crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
The phone won't turn on
No matter what you do, you can't get your phone to turn on.
The phone is dead/has a bad battery
Before you start to disassemble the phone, make sure the phone is turned on. Also, try plugging the phone in to the charger. The battery may be dead. If the phone still won't turn on or charge, you may need to replace your battery. This is a simple task that is outlined in this guide.
The display screen has gone bad
The phone may actually be turning on, but nothing will appear on the screen if the display has gone bad. This is likely if nothing appears on the screen, but the phone still makes sounds and has call functionality. If this is the case, you may need to replace your display screen. A replacement guide can be found here.
You can't make calls/hear sounds
"No sound comes out of the front speaker of the phone."
Volume/sound settings
Double check that your volume settings are turned up and there aren't any audio output devices plugged into the device.
Broken/malfunctioning front speaker
If you can only hear sounds coming out of your rear speaker, your front speaker may be broken or malfunctioning. You can find a guide to replace your front speaker here.
Certain buttons won't input
"When a specific button or multiple buttons are pressed, there is nothing indicating the phone acknowledged it."
Inner workings are dirty
Take apart the phone and clean the inner workings with the buttons. Dirt and other debris can cause issues in the phone properly receiving the button inputs. Be careful in this endeavor. Avoid chemicals that could damage your phone.
Buttons themselves are broken
The buttons work with a cosmetic number pad and circuitry below that takes the actual input. The circuit board may be broken and need replacement. You can find a guide to replace this part here.
The screen is cracked
"After a violent event with the phone, the screen appears broken with a crack in it."
The outer shell is cracked
The phone is built with an outer, plastic shell covering the actual screen. This is the most likely part to be cracked/damaged. This will need to be replaced. You can find a guide to replace this part here.
The inner display screen is cracked
Inside the phone, there is a screen that actual displays the information. This may have been what has been cracked/damaged. It will need to be replaced. You can find a guide to replace this part here.
The battery runs out too fast
"When compared to other instances in which the phone has been used, the battery runs out of power at an alarmingly fast rate. The regular use of the phone is not significantly different than it was when the battery fared better."
Phone reception is bad in the area
Often, phone reception can be a drain on a battery. When the phone constantly searches for a signal, it will drain the battery faster. Keep an eye on the signal the phone normally gets in the areas you keep it. Check the battery's life within various reception qualities to see how pronounced this issue could be.
Battery is dying
A battery that is dying will hold less power than it would normally. The fix for this would be to replace the battery. You can find a guide to replace this part here.
Helen Karsten
crwdns2935283:010/23/14crwdne2935283:0
209 crwdns2915208:0crwdne2915208:0
Michigan Tech, Team 1-6, Lauer Fall 2014 crwdns2935289:0Michigan Tech, Team 1-6, Lauer Fall 2014crwdne2935289:0
MTU-LAUER-F14S1G6
crwdns2942667:0crwdne2942667:0 668
