crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Shutter Does Not Cycle
Camera shutter seems to "stick" halfway through the shutter cycle.
Low Battery
This error occurs due to low battery, and the camera should be reset. Remove the battery, fully charge the battery using the Nikon D80 battery charger, and then remove the memory card and reset the camera. This can be done by using the reset option in the menu. Alternatively, there is a reset switch on the camera's body, under the connector cover. Test to see if the shutter cycles by taking photos. If solved, the message should not reappear. If the error message is still appearing, view the Shutter Reset section below.
Incomplete Wire Connection
If resetting the camera does not fix the issue, there may be something wrong near the battery. Remove the bottom cover using this guide and see if any wires are unplugged or improperly connected.
Shutter Not Reset Correctly
If the camera reset is not successful, then reset the shutter. This is done by dismounting the lens and pressing the shutter button with the camera on; then remount the lens. Test by taking photos. If solved, the message should not reappear.
R09 Message Is Onscreen
You see R09 appear on the LCD screen.
Common Misconception
The R_number messages provide the user with buffering information. This R_number tells the user how many photos are available in the buffer.
D80 Metering Info Not In Viewfinder
The light meter and other options are not visible through the viewfinder.
Camera Needs Resetting
Select the RESET option in the Custom Settings Menu or hold the +/- and AF buttons for two (2) seconds or more.
Alternatively, with the camera off, remove the batteries for about fifteen (15) seconds, then replace the battery and turn on the camera.
Lens Is Cloudy
It is difficult to see through the lens due to a whitish color.
Debris On Lens
Wipe the outside of the lens with a clean towel or cloth.
Humidity Build-Up On Lens
Manually twist the lens, zooming it in and out to aerate, clearing the condensation from the cavity.
Menu Items Are Not Displayed
When looking at the LCD for the menu, it is not visible.
Menu Settings Require Adjusting
Select Full from the CSM / setup menu.
Rear LCD Screen Requires Replacement
If nothing continues to be visible on the rear LCD screen, the rear LCD screen may need to be replaced. Follow this link to access the rear LCD screen replacement guide.
Main Board or Mother Board Requires Replacement
If nothing continues to be visible on the rear LCD screen, your main board or mother board may need replacing. Follow this link to the main board replacement guide or this link to the mother board replacement guide.
Flash Does Not Activate When Taking Pictures
When pressing the shutter to take a picture, flash does not automatically trigger.
Incorrect Mode for Flash
Rotate mode dial to M and then press the Flash Mode button, or, alternatively, rotate mode dial to Auto; with this second option, the flash activates in low-light situations.
Flash Mechanism Requires Replacement
The flash mechanism may be broken; follow this link to find our flash assembly replacement guide.
Lindsey Griffin
crwdns2935283:010/04/16crwdne2935283:0
472 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-2, Nance Fall 2016 crwdns2935289:0USF Tampa, Team 2-2, Nance Fall 2016crwdne2935289:0
USFT-NANCE-F16S2G2
crwdns2944067:09crwdne2944067:0
I have followed the above instruction but still Err appears on the LCD screen.
Massoud Salamat - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Are you growing up, have you solved the problem?
Андрей Будко - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
my display flashes up Err and the clock dumble flashes on and off in the with the err help please
Chris - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
When I take a photo I get a “black photo” on the screen. Previously taken photos are displayed without problems. What is the problem?
MikeRen - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Chris did you ever get a reply? I have the same problem!!! I have reset everything with no luck!!!
Thanks
Dalecom2@yahoo.com
Dale - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 58
crwdns2936753:030crwdne2936753:0 222
crwdns2959996:0crwdne2959996:0 21,637
