteries and check again.
Broken LCD Screen
If the screen is still dark, the LCD may need to be replaced. Remove outer casing and replace the LCD
Olympus FE-210 LCD Screen Replacement
Motherboard Failure
Flash Doesn't Work
When taking a photo, the flash does not discharge.
Flash Setting is Turned Off
Check that the flash settings are turned on. To access the flash menu, press the Right Arrow button while in one of the "still-photo modes".
Low Battery
The flash may not discharge if the batteries are too low. Replace with two AA batteries and check again.
Flash Bulb is Broken
The bulb may be burned out. Replace the bulb and check again.
Removing Olympus FE-210 Flash Assembly
Flash Capacitor is Damaged
The capacitor charging the flash may be burned out. Replace the capacitor and check again.
Motherboard Failure
Video Output Won't Work
When trying to output a video, the other device is not receiving the signal
Wrong Type of Output Cable
Check to see what type of cable you are using. Click on this link to see a picture of the correct AV cable.
Ensure Correct Video Output Setting
Depending on the territory your display is from, your output settings may need to change. Press the "Menu" button, and select the "Setup" option, scroll down to the last option on the second page, change to NTSC for United States and PAL for Europe.
Motherboard Failure
Alex Wolff
crwdns2935283:001/21/11crwdne2935283:0
234 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-36, Regan Winter 2011 crwdns2935289:0Cal Poly, Team 4-36, Regan Winter 2011crwdne2935289:0
CPSU-REGAN-W11S4G36
crwdns2935297:084crwdne2935297:0
crwdns2936753:030crwdne2936753:0 72
crwdns2959996:0crwdne2959996:0 12,073
