Olympus FE-210 LCD Screen Replacement
    1. Olympus FE-210 LCD Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus FE-210 LCD Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
    2. Olympus FE-210 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus FE-210 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The batteries will slide right out.
      • When putting new batteries in, make sure they are pointing the right direction.
    1. Olympus FE-210 LCD Screen Replacement, Front Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus FE-210 LCD Screen Replacement, Front Casing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus FE-210 LCD Screen Replacement, Front Casing: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the seven screws holding the front case in place, with a Phillips #00 screwdriver.
      • Six screws are 3.6 mm.
      • The seventh screw is 3.2 mm.
    2. Olympus FE-210 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus FE-210 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus FE-210 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert an opening tool or spudger into the seam between the front case and body of the camera to release the clips holding it together.
      • These three places are located:
      • At the top and bottom of the battery side (opposite of side pictured) of the case.
      • Right in the middle of the DC-in side (side pictured) of the case.
      • Top of the camera, to the left of the power button.
      • Once those places are disconnected, the front case will pop right off.
      • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
    1. Olympus FE-210 LCD Screen Replacement, Rear Casing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
      • After removal of the screw the case will be loose, but do not tug it off. There is a cord connecting the rear controls to the motherboard.
    2. Olympus FE-210 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus FE-210 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus FE-210 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
      • Lift the white latch using a fingernail or a spudger.
      • Pull the cord from its connector.
    1. Olympus FE-210 LCD Screen Replacement, LCD Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Olympus FE-210 LCD Screen Replacement, LCD Screen: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two 2.7 mm screws using a #00 screwdriver.
      • After removing the screws the display will be free. Do not remove it. Like the rear case, there is a cord connecting it to the motherboard that must be disconnected first.
    2. Olympus FE-210 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus FE-210 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus FE-210 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using a spudger, lift the latch on the connector.
      • Remove the ribbon cord from its connector.
      • Remove the LCD from the rest of the camera.
Matt
crwdns2935283:001/25/11crwdne2935283:0
826 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-36, Regan Winter 2011 crwdns2935289:0Cal Poly, Team 4-36, Regan Winter 2011crwdne2935289:0
CPSU-REGAN-W11S4G36
Now need source for replacement screen thank you
Emile Crotteau - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 75
crwdns2942667:0crwdne2942667:0 6,144
