crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
The Phone Doesn’t Vibrate
The phone does not vibrate when I receive notifications.
The Vibrator may be Disabled
Your phone may be set not to vibrate. To fix this issue, go to the settings menu, and make sure vibrate is set to ‘on’.
Vibration Motor is Broken.
The vibrator inside your phone may be dysfunctional. If you are unable to fix the vibrator in the settings menu, you may have to replace your phone’s vibrator. Visit the replacement page for the vibrator.
The Phone Lags or Operates Slowly
The phone doesn't respond right away when I swipe or tap.
Too Many Background Applications
Your phone may be running out of processing power because too many applications are running in the background. Try uninstalling apps that you don’t use or simply restart your phone.
The Phone is Out of Storage
Your phone’s storage may be full of applications, images, and other junk. This can cause your device to respond slower. Try freeing up space on your device by deleting things you don’t need or install a micro SD card to increase your device’s storage.
The Phone Needs a System Update
This isn’t an iPhone, so updating your operating system won’t make your phone slower. In fact, updating your phone can help to optimize your phone performance and give you a much needed increase in speed.
The Battery Needs to be Replaced
An old and faulty battery can throttle your processor, resulting in reduced speed. This may be the case if you've had your device for a while and the above fixes did not work. Visit the replacement page for replacing the battery.
The Device Won't Turn On
My phone frequently will not turn on when I press the power button. When I turn on my phone, it will shut off faster than normal.
The Battery isn’t Fully Charged
When charging the phone, it’s possible that the USB charging it is faulty and isn’t properly charging the phone. You could purchase a replacement charging cord.
The Battery is Faulty
If the phone has been charged up to at least 25% and still turns off after unplugging it, it is possible that your phone needs a replacement battery. You can replace your battery using this comprehensive guide here.
The Speakers Don’t Work or the Sound is Distorted
When playing music or calling someone on speakerphone, the audio is distorted or doesn’t make any noise
The Volume may be on Low
If your phone does not play any sound, try increasing the volume level using the volume control on the side of your phone or by accessing the sound settings in the settings menu.
The Pictures I take are Blurry
The pictures you take are coming out blurry or otherwise distorted
The Camera is Dirty
(Applicable to both front and rear camera) If your pictures are blurry it’s possible the camera needs to be cleaned. Wipe down the blurry camera with a microfiber cloth and alcohol before testing it out. If the pictures are still blurry remove the cover of the phone and wipe the inside of the cover that goes in front of the camera.
The Camera is Faulty
If your pictures still appear blurry after cleaning your camera, the actual camera piece may have a crack in the lens or could be faulty. You can replace your camera piece in the front here and in the back here.
Kristina Tran
crwdns2935283:001/24/18crwdne2935283:0
574 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S2-G3, Livingston Winter 2018 crwdns2935289:0Cal Poly, Team S2-G3, Livingston Winter 2018crwdne2935289:0
CPSU-LIVINGSTON-W18S2G3
fast booting option not showing. I do the same thing, but it does not work.
ARJUN LAL S - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 56
crwdns2942667:0crwdne2942667:0 3,198
